SERIN / SEROUT Baudmode Parameter
Most of the troubles with SERIN and SEROUT come from incorrectly specifying the baudmode parameter.· You can save yourself a lot trouble by taking advantage of the conditional compilation capabilities of the version 2.1 compiler.· Here's a bit of code that appears in my standard template file:
#SELECT $STAMP
· #CASE BS2, BS2E, BS2PE
··· T1200······ CON···· 813
··· T2400······ CON···· 396
··· T4800······ CON···· 188
··· T9600······ CON···· 84
··· T19K2······ CON···· 32
··· T38K4······ CON···· 6
· #CASE BS2SX, BS2P
··· T1200······ CON···· 2063
··· T2400······ CON···· 1021
··· T4800······ CON···· 500
··· T9600······ CON···· 240
··· T19K2······ CON···· 110
··· T38K4······ CON···· 45
#ENDSELECT
Inverted······· CON···· $4000
Open··········· CON···· $8000
Baud··········· CON···· T9600
Jon Williams
Dallas Office
#SELECT $STAMP
· #CASE BS2SX, BS2P
#ENDSELECT
Jon Williams
Dallas Office
Sid
Sid Weaver
4-digit LED
http://hometown.aol.com/newzed/index.html
Baud··········· CON···· T9600 + Inverted
Jon Williams
Dallas Office
