I've just updated my earlier post (here) with a slightly improved version of payload. This new version is also on GitHub, and will be included in the next Catalina release.
When using payload in 'dumb' mode on Windows, payload now maps the keyboard so that programs see the same input that they would see under a terminal emulator operating in vt100 mode.
This makes programs such as Catalyst and the vi text editor (which are designed to work with a vt100 terminal emulator) work better under the Windows Console Host and the Windows Terminal app, which interpret some vt100 escape codes, but do not generate vt100 keyboard output.
There are no changes to 'dumb' mode on Linux, since most Linux terminals already do this.
I just discovered that to use ANSI escape codes in a Console Host window (i.e. what used to be plain old cmd.exe) now requires a registry setting. If you use the Terminal App instead of the Console Host, you don't need to worry about this. but I tend to still use the Console Host because it is both simpler and and faster than the Terminal App.
Attached is a simple batch file to set or clear the appropriate registry setting. It will be included in the next Catalina release. In the meantime, just unzip it into Catalina's bin directory, and then to enable ANSI escape code processing enter: ansi_mode on
or to disable it enter: ansi mode off
To just check the current state enter: ansi_mode
Note that because this is a registry setting, you only have to do it once. I made it possible to turn it on or off in just case it upsets other programs that use the Console Host window.
Turning ANSI mode on makes the new version of payload (which adds 'dumb' terminal support) work properly in a Console Host window. Otherwise ANSI escape codes (e.g. used by Catalyst) will work when using the Terminal App, but not Console Host.
I had a need to rebuild my Windows MinGW installation recently, which upgraded gcc to 15.2.0 (the most recent version). I found a few things in Catalina needed tweaking because this version of gcc raises errors in cases where previous versions did not. This does not affect any existing binaries, and there are no functional changes, so those who use Windows but do not need to rebuild Catalina don't need to do anything.
I have uploaded the tweaks to GitHub, and will include them in the next release.
An update: The problem is not with Catalina. It is with either the latest version of gcc or MinGW, or with Windows. More investigation required. I hope the problem is with gcc or MinGW, because I can get around those simply by reverting to a version that works. If the problem with with Windows, then it will be a lot more difficult to find, and may be impossible to fix.
Just to repeat - the currently compiled Windows binaries (both on SourceForge or GitHub) are fine.
The problem is with the expansion of wildcards on the Windows command line - a process known as 'globbing'. On Linux, the command processor always does this for you. On Windows you have to do it yourself, but gcc can also do it for you.
What has happened is that in the current release of gcc/MinGW/Windows (not 100% sure which) globbing is apparently now turned off by default, whereas it used to be on by default.
All I had to do was add the line:
extern int _CRT_glob = 1; /* 0 turns off globbing; 1 turns it on */
I have added this line near the top of the following files:
source\catalina\catalina.c
source\catalina\catbind.c
source\catalina\bcc.c
source\lcc\etc\lcc.c
source\lcc\cpp\cpp.c
source\lcc\src\main.c
I will fix this on GitHub and also include it in the next release.
This is a full release. It adds a 'dumb' terminal mode to payload, updates Cake and the VT100 test program (vttest), and a has few minor non-functional changes that allow Catalina to compile correctly with the latest version of gcc.
Here is the relevant extract from the README.TXT:
New Functionality
1. Payload now has a 'dumb' mode, which is enabled by using the -I option
but specifying either "dumb" or "none" as the terminal name (e.g. -Idumb
or -I none). In dumb mode (after download, if a file is also specified)
payload just echoes all characters received on the serial port to stdout,
and all characters received on stdin to the serial port. Dumb mode can be
terminated by entering TWO consecutive CTRL-D characters.
As the name implies, in dumb mode, payload does not do any character
processing on either input or output characters (except for detecting
two successive CTRL-D characters) - If the Propeller program does any
terminal-dependent stuff (e.g. cursor movement, screen manipulation,
applying colors etc) this will work if that capability is implemented
by the terminal window in which payload is executing. In general, this
means many things will work quite smoothly (in Windows) using cmd.exe,
conhost or the terminal app, or (in Linux) in any window type derived
from an xterm.
On Windows, the keyboard is assumed to be an extended ASCII keyboard,
and the keyboard input is mapped to that which would be generated by a
terminal emulator operating in vt100 mode. This is done so that programs
see the same keyboard input when -I dumb is specified as they would see if
either -i or -I vt100 was specified. This makes both the Windows Console
Host and Terminal App behave more like a real terminal emulator in vt100
mode when used with programs like Catalyst or the vi text editor.
2. A new batch file (ansi_mode.bat) is included to set or clear the registry
setting that enables processing ANSI escape codes in the Console Host
window (this is enabled by default in the Terminal App). To enable ANSI
escape code processing in Console Host enter:
ansi_mode on
ansi mode off
Note that the setting will only affect NEW Console Host Windows, not
the current window. To just check the current state enter:
ansi_mode
Because this setting is in the registry, this only has to do be done
once, not on each login, or each time a Console Host window is opened.
It can be turned off again if it upsets other programs that use the
Enabling ANSI mode makes the new 'dumb' terminal option offered by payload
work correctly in a Console Host window. Otherwise ANSI escape codes (e.g.
used by Catalyst) work in the Terminal App, but not Console Host.
Other Changes
1. The vttest program, which is used to test vt100 compatibility, has been
updated to the latest version. Note that this program is NOT required to
use Catalina - it is a utility that can be used to test compatibility
of various vt100 terminal emulators, including Catalina's terminal emulator
(Comms.exe) as well as the Windows Console Host and Terminal App. See the
README file in /source/comms/vttest for more details.
2. There were two problems in the build scripts in /source/geany_bundle:
1. The build_all script used the pacman cache. This only worked if the
packages had already been downloaded. Now they are downloaded on each
build.
2. The option to unpack compressed packages is now --zstd, not -xz
Affected Windows only.
3. In the blackbox debugger, calls to the function blackbox_close() should have
no parameters. This caused recent versions of gcc to throw an error. No
functional changes. Affected Windows only.
4. In awka, the function awka_init_parachute() was being defined incorrectly
in error.c to accept parameters. This causes the latest versions of gcc to
throw an error. No functional changes.
Affected Windows and Linux.
5. When compiling awka, the Catalina parallelizer and the Catalina optimizer
with the latest version of gcc, the option -std=c99 must be added for
the programs to compile correctly. No functional changes.
6. When compiling lcc with the latest version of gcc, the definition of
_spawnvp() must be changed to match that in stdio.h for the program to
7. There is an issue with the current version of gcc/MinGW on Windows, which
means that 'globbing' (expansion of wildcard characters on the command line
was disabled by default. It can be manually re-enabled for programs that
need it by including the following line near the top of the main program
file:
8. There is an issue with versions of gcc which reserve the keyword
"constexpr", which was used by LCC as an identifier. This has now been
changed in LCC to "cnstexpr". No functional changes.
9. Non-C89 compatible comments in LCC (i.e. introduced using //) have now
been replaced with C89-compatible comments (i.e. /* ... */). No functional
changes.
10. There is an issue in MinGW32 that means some programs may fail to compile
with gcc when an old version of libwinpthread-1.dll exists in the PATH.
An error message that "clock_gettime64" was not found is generated.
