FrySky Smart Port (Telemetry) - Object Available?
in Propeller 1
Thanks in advance for any help provided!
Attempting to send global variable data from a P1 FLiP 32123 to a FrySky X20R using SmartPort.
Once received on the FrySky I'll use Lua and Ethos to create a custom telemetry display screen.
I'm pretty close ... I can provide Saleae Logic Analyzer screenshots and my current code if needed. But ... maybe someone has already done this? Can't find an Object on OBEX.
Relevant info provided...
-TD SR12 is actively polling
- FLiP is receiving SPort traffic
- Inversion, Baud Rate, Parity, Stop Bit are correct (or at least seem correct).
- 4.7K Ohm pull-up on the in/out Pin. Pin shifts from input to output during half duplex comms.
- Code is trying to respond...
- Keep getting a 0x00 framing error after the initial poll of 0x7E 0x1B. Perhaps a stop bit error or timing isn't correct...?
- Transmit byte routine is not producing a clean UART frame on the S.Port line ... not the receive side.
Thank you!
Never mind...figured it out.
