DIRS and OUTS — Parallax Forums
DIRS and OUTS
NewzedNewzed Posts: 2,503
edited 2004-07-23 23:37 in BASIC Stamp
If I write:
DIRH = 1
OUTH = 0
will that make pins 8-15 outputs and set them all low?
Sid
  • K de JongK de Jong Posts: 154
    edited 2004-07-23 23:22
    Hi Sid,
    To my opinion (and that of the Stamp manual :-): yes, that should work that way!
    Klaus
    Newzed said...
    If I write:
    DIRH = 1
    OUTH = 0
    Sid
    edited 2004-07-23 23:30
    No, that will only make P8 go low. What you want to do is this:
    OUTH = %00000000
    DIRH = %11111111
    Using binary values when working with multiple IO pins helps "visualize" what's going on. Your code is doing this:
    DIRH = %00000001
    OUTH = %00000000
    ... so now you can see why only P8 is being made an output.
    Jon Williams
    Dallas Office
  • NewzedNewzed Posts: 2,503
    edited 2004-07-23 23:31
    Thanks, Klaus.· Been busy - haven't looked at your data logging thing but I will.
    Bespreking aan u later
    Sid
    Thanks, Jon.· Just wan't thinking.
    Sid