The current fix is that "libwinpthread-1.dll" in Catalina's bin and
catalina_geany/bin directories have been replaced with the latest version.
However, in case this fix causes other problems, the old version are still
included, but have been renamed to "libwinpthread-1.dll.old".
This is a full release. The impetus for this release was the recent release of both Lua 5.4.8 and Lua 5.5.0. Lua 5.4.8 is the latest and greatest stable Lua release, while Lua 5.5.0 is the first of the next generation of Lua releases - interesting, but not mature or stable enough just yet to make it the default. However, while testing Lua 5.4.8 I found some issues that needed fixing, and also did some preparation work for the changes that will be coming in Lua 5.5.X.
New Functionality
1. Lua 5.5.0 has now been included in this release. However, Lua 5.5.X is not
yet mature or stable enough to replace Catalina's fully integrated
version, which remains at 5.4.X. However, Lua 5.5.0 is fully functional
when used stand-alone, apart from the capabilities enabled by defining the
ENABLE_PSRAM or ENABLE HYPER Catalina symbols when compiling Lua. Those
capabilities are deeply embedded in the internals of Lua 5.4.X, were
developed before the more general capability of using PSRAM as XMM RAM
was added, and are deprecated in this release. They are likely to be
dropped altogether in the next Catalina release.
To build Lua 5.5.0, go to the folder demos\catalyst\lua-5.5.0 and use the
build_all script in the same way as used to build Lua 5.4.X. For example:
build_all P2_EDGE SIMPLE VT100 MHZ_200 OPTIMIZE
To copy all the executables to an SD card, use the copy_all script. Note
that this script will supersede any existing Lua binaries and programs on
the SD Card. For example, if drive the SD Card is detected as drive H, the
command to enter would be:
copy_all h:
2. The version of Lua fully integrated into Catalina has been updated from
version 5.4.4 to 5.4.8. There is no new Lua functionality in this update,
just a few Lua bug fixes. However, there have been some minor tweaks to
some example programs as a result, mainly the multi-processing with Lua
examples. This is because the changes may not affect Lua's functionality,
but they do sometimes affect Lua's memory utilization. The updated example
programs now work with both Lua 5.4.X and Lua 5.5.X.
Note that the compiled (i.e. binary) format of Lua programs has changed
between versions 5.4.X and 5.5.X. This means that the corresponding version
of the lua compiler (luac) must be used. If the wrong version is used, the
following error message will be displayed:
bad binary format (version mismatch)
3. There are now only two copies of the Lua 5.4.X source files in this release
of Catalina (in previous releases there were three copies). The Lua source
files that used to be in demos/catalyst/lua/5.4.X are now copied from
source/catalina/lua-5.4.X when Catalyst is compiled using the build_all
scripts, and deleted again by the clean_all scripts (similar to the way
the self-hosted version of Catalina itself is built). Note that when the
Windows installer is used to install Catalina, this means that to compile
Catalyst from source, the Catalina sources MUST be installed. This option
is now the default.
A copy of the Lua 5.4.X source files still exists in the library source
tree. This duplication is likely to remain so that the stand-alone version
of Lua can be updated independently from the integrated version.
Note that when Lua is built as part of Catalina (it is used for scripting
in both payload and blackbox) the standard Lua Makefiles are used. When it
is built as part of Catalyst, the Makefiles in the src folder are used
(Makefile.Catalina on Linux, or Makefile.Catalina.mgw on Windows).
4. Partly in anticipation of Lua 5.5.X becoming Catalina's default integrated
version of Lua, the multiple different versions of the Lua initialization
file (variously called linit.c, iinit.c or xinit.c) which enabled different
Lua libraries in previous releases have all been replaced with a common
version (linit.c). In this release, this file must still be present and
compiled in the same folder as the Lua application, but this will change
in Lua 5.5.X, which uses a different initialization process).
Specific libraries to be enabled or disabled are now specified on the
Catalina command line (or in a catapult pragma) as follows:
propeller always enabled
hmi always enabled
threads enabled by -lthreads
serial enabled by -lserial2 or -lserial8
wifi enabled by -lwifi
service enabled by -C LUA_SERVICE
linenoise enabled by -C LUA_LINENOISE
If memory is very tight, the optional debug, utf8 and os libraries can
be disabled by -C LUA_NO_OPT, and if only integer math is required then
the math library can be disabled by -C LUA_NO_MATH - but neither of
these are used in any of the demo programs, and doing so is deprecated
because these options will not be available when Lua 5.5.X becomes the
default version of Lua.
Other Changes
1. There was a bug in the Multiprocessing versions of Lua (i.e. mlua and
mluax) that may have led to a program lock-up when multiple factories were
in use (for example, it may have occurred when executing the example
programs ex9.lua or ex12.lua). Affected the Propeller 2 only.
2. There was a bug in Catalyst that limited commands to 8 characters when
no extension was specified. So (for example) the program "bin/dbasic.bin"
would be correctly found and executed if the command was entered as:
dbasic
dbasic.bin
bin/dbasic.bin
but NOT if entered as:
bin/dbasic
Instead, "cannot open file BIN/DBASIC" would be displayed.
Affected the Propeller 1 and Propeller 2.
3. Some Lua programs have been updated to allow for the use of either Lua 5.4
or Lua 5.5. In particular, Lua 5.5 requires different parameters to the
collectgarbage() function. The following code takes the lua version into
account, and can be used set a specific garbage collection mode and/or
parameters in a way that is backwards compatible:
lua_version = tonumber(string.sub(_VERSION, 5, 7));
if lua_version and lua_version < 5.4 then
-- default mode is incremental, so just set parameters ...
collectgarbage("setpause", 150);
collectgarbage("setstepmul", 500);
elseif lua_version and lua_version < 5.5 then
-- incremental mode is optional, so set it with parameters ...
collectgarbage("incremental", 150, 500);
else
-- mode and parameter setting now separate in Lua 5.5 ...
collectgarbage("incremental");
collectgarbage("param", "pause", 150);
collectgarbage("param", "stepmul", 500);
end
4. To minimize Lua's use of memory, the threads functions wait() and workers()
also used to do garbage collection in previous releases - this was done to
collect garbage after workers and threads had been initiated. However, a
better solution is to do this explicitly if needed, and also for threads
themselves to be able to perform garbage collection if required, so a new
"thread safe" function for invoking the Lua garbage collector has been
added to the threads module. The threads.gc() function can combine the
functionality of collectgarbage() and threads.sbrk() (which are often used
together to maximize free Lua memory and also defragment the C heap) into
one function. See the updated "Lua on the Propeller 2 with Catalina"
document for more details. The example program ex9.lua demonstrates the
new function. If backwards compatibility is necessary, Lua code such as
the following can be used to detect if the threads.gc() function is
available or not:
if threads.gc then
threads.gc(1) -- also invokes sbrk(true)
else
-- note: not guaranteed thread safe ...
collectgarbage()
thread.sbrk(true)
end
5. Upgrading to Lua 5.4.8 has made some programs that used the integrated
version of Lua (i.e. the version in the Catalina library) slightly larger,
which may cause the program to run out of Hub RAM. For example, the Aloha
WiFi RPC demo program sluarfx.c is now too large to execute correctly if
compiled in NATIVE mode, and so has been replaced by the functionally
identical program slaurcx.c which instead uses COMPACT mode.
