Control of a servo with a mouse — Parallax Forums
BoneyardBoneyard Posts: 10
edited 2004-07-29 02:01 in BASIC Stamp
Im new to the Basic stamp. But learning.
I would like to control 2 servos with a optomechanical mouse or a new style optical.
Im trying this project with a logitech track ball to start off (its what I had handy)
So far im able to control one servo in one direction·by moving the track ball in any direction. The servo responds, but when I stop the ball movement the servo does not hold position, My other problem is having the two servos understand the x,y axis of the track ball.
so when·I move the track ball along the x axis one servo moves back and forth and when·I move the trackball along the y axis the other servo moves.
here is the code I have come up with. I do not know If it is even close.
Help Please.
'P0 to cs
'P1 to Data
'P2 to Clock
'P7 to servo
cs var out0
clock var in1
Do var in2
Servo var out15
moused var bit
mousein var byte 'mouse clock line
pass var bit
servotime var word
programtop:
dirL=%1011
dirH=11111
mousein=1
cs=1
clock=1
debug "starting"
looptop:
clock=0
pass=0
mousein=1
cs=0
getmousein
moused=moused << 1
pulsout 1,2
moused=do
moused=moused
pass=pass+2
if pass >9 then getmousein
cs=1
pulsout 15,1500
pulsout 15,0
servotime = moused * 5
pulsout 15,servotime
pulsout 6,500
goto looptop
goto programtop
  • BoneyardBoneyard Posts: 10
    hers my updated code
    '{$STAMP BS2}
    'P0 to cs
    'P1 to Data
    'P2 to Clock
    'P7 to servo
    cs var out0 'chip select line
    clock var out1 'chip clock line
    Do var in2 'Chip data input line
    Servo con 15 'servo output data
    moused var bit 'mouse input value
    pass var bit 'loop counter variable
    servotime var word 'output time for servo
    programtop:
    dirL=%1011 ' set low byte of IO direction
    dirH=11111
    mousein=1
    cs=1 'set chip select nominal state
    clock=1 'set clock nominal state to reset chip
    debug "starting"
    looptop:
    ' start a loop that reads the data from the mouse
    clock=0
    pass=0
    mousein=1
    cs=0
    ' clock the data in
    getmousein:
    moused=moused <<1 'shift the data bits in the value variable
    pulsout 1,2 'strobe the clock bit
    moused=do 'get the data and stuff it into a bit var
    moused=moused 'or the bit var with the value variable
    pass=pass+2 'increment the bit counter
    if pass >9 then getmousein 'if not 8 bits done do again
    cs=1 'end read with chip select
    ' the data is now read into the
    ' mouse variable and can be used for
    ' other things
    ' start a servo output time calculation
    ' based on the read data
    pulsout 15, 1500-0 'send the pulse to the servo on pin 15
    pulsout 6,500 'send a dummy pulse on pin 6 (unused)
    ' to slow the loop down for the servo
    goto looptop
    goto programtop
