Spin syntax: are multi-line statements a thing? — Parallax Forums
I am trying to put together a simple tokenizer for syntax highlighting purposes, and from what I have seen, statements cannot span multiple lines. Is that true? That would make my code a bit simpler
  • maccamacca Posts: 1,064
    Three dots can be used to ignore the rest of the line and continue parsing into the next line (from Spin2 documentation).
      STRUCT dir_entry_t(BYTE name[8], BYTE ext[3], BYTE attr, BYTE ntRes, BYTE crtTenth,  ...
        WORD crtTime, WORD crtDate, WORD accDate, WORD clusHI,                             ...
        WORD wrtTime, WORD wrtDate, WORD clusLO, LONG fileSize)
  • ke4pjwke4pjw Posts: 1,332
    I wish I had known that. I have done silly things like.....
    mask_info_H { // 16 bytes — Level H format information words, masks 0-7 }
    word     5769, {// Mask H-0 (001011010001001)
    }         5054, {// Mask H-1 (001001110111110)
    }         7399, {// Mask H-2 (001110011100111)
    }         6608, {// Mask H-3 (001100111010000)
    }         1890, {// Mask H-4 (000011101100010)
    }          597, {// Mask H-5 (000001001010101)
    }         3340, {// Mask H-6 (000110100001100)
    }         2107  {// Mask H-7 (000100000111011)}
    I really should sit down and read the whole Spin2 Doc
    Thanks!
  • JonnyMacJonnyMac Posts: 9,837
    Of the many nice things about Spin Tools, yesterday I -- without thinking -- used the ellipsis to extend a line in a P1 program and found it works. Note that it does not work for the P1 in Propeller Tool.
  • evanhevanh Posts: 17,289
    It wasn't always a feature of Spin2. Added in at Pnut v37.