This change may affect other programs. Affected the Propeller 2 only.
6. The 'Aloha from Lua' document mentioned that the rpc_network table could
be in the common.lua module, but in the RPC demo programs the table was
instead duplicated in the server.lua, remote.lua and serverbg.lua modules.
While this is technically ok, it complicates the process of configuring
the demo programs. Now, the document and all the demo programs have been
made consistent, with only one copy of the rpc_service table in the
common.lua module. Affected the Propeller 2 only.
7. There were a couple of issues with the WiFi version of ALOHA:
(a) There was an undocumented limitation on the size of an WiFi RPC
request. The code currently limits such requests to a maximum of 512
bytes (the RPC response can be larger). This limit caused one of the
demo programs (i.e. the 'complete' demo) to work with the serial
version, but not the WiFi version because the string used was too
long. The example has now been corrected to work with both, and the
'ALOHA from Lua' document also has been updated. This limit may be
increased in a future release.
(b) The Lua dispatcher could fail to retrieve all data returned by an
RPC call when the response consisted of multiple data packets.
I just pushed an update to Catalina's ENABLE_HYPER and ENABLE_PSRAM Lua options to github.
I had intended to deprecate these options, but it turned out that adding them to Lua 5.5.0 was trivial, and also Lua 5.5.0 claims to substantially reduce Lua's run-time data requirements, which means these options (which allow larger Lua code sizes without the performance hit of using XMM RAM) may turn out to be very useful in Lua 5.5.X.
These options provide an alternative way to use PSRAM to Catalina's normal SMALL and LARGE XMM options, which use the PSRAM or HYPER RAM as general-purpose external memory. Instead, these option build a special version of Lua that uses the PSRAM as a dedicated cache for Lua code only. These options are described in the Catalyst Reference Manual. Using PSRAM as XMM RAM is easier and more flexible - it is but also much slower. The ENABLE_PSRAM and ENABLE_HYPER options help fill a significant gap in the performance/size tradeoff.
To illustrate this, here is a comparison of a trivial Lua fibo benchmark program, executed with Lua 5.5.0 and using various memory configurations. I have normalized the results so that the fastest mode is 1.0:
NATIVE : 1.0 uses only Hub RAM. Max Lua code and data ~85kb
NATIVE with ENABLE_PSRAM : 1.3 uses PSRAM for Lua code and Hub RAM for Lua data and C code and data. Max Lua code 16Mb. Max Lua data ~75kb
COMPACT : 4.5 uses only Hub RAM. Max Lua code and data ~245kb
COMPACT with ENABLE_PSRAM : 5.9 uses PSRAM for Lua code and Hub RAM for Lua data and C code and data. Max Lua code 16Mb. Max Lua data ~240kb
SMALL : 8.7 uses PSRAM for C code and Hub RAM for C data and Lua code and data. Max C code ~15.5Mb. Max Lua code and data ~465kb
LARGE : 13.5 uses PSRAM for C and Lua code and data. Max C and Lua code and data ~15.5Mb
EDIT: Added NATIVE with ENABLE_PSRAM
EDIT: Fixed SMALL Max sizes.
Oops! The Catalina 8.8.5 packages on Sourceforge contain an extraneous directory that can prevent Lua 5.5.0 from compiling. This does not affect GitHub.
I have updated the packages, but if you have already downloaded them you do not need to do so again - all you need to do is remove one (empty!) directory:
To do so, open a Catalina command line window and then (on Windows):
I have pushed another bunch of small updates to GitHub. Catalina's Multi-processing extensions to Lua are not Propeller specific - they should also work when Lua is compiled natively for Windows or Linux (in which cases they use Posix threads in place of Catalina threads).
However, I had not tested this with Lua 5.5.0 and had not realized that this version of Lua made some internal changes which my extension modules also needed to adopt to make them compile correctly with gcc (they compiled correctly with Catalina).
A few minor tweaks and the versions of Lua with Multi-processing extensions (i.e. mlua and mluax) now also work on Windows and Linux again in Lua 5.5.0 (they already worked on the Propeller).
However, I also found that Multi-processing Lua example 6 (i.e. ex6.lua) contains a race condition, which is exposed in the Linux version (it does not seem to affect the Propeller or Windows versions). I will have to have a think about this one - the problem is inherent in Posix condition variables, not in Lua or Catalina. If I can't fix this example, then I will include a new one in the next release.
Here is an updated version of ex6.lua - it is functionally identical to the previous versions, but eliminating the race condition has made it a little more complex. However, it now works properly on the Propeller as well as on Windows and Linux:
t = threads
-- we want four simultaneous threads
t.workers(4)
-- here is how we will identify them, which
-- is also a string for each one to output
eeny = "eeny "
meeny = "meeny "
miney = "miney "
mo = "mo\n"
-- we need four condition variables
-- (one for each thread)
t.condition(eeny)
t.condition(meeny)
t.condition(miney)
t.condition(mo)
-- generate a thread function
function Thread(me, next, count, last)
return function()
t = threads
repeat
t.lock(me)
t.update(me, true)
t.wait(me)
t.update(me, false)
t.unlock(me)
t.output(me)
count = count - 1
if (count > 0) or not last then
next_ready = false
while not next_ready do
t.lock(next)
next_ready = t.shared(next)
t.unlock(next)
end
t.signal(next)
end
until count == 0
end
end
-- wait till a thread is "ready"
-- (i.e. waiting on its condition variable)
function wait_till_ready(this)
local this_ready = false
while not this_ready do
t.lock(this)
this_ready = t.shared(this)
t.unlock(this)
end
return this_ready
end
count = 20
-- create the threads
t.new(Thread(eeny, meeny, count, false))
t.new(Thread(meeny, miney, count, false))
t.new(Thread(miney, mo, count, false))
t.new(Thread(mo, eeny, count, true))
-- wait till eeny is "ready"
wait_till_ready(eeny)
-- kick things off
t.signal(eeny)
-- wait for threads to complete
t.wait()
This version is now on GitHub, along with an updated description in the Lua on the Propeller 2 with Catalina document.
Ross.
EDIT: Thought I'd add a brief explanation here as to why this version eliminates the race condition. The key is to lock the condition mutex each and every time you access the condition (which in this version is now a shared variable rather than the condition variable itself).
What this does is guarantee that the "condition" (represented here by the shared variable "next") is not in the process of changing when you access it - i.e. the lock ensures that any change is completed before you are given access (your process is stalled if required until this is true). That's all that's needed - but without that you can (in this instance) retrieve a "condition" of true when in fact it is not yettrue, but will be almost immediately afterwards. This is a classic race condition! - if the thread execution is interleaved at exactly the wrong instant, you are in fact working with the wrong information, and the result is usually a deadlock!
This stuff is hard ... but interesting and necessary ... if you want to do parallel processing
I just pushed a few updates to the catapult and eLua/ALOHA demos to GitHub. Here is the summary:
Implement a new FIXED_ARGS Catalina option, which enables the allocation of the maximum memory that might be required for command line arguments, rather than the actual memory used. Note that FIXED_ARGS has no effect if NO_ARGS is specified for the same compilation.
Add -C FIXED_ARGS to all catapult primary program compilations.
Fix the use of alloca() in various catapult and ALOHA demos so that the catapult memory buffer allocation does not depend on the command-line arguments.
