Pitfalls and crawling out... GetSec() behaves not as I expected, to slow and counting down - Page 3 — Parallax Forums
13»
  • JonnyMacJonnyMac Posts: 9,824
    I've attached my quadrature encode object that uses smart pins. Perhaps it will help you get started.
  • ErNaErNa Posts: 1,859
    edited 2026-04-15 19:31
    Thanks, Jon. Indeed, it was a great starting point. Btw: I like your versioning system. One remark: those rotary switches come in two variants: the solid versions intended for CNC machining and else actually show a quadrature signal. The cheap input switches often output a clock/direction signal. It can be decoded as a quadrature signal, but then four state changes stand for one increment.
    The smart pins are just great. They do the dirty work in real time and you fetch a result whenever needed. It's like watching a tanker passing by and just take it, if you are in the mood.
    Just a short question: I'm trying to use debug() on a P2 using a PropPlug, but lose debug communication. Another board with an USB-C works fine. Is this a known issue and is there a workaround? (I still use the outdated Propeller Tool 2.9.3
    Old Propeller Tool can be twitchy; you could try PNut or Spin Tools (for a nicer environment). If you really want to use Propeller Tool, you could try lowering the DEBUG baud rate using the DEBUG_BAUD constant).
    Debug_baud didn't solve the problem. I have a KISS board and a PropPlug. I'm looking to attach a display to the prop2, I normally use as debug output, but as there is no driver, I can not display status information. But I have to stop writing the driver, as the documentation is about 200 pages and the esp example is huge, so I'll fall back on my small display for now.
  • evanhevanh Posts: 17,238
    Dodgy USB cables have caused no end of trouble in the past. Make sure you've swapped to a known good cable before looking elsewhere.