Add a new catapult demo (demos/catapult/lua_lua) to illustrate that the primary and secondary programs can both be instances of Lua, and that the secondary can be multi-threaded (typically, the primary cannot because it executes from XMM RAM).
Note that the new catapult demo is a different thing to eLua - eLua implements a full-blown client/server architecture between potentially many Lua instances, which can be running on different Propellers connected by serial or WiFi connections. The new demo is much smaller (and much simpler) because the two instances of Lua run on the same propeller and (apart from sharing data via Hub RAM) otherwise execute independently.
This is a full release. This release has a few minor enhancements, fixes a bunch of minor issues, and adds a demo of eLua to the pre-built binaries.
New Functionality
1. If a compiled version of a Lua module exists, it is now loaded in
preference to the uncompiled version - e.g. given 'require "module"'
Lua will now try to load "module.lux" and load it if it exists,
otherwise it will try "module.lua". The full search path is now:
?.lux; ?.lua;
?/init.lux; ?/init.lua;
lua/?.lux; lua/?.lua;
lua/?/init.lux; lua/?/init.lua
This search path can be set using the environment variable LUA_PATH,
so to revert to the previous behaviour use the Catalyst command:
set LUA_PATH="?.lua;?/init.lua;lua/?.lua;lua/?/init.lua"
2. When the Catalyst pre-built demos are built for a Propeller 2 platform
with XMM RAM (i.e. the P2_EDGE or P2_EVAL) then eLua is now also built
(i.e. elua, elaux, eluafx, eluas, eluasx). An eLua demo of the Game of
Life is also copied into the folder 'life'.
See the file life/README.TXT for details on executing this demo. In
particular, note that 'exec life/rebuild' must be executed before
the demo can be executed.
3. The catapult and elua/ALOHA demos now allow fixed length path names of up
to 128 bytes instead of just a DOS 8.3 file name. This allows eLua/ALOHA
programs to be put into folders. The pre-built demos for the Propeller 2
now contain an example of doing this - i.e. the Game of Life eLua demo in
folder 'life'.
Other Changes
1. The build scripts for the P2_EDGE and P2_EVAL Catalyst demos were
building cake to use a serial HMI even when compiling the VGA demos.
2. There were issues with catapult programs that accepted command line
arguments. The size and number of arguments could change the memory
addresses allocated in the program, requiring it to be recompiled in
each case. This has now been fixed by the addition of a new Catalina
option -C FIXED_ARGS, which forces the program to always allocate the
maximum possible number of bytes for command line arguments even if
none were specified or supported. In cases where no command line
argument support is required, This can be disabled using the existing
option -C NO_ARGS. Affected the Propeller 2 only.
3. Several of the catapult demos, including the ALOHA demos, were allocating
hub RAM for file names BEFORE allocating the catapult memory buffers,
which meant that the buffer addresses could change depending on the
command-line arguments. All the demos now always allocate a fixed amount
of Hub RAM to hold the file names so that the catapult buffers will
always have the same addresses. Affected the Propeller 2 only.
4. Updated the 'Aloha from Lua' document to match the current version of the
Lua initialization file (linit.c).
5. It was possible for the Serial ALOHA protocol to overrun the serial buffers
in the case of large messages. Now a delay has been added when transmitting
(defaults to 5ms every 16 characters, but it can be adjusted in aloha.c).
6. Recent Lua updates have changed the size of Lua executables, and hence the
size of Lua programs that can be executed from Hub RAM. The 'Game of Life'
eLua demo is now too large to be executed with 'sluafx', but since it does
not need floating point it can still be executed using 'sluafix'. The
'Aloha from Lua' document has been updated accordingly.
7. Removed all "just update version number" type comments - they served no
useful purpose and just consumed space (especially in Lua scripts).
8. Use $* in place of $1 $2 $3 ... $9 and %* in place of %1 %2 %3 .. %9
wherever it is feasible to do so. This is necessary because Catalina now
has so many symbols that may need to be defined on a command line (usually
in scripts) it is now possible that more than 9 parameters need to be
specified.
While Linux users can easily rebuild Catalina from source, building Catalina on Windows is still such a painful process that I don't expect anyone but me ever bothers doing it. I am also sure most Windows users use the installer rather than cloning GitHub, so I have decided to simplify things by just including the Windows installer as a GitHub asset, instead of re-bundling the Windows binaries separately (I also realized I had made some silly mistakes in these bundles in the past, whereas the Windows installer is pretty thoroughly tested before each release).
Catalina now incorporates everything I need for Propeller development, so apart from expected forthcoming Cake and Lua updates, the next few releases will probably only be for bug fixes.
I just posted a brief video on Patreon (here) to show how to execute the new eLua demo, which requires a terminal window size of 80x30 (i.e. 80 columns and 30 rows) to display correctly.
Some Windows users have had trouble, probably because they use payload with the default terminal emulator settings, which sets the window size to 80x24 - and the terminal size can't be adjusted once payload starts.
The solution is to either use a slightly more sophisticated vt100 terminal emulator, or use payload with the -Inone option, which disables its internal terminal emulator.
@Tatevrt said:
Catalina is an open-source C compiler for Propeller 1 & 2 that also runs Lua (5.1.5 & 5.4.3). It supports embedded scripting, standalone Lua, and multi-threading with minimal RAM use. Catalina 5 adds full Lua multi-threading and pthreads-style support. Mac isn’t officially supported.
The current supported versions of Lua are 5.5.0 (the latest release) and 5.4.8 (the most stable release). The officially supported platforms are Windows and Linux (including Pi Os). Mac was supported by early Catalina releases, but I stopped supporting it when it became impossible to do so without actually owning a physical Mac, which is beyond my budget
I've just pushed a minor update to github. Cake has been updated to version 0.12.72 which fixes a minor issue compiling coremark. It now compiles without needing any source code modification (just the addition of the catalina port directory). I may remove the coremark source from the next release and just put a link to where they can be downloaded from.
I've just pushed another minor update to GitHub. When additional include paths were specified on the command line using -I, the paths were incorrectly being "quoted" before being passed to the preprocessor. This did not matter on Windows or when using cpp as the preprocessor, but it broke Catalina on Linux when using cake.
For example, the following command would work on Windows, but would fail to find any include files in my_includes on Linux:
I've just posted a Catapult update to GitHub. The purpose of the update is to simplify the creation of C and Lua client/server applications. There are no changes to Catalina itself.
I have added two more Catapult pragmas - #pragma catapult service and #pragma catapult service_list - that create and configure all the necessary proxy functions automatically.
It is still possible to do this manually (which means existing Catapult programs will still work) but using the new pragmas simplifies the program, eliminates a possible source of error, and permits client/server applications to be compiled monolithically (i.e. as simple linear programs, not multi-model programs). C programs can also be executed when compiled monolithically, but Lua programs cannot (because the Lua server is expecting to run on a separate cog).
Below is an updated example (srv_c_p2.c which is also in the demos/catapult directory). It implements a C client executing from Hub RAM and a C server executing from XMM RAM (when compiled using Catapult) or Hub RAM (when compiled monolithically using Catalina).
This example is for a P2 Edge with PSRAM (i.e. the P2_EC32MB). The instructions for compiling and executing it are in the comments:
#pragma catapult common options(-W-w -p2 -C P2_EDGE -C SIMPLE -C NO_ARGS -lc -lmc)
* Using Catapult to build a C server. *
* This program demonstrates executing a primary server from XMM RAM that *
* dispatches service calls made from one or more C secondary clients to *
* C functions implemented in the primary server (i.e. from XMM RAM). *
* The program uses the Catalina Registry as the mechanism, which enables *
* the server to offer multiple services, and also adds lock protection to *
* the services. Using the registry supports only a limited number of *
* parameter profiles - i.e. those that are required to implement Catalina *
* plugins (see func_1 to func_5). However, the basic "short" service can *
* also be used to pass a pointer to the shared data structure as the *
* parameter, which allows for arbitary data to be exchanged between client *
* and server, as usual for catapult programs (see func_6). *
* This version is for a Propeller 2 P2_EDGE with PSRAM (i.e. a P2-EC32MB). *
* Compile this program with a command like: *
* catapult srv_c_p2.c *
* Before loading, execute 'build_utilities' to build the appropriate XMM *
* loader (for a P2_EDGE with PSRAM and an 8K cache), and then load and *
* execute the program with a command like: *
* payload -o2 -i XMM srv_c_p2 *
* Note that if you modify the program, you may have to modify the address *
* specified in the secondary pragma - but the program will tell you what *
* address to use when you compile and execute it. *
* This program can also be compiled 'monolitically' (i.e. without catapult) *
* and then executed using commands like: *
* catalina -p2 -CP2_EDGE -lc -lm srv_c_p2.c *
* payload -o2 -i srv_c_p2 *
* See the document 'Getting Started with Catapult' for details. *
#include <catapult.h>
#include <service.h>
#include <stdlib.h>
* Define a type to be used for exchanging data between the client and server.
* The 'ready' and 'start' fields are used to ensure the client does not start
* till the server is ready.
typedef struct shared_data {
int ready;
int start;
int data;
} shared_data_t;
* Forward declare the client function (so the server can start it)
void hub_client(shared_data_t *s);
#pragma catapult primary binary(srv_c_p2) mode(XMM)
* The server (primary) - loads the client, then executes a C dispatcher, *
* dispatching calls to the C functions specified in my_service_list *
* Define the C functions implemented by the server - note the use of
* '#pragma catapult service' to identify functions that need to have
* proxy functions created for clients to call.
#pragma catapult service func_1 type(short)
int func_1(long l) { // example SHORT_SVC
t_printf("Hello, World (from C func_1!)\n");
t_printf("Args: l=%ld\n", l);
return l + 1;
#pragma catapult service func_2 type(long)
int func_2(long l) { // example LONG_SVC
t_printf("Hello, World (from C func_2!)\n");
return l + 2;
#pragma catapult service func_3 type(long_2)
int func_3(long l1, long l2) { // example LONG_2_SVC
t_printf("Hello, World (from C func_3!)\n");
t_printf("Args: l1=%ld, l2=%ld\n", l1, l2);
return l1 + l2 + 3;
#pragma catapult service func_4 type(float)
float func_4(float f1, float f2) { // example FLOAT_SVC
t_printf("Hello, World (from C func_4!)\n");
t_printf("Args: f1=%f, f2=%f\n", f1, f2);
return f1 + f2 + 4;
#pragma catapult service func_5 type(long_float)
long func_5(float f1, float f2) { // example LONG_FLOAT_SVC
t_printf("Hello, World (from C func_5!)\n");
return (long)(f1 + f2) + 5;
#pragma catapult service func_6 type(shared)
long func_6(shared_data_t *shared) { // example SHARED_SVC
t_printf("Hello, World (from C func_6!)\n");
shared->data++;
return shared->data;
* Define a service list to use for dispatching calls to the server.
* We can autofill the list by using #pragma catapult service_list,
* specifying type C. Note that the list must be terminated with
* a null entry -i.e. {"", NULL, 0}
svc_list_t my_service_list = {
#pragma catapult service_list type(C)
{"", NULL, 0}
* the main function does all the initialization
void main() {
shared_data_t shared = { 0, 0, 0 };
int cog;
// re-register this cog as a server (it will already
// be registered, but as a kernel, not a server)
_register_plugin(_cogid(), LMM_SVR);
// register the services, so clients can find them
_register_services(_locknew(), my_service_list);
// load the client function - it will wait for the
// 'start' field of the shared_data argument to be set
RESERVE_AND_START(hub_client, shared, ANY_COG, cog);
#ifdef __CATAPULTED
// wait for the client to be ready (required if the client
// prints messages, to prevent garbled output, and only if we
// have been processed by Catapult, otherwise this blocks!)
while (!shared.ready);
#endif
// the server is ready - start the client
t_printf("Server ready - press a key to begin ...\n");
k_wait();
shared.start = 1;
// dispatch calls made to the services in my_service_list
DISPATCH_C(my_service_list);
#pragma catapult secondary hub_client(shared_data_t) address(0x77178) mode(NMM) stack(500)
* The client (secondary) - calls services provided by the server (primary) *
void hub_client(shared_data_t *s) {
int i = 0;
long l = 0;
float f = 0.0;
t_printf("Client ready - press a key to start the server ...\n");
k_wait();
// tell the server we are ready
s->ready = 1;
#ifdef __CATAPULTED
// wait till we are told to start by the server before proceeding
// (only if we have been processed by Catapult, otherwise this blocks!)
while (s->start == 0);
#endif
t_printf("The client calls from cog %d ...\n", _cogid());
t_printf("... to the server on cog %d\n", _locate_plugin(LMM_SVR));
// call the services ...
while(1) {
t_printf("\nPress a key to continue ...\n");
k_wait();
i = func_1(1000);
t_printf("result of func_1 = %d\n", i);
i = func_2(2000);
t_printf("result of func_2 = %d\n", i);
i = func_3(3000, 4000);
t_printf("result of func_3 = %d\n", i);
f = func_4(5000.0, 6000.0);
t_printf("result of func_4 = %f\n", f);
l = func_5(7000.0, 8000.0);
t_printf("result of func_5 = %ld\n", l);
i = func_6(s);
t_printf("result of func_6 = %d\n", i);
The Getting Started with Catapult document has been updated and is also on GitHub, along with similar updated client/server examples that use Lua to implement the server instead of C, and also versions of both that run on a Propeller 1 equipped with suitable XMM RAM (such as the C3).
For SourceForge users, these updates will be included in the next release.
I've just pushed an update to the p2asm assembler to GitHub.
p2asm was not generating the same code as PNut or the Propeller Tool for LOC instructions below hub RAM location $400. The test file for this case was also incorrect and has been corrected, so p2asm now passes all its own verification tests.
This bug did not affect Catalina itself because Catalina never generates such LOC instructions, but it may have affected pure Propeller 2 PASM programs.
Catalina's time to compile a C "Hello, World" program when self-hosted on a P2 Edge with PSRAM is now under 3 minutes (2:50 best-case to be precise!). This is a long way from the first time I tried this, when even such a simple compile took more than 12 minutes. That was simply embarrassing!
I realize this is not a significant technical milestone, but it is an emotional one. Self-hosted Catalina now feels fast enough to be considered usable!
This latest improvement came partly from me finally being able to use the Catalina Optimizer on Catalina itself - the core of the compiler (rcc) comes in at 1.86Mb without optimization or 1.71Mb with optimization - but optimization does not just reduce the code size, it also speeds up execution (e.g. by automatically 'inlining' code where possible).
I finally found why the Optimizer was failing (and therefore had to be disabled) on big programs like Catalina itself or Lua - and it wasn't size alone, although that was one problem - there was an optimization case that I had simply missed which tended only to occur in very large programs, and which caused the Optimizer to crash and burn when it did.
This will be in the next release, along with a significant Cake update. Cake is going from strength to strength, particularly on C23 support. Soon, Cake may be the best C23 (and beyond) option available!
See the document BUILD.TXT for instructions on building Catalina on both Windows and Linux. Linux is pretty straightforward.
Ross.
sigh - Windows gets you every time
ansi_mode onor to disable it enter:
ansi mode offTo just check the current state enter:
ansi_modeNote that because this is a registry setting, you only have to do it once. I made it possible to turn it on or off in just case it upsets other programs that use the Console Host window.
Ross.
I've put up a new Patreon video about Catalina's new smart "dumb" mode - see here.
Ross.
Ross.
Ha! Found it!
Ross.
Catalina 8.8.4 has been released on GitHub and SourceForge.
New Functionality ----------------- 1. Payload now has a 'dumb' mode, which is enabled by using the -I option but specifying either "dumb" or "none" as the terminal name (e.g. -Idumb or -I none). In dumb mode (after download, if a file is also specified) payload just echoes all characters received on the serial port to stdout, and all characters received on stdin to the serial port. Dumb mode can be terminated by entering TWO consecutive CTRL-D characters. As the name implies, in dumb mode, payload does not do any character processing on either input or output characters (except for detecting two successive CTRL-D characters) - If the Propeller program does any terminal-dependent stuff (e.g. cursor movement, screen manipulation, applying colors etc) this will work if that capability is implemented by the terminal window in which payload is executing. In general, this means many things will work quite smoothly (in Windows) using cmd.exe, conhost or the terminal app, or (in Linux) in any window type derived from an xterm. On Windows, the keyboard is assumed to be an extended ASCII keyboard, and the keyboard input is mapped to that which would be generated by a terminal emulator operating in vt100 mode. This is done so that programs see the same keyboard input when -I dumb is specified as they would see if either -i or -I vt100 was specified. This makes both the Windows Console Host and Terminal App behave more like a real terminal emulator in vt100 mode when used with programs like Catalyst or the vi text editor. 2. A new batch file (ansi_mode.bat) is included to set or clear the registry setting that enables processing ANSI escape codes in the Console Host window (this is enabled by default in the Terminal App). To enable ANSI escape code processing in Console Host enter: ansi_mode on or to disable it enter: ansi mode off Note that the setting will only affect NEW Console Host Windows, not the current window. To just check the current state enter: ansi_mode Because this setting is in the registry, this only has to do be done once, not on each login, or each time a Console Host window is opened. It can be turned off again if it upsets other programs that use the Console Host window. Enabling ANSI mode makes the new 'dumb' terminal option offered by payload work correctly in a Console Host window. Otherwise ANSI escape codes (e.g. used by Catalyst) work in the Terminal App, but not Console Host. Other Changes ------------- 1. The vttest program, which is used to test vt100 compatibility, has been updated to the latest version. Note that this program is NOT required to use Catalina - it is a utility that can be used to test compatibility of various vt100 terminal emulators, including Catalina's terminal emulator (Comms.exe) as well as the Windows Console Host and Terminal App. See the README file in /source/comms/vttest for more details. 2. There were two problems in the build scripts in /source/geany_bundle: 1. The build_all script used the pacman cache. This only worked if the packages had already been downloaded. Now they are downloaded on each build. 2. The option to unpack compressed packages is now --zstd, not -xz Affected Windows only. 3. In the blackbox debugger, calls to the function blackbox_close() should have no parameters. This caused recent versions of gcc to throw an error. No functional changes. Affected Windows only. 4. In awka, the function awka_init_parachute() was being defined incorrectly in error.c to accept parameters. This causes the latest versions of gcc to throw an error. No functional changes. Affected Windows and Linux. 5. When compiling awka, the Catalina parallelizer and the Catalina optimizer with the latest version of gcc, the option -std=c99 must be added for the programs to compile correctly. No functional changes. Affected Windows and Linux. 6. When compiling lcc with the latest version of gcc, the definition of _spawnvp() must be changed to match that in stdio.h for the program to compile correctly. No functional changes. Affected Windows and Linux. 7. There is an issue with the current version of gcc/MinGW on Windows, which means that 'globbing' (expansion of wildcard characters on the command line was disabled by default. It can be manually re-enabled for programs that need it by including the following line near the top of the main program file: extern int _CRT_glob = 1; /* 0 turns off globbing; 1 turns it on */ No functional changes. Affected Windows only. 8. There is an issue with versions of gcc which reserve the keyword "constexpr", which was used by LCC as an identifier. This has now been changed in LCC to "cnstexpr". No functional changes. Affected Windows and Linux. 9. Non-C89 compatible comments in LCC (i.e. introduced using //) have now been replaced with C89-compatible comments (i.e. /* ... */). No functional changes. Affected Windows and Linux. 10. There is an issue in MinGW32 that means some programs may fail to compile with gcc when an old version of libwinpthread-1.dll exists in the PATH. An error message that "clock_gettime64" was not found is generated. The current fix is that "libwinpthread-1.dll" in Catalina's bin and catalina_geany/bin directories have been replaced with the latest version. However, in case this fix causes other problems, the old version are still included, but have been renamed to "libwinpthread-1.dll.old". Affected Windows only.Catalina 8.8.5 has been released on GitHub and SourceForge.
New Functionality ----------------- 1. Lua 5.5.0 has now been included in this release. However, Lua 5.5.X is not yet mature or stable enough to replace Catalina's fully integrated version, which remains at 5.4.X. However, Lua 5.5.0 is fully functional when used stand-alone, apart from the capabilities enabled by defining the ENABLE_PSRAM or ENABLE HYPER Catalina symbols when compiling Lua. Those capabilities are deeply embedded in the internals of Lua 5.4.X, were developed before the more general capability of using PSRAM as XMM RAM was added, and are deprecated in this release. They are likely to be dropped altogether in the next Catalina release. To build Lua 5.5.0, go to the folder demos\catalyst\lua-5.5.0 and use the build_all script in the same way as used to build Lua 5.4.X. For example: build_all P2_EDGE SIMPLE VT100 MHZ_200 OPTIMIZE To copy all the executables to an SD card, use the copy_all script. Note that this script will supersede any existing Lua binaries and programs on the SD Card. For example, if drive the SD Card is detected as drive H, the command to enter would be: copy_all h: 2. The version of Lua fully integrated into Catalina has been updated from version 5.4.4 to 5.4.8. There is no new Lua functionality in this update, just a few Lua bug fixes. However, there have been some minor tweaks to some example programs as a result, mainly the multi-processing with Lua examples. This is because the changes may not affect Lua's functionality, but they do sometimes affect Lua's memory utilization. The updated example programs now work with both Lua 5.4.X and Lua 5.5.X. Note that the compiled (i.e. binary) format of Lua programs has changed between versions 5.4.X and 5.5.X. This means that the corresponding version of the lua compiler (luac) must be used. If the wrong version is used, the following error message will be displayed: bad binary format (version mismatch) 3. There are now only two copies of the Lua 5.4.X source files in this release of Catalina (in previous releases there were three copies). The Lua source files that used to be in demos/catalyst/lua/5.4.X are now copied from source/catalina/lua-5.4.X when Catalyst is compiled using the build_all scripts, and deleted again by the clean_all scripts (similar to the way the self-hosted version of Catalina itself is built). Note that when the Windows installer is used to install Catalina, this means that to compile Catalyst from source, the Catalina sources MUST be installed. This option is now the default. A copy of the Lua 5.4.X source files still exists in the library source tree. This duplication is likely to remain so that the stand-alone version of Lua can be updated independently from the integrated version. Note that when Lua is built as part of Catalina (it is used for scripting in both payload and blackbox) the standard Lua Makefiles are used. When it is built as part of Catalyst, the Makefiles in the src folder are used (Makefile.Catalina on Linux, or Makefile.Catalina.mgw on Windows). 4. Partly in anticipation of Lua 5.5.X becoming Catalina's default integrated version of Lua, the multiple different versions of the Lua initialization file (variously called linit.c, iinit.c or xinit.c) which enabled different Lua libraries in previous releases have all been replaced with a common version (linit.c). In this release, this file must still be present and compiled in the same folder as the Lua application, but this will change in Lua 5.5.X, which uses a different initialization process). Specific libraries to be enabled or disabled are now specified on the Catalina command line (or in a catapult pragma) as follows: propeller always enabled hmi always enabled threads enabled by -lthreads serial enabled by -lserial2 or -lserial8 wifi enabled by -lwifi service enabled by -C LUA_SERVICE linenoise enabled by -C LUA_LINENOISE If memory is very tight, the optional debug, utf8 and os libraries can be disabled by -C LUA_NO_OPT, and if only integer math is required then the math library can be disabled by -C LUA_NO_MATH - but neither of these are used in any of the demo programs, and doing so is deprecated because these options will not be available when Lua 5.5.X becomes the default version of Lua. Other Changes ------------- 1. There was a bug in the Multiprocessing versions of Lua (i.e. mlua and mluax) that may have led to a program lock-up when multiple factories were in use (for example, it may have occurred when executing the example programs ex9.lua or ex12.lua). Affected the Propeller 2 only. 2. There was a bug in Catalyst that limited commands to 8 characters when no extension was specified. So (for example) the program "bin/dbasic.bin" would be correctly found and executed if the command was entered as: dbasic dbasic.bin bin/dbasic.bin but NOT if entered as: bin/dbasic Instead, "cannot open file BIN/DBASIC" would be displayed. Affected the Propeller 1 and Propeller 2. 3. Some Lua programs have been updated to allow for the use of either Lua 5.4 or Lua 5.5. In particular, Lua 5.5 requires different parameters to the collectgarbage() function. The following code takes the lua version into account, and can be used set a specific garbage collection mode and/or parameters in a way that is backwards compatible: lua_version = tonumber(string.sub(_VERSION, 5, 7)); if lua_version and lua_version < 5.4 then -- default mode is incremental, so just set parameters ... collectgarbage("setpause", 150); collectgarbage("setstepmul", 500); elseif lua_version and lua_version < 5.5 then -- incremental mode is optional, so set it with parameters ... collectgarbage("incremental", 150, 500); else -- mode and parameter setting now separate in Lua 5.5 ... collectgarbage("incremental"); collectgarbage("param", "pause", 150); collectgarbage("param", "stepmul", 500); end Affected the Propeller 1 and Propeller 2. 4. To minimize Lua's use of memory, the threads functions wait() and workers() also used to do garbage collection in previous releases - this was done to collect garbage after workers and threads had been initiated. However, a better solution is to do this explicitly if needed, and also for threads themselves to be able to perform garbage collection if required, so a new "thread safe" function for invoking the Lua garbage collector has been added to the threads module. The threads.gc() function can combine the functionality of collectgarbage() and threads.sbrk() (which are often used together to maximize free Lua memory and also defragment the C heap) into one function. See the updated "Lua on the Propeller 2 with Catalina" document for more details. The example program ex9.lua demonstrates the new function. If backwards compatibility is necessary, Lua code such as the following can be used to detect if the threads.gc() function is available or not: if threads.gc then threads.gc(1) -- also invokes sbrk(true) else -- note: not guaranteed thread safe ... collectgarbage() thread.sbrk(true) end Affected the Propeller 2 only. 5. Upgrading to Lua 5.4.8 has made some programs that used the integrated version of Lua (i.e. the version in the Catalina library) slightly larger, which may cause the program to run out of Hub RAM. For example, the Aloha WiFi RPC demo program sluarfx.c is now too large to execute correctly if compiled in NATIVE mode, and so has been replaced by the functionally identical program slaurcx.c which instead uses COMPACT mode. This change may affect other programs. Affected the Propeller 2 only. 6. The 'Aloha from Lua' document mentioned that the rpc_network table could be in the common.lua module, but in the RPC demo programs the table was instead duplicated in the server.lua, remote.lua and serverbg.lua modules. While this is technically ok, it complicates the process of configuring the demo programs. Now, the document and all the demo programs have been made consistent, with only one copy of the rpc_service table in the common.lua module. Affected the Propeller 2 only. 7. There were a couple of issues with the WiFi version of ALOHA: (a) There was an undocumented limitation on the size of an WiFi RPC request. The code currently limits such requests to a maximum of 512 bytes (the RPC response can be larger). This limit caused one of the demo programs (i.e. the 'complete' demo) to work with the serial version, but not the WiFi version because the string used was too long. The example has now been corrected to work with both, and the 'ALOHA from Lua' document also has been updated. This limit may be increased in a future release. (b) The Lua dispatcher could fail to retrieve all data returned by an RPC call when the response consisted of multiple data packets. Affected the Propeller 2 only.I just pushed an update to Catalina's ENABLE_HYPER and ENABLE_PSRAM Lua options to github.
Or (on Linux):
Ross.
t = threads -- we want four simultaneous threads t.workers(4) -- here is how we will identify them, which -- is also a string for each one to output eeny = "eeny " meeny = "meeny " miney = "miney " mo = "mo\n" -- we need four condition variables -- (one for each thread) t.condition(eeny) t.condition(meeny) t.condition(miney) t.condition(mo) -- generate a thread function function Thread(me, next, count, last) return function() t = threads repeat t.lock(me) t.update(me, true) t.wait(me) t.update(me, false) t.unlock(me) t.output(me) count = count - 1 if (count > 0) or not last then next_ready = false while not next_ready do t.lock(next) next_ready = t.shared(next) t.unlock(next) end t.signal(next) end until count == 0 end end -- wait till a thread is "ready" -- (i.e. waiting on its condition variable) function wait_till_ready(this) local this_ready = false while not this_ready do t.lock(this) this_ready = t.shared(this) t.unlock(this) end return this_ready end count = 20 -- create the threads t.new(Thread(eeny, meeny, count, false)) t.new(Thread(meeny, miney, count, false)) t.new(Thread(miney, mo, count, false)) t.new(Thread(mo, eeny, count, true)) -- wait till eeny is "ready" wait_till_ready(eeny) -- kick things off t.signal(eeny) -- wait for threads to complete t.wait()This version is now on GitHub, along with an updated description in the Lua on the Propeller 2 with Catalina document.
Ross.
For example:
What this does is guarantee that the "condition" (represented here by the shared variable "next") is not in the process of changing when you access it - i.e. the lock ensures that any change is completed before you are given access (your process is stalled if required until this is true). That's all that's needed - but without that you can (in this instance) retrieve a "condition" of true when in fact it is not yet true, but will be almost immediately afterwards. This is a classic race condition! - if the thread execution is interleaved at exactly the wrong instant, you are in fact working with the wrong information, and the result is usually a deadlock!
Catalina 8.8.6 has been released on GitHub and SourceForge.
New Functionality ----------------- 1. If a compiled version of a Lua module exists, it is now loaded in preference to the uncompiled version - e.g. given 'require "module"' Lua will now try to load "module.lux" and load it if it exists, otherwise it will try "module.lua". The full search path is now: ?.lux; ?.lua; ?/init.lux; ?/init.lua; lua/?.lux; lua/?.lua; lua/?/init.lux; lua/?/init.lua This search path can be set using the environment variable LUA_PATH, so to revert to the previous behaviour use the Catalyst command: set LUA_PATH="?.lua;?/init.lua;lua/?.lua;lua/?/init.lua" 2. When the Catalyst pre-built demos are built for a Propeller 2 platform with XMM RAM (i.e. the P2_EDGE or P2_EVAL) then eLua is now also built (i.e. elua, elaux, eluafx, eluas, eluasx). An eLua demo of the Game of Life is also copied into the folder 'life'. See the file life/README.TXT for details on executing this demo. In particular, note that 'exec life/rebuild' must be executed before the demo can be executed. 3. The catapult and elua/ALOHA demos now allow fixed length path names of up to 128 bytes instead of just a DOS 8.3 file name. This allows eLua/ALOHA programs to be put into folders. The pre-built demos for the Propeller 2 now contain an example of doing this - i.e. the Game of Life eLua demo in folder 'life'. Other Changes ------------- 1. The build scripts for the P2_EDGE and P2_EVAL Catalyst demos were building cake to use a serial HMI even when compiling the VGA demos. Affected the Propeller 2 only. 2. There were issues with catapult programs that accepted command line arguments. The size and number of arguments could change the memory addresses allocated in the program, requiring it to be recompiled in each case. This has now been fixed by the addition of a new Catalina option -C FIXED_ARGS, which forces the program to always allocate the maximum possible number of bytes for command line arguments even if none were specified or supported. In cases where no command line argument support is required, This can be disabled using the existing option -C NO_ARGS. Affected the Propeller 2 only. 3. Several of the catapult demos, including the ALOHA demos, were allocating hub RAM for file names BEFORE allocating the catapult memory buffers, which meant that the buffer addresses could change depending on the command-line arguments. All the demos now always allocate a fixed amount of Hub RAM to hold the file names so that the catapult buffers will always have the same addresses. Affected the Propeller 2 only. 4. Updated the 'Aloha from Lua' document to match the current version of the Lua initialization file (linit.c). 5. It was possible for the Serial ALOHA protocol to overrun the serial buffers in the case of large messages. Now a delay has been added when transmitting (defaults to 5ms every 16 characters, but it can be adjusted in aloha.c). 6. Recent Lua updates have changed the size of Lua executables, and hence the size of Lua programs that can be executed from Hub RAM. The 'Game of Life' eLua demo is now too large to be executed with 'sluafx', but since it does not need floating point it can still be executed using 'sluafix'. The 'Aloha from Lua' document has been updated accordingly. 7. Removed all "just update version number" type comments - they served no useful purpose and just consumed space (especially in Lua scripts). 8. Use $* in place of $1 $2 $3 ... $9 and %* in place of %1 %2 %3 .. %9 wherever it is feasible to do so. This is necessary because Catalina now has so many symbols that may need to be defined on a command line (usually in scripts) it is now possible that more than 9 parameters need to be specified.While Linux users can easily rebuild Catalina from source, building Catalina on Windows is still such a painful process that I don't expect anyone but me ever bothers doing it. I am also sure most Windows users use the installer rather than cloning GitHub, so I have decided to simplify things by just including the Windows installer as a GitHub asset, instead of re-bundling the Windows binaries separately (I also realized I had made some silly mistakes in these bundles in the past, whereas the Windows installer is pretty thoroughly tested before each release).
Ross.
Ross.
As discussed in this thread, attached is a zip file containing the coremark benchmarking program ported to Catalina.
Unzip it into a directory such as demos/coremark and see the file CATALINA.TXT for more details.
Ross.
catalina -C99 -lc -Imy_includes program.cI've just posted a Catapult update to GitHub. The purpose of the update is to simplify the creation of C and Lua client/server applications. There are no changes to Catalina itself.
#pragma catapult serviceand#pragma catapult service_list- that create and configure all the necessary proxy functions automatically.It is still possible to do this manually (which means existing Catapult programs will still work) but using the new pragmas simplifies the program, eliminates a possible source of error, and permits client/server applications to be compiled monolithically (i.e. as simple linear programs, not multi-model programs). C programs can also be executed when compiled monolithically, but Lua programs cannot (because the Lua server is expecting to run on a separate cog).
#pragma catapult common options(-W-w -p2 -C P2_EDGE -C SIMPLE -C NO_ARGS -lc -lmc) /****************************************************************************** * Using Catapult to build a C server. * * * * This program demonstrates executing a primary server from XMM RAM that * * dispatches service calls made from one or more C secondary clients to * * C functions implemented in the primary server (i.e. from XMM RAM). * * * * The program uses the Catalina Registry as the mechanism, which enables * * the server to offer multiple services, and also adds lock protection to * * the services. Using the registry supports only a limited number of * * parameter profiles - i.e. those that are required to implement Catalina * * plugins (see func_1 to func_5). However, the basic "short" service can * * also be used to pass a pointer to the shared data structure as the * * parameter, which allows for arbitary data to be exchanged between client * * and server, as usual for catapult programs (see func_6). * * * * This version is for a Propeller 2 P2_EDGE with PSRAM (i.e. a P2-EC32MB). * * * * Compile this program with a command like: * * * * catapult srv_c_p2.c * * * * Before loading, execute 'build_utilities' to build the appropriate XMM * * loader (for a P2_EDGE with PSRAM and an 8K cache), and then load and * * execute the program with a command like: * * * * payload -o2 -i XMM srv_c_p2 * * * * Note that if you modify the program, you may have to modify the address * * specified in the secondary pragma - but the program will tell you what * * address to use when you compile and execute it. * * * * This program can also be compiled 'monolitically' (i.e. without catapult) * * and then executed using commands like: * * * * catalina -p2 -CP2_EDGE -lc -lm srv_c_p2.c * * payload -o2 -i srv_c_p2 * * * * See the document 'Getting Started with Catapult' for details. * * * ******************************************************************************/ #include <catapult.h> #include <service.h> #include <stdlib.h> /* * Define a type to be used for exchanging data between the client and server. * The 'ready' and 'start' fields are used to ensure the client does not start * till the server is ready. */ typedef struct shared_data { int ready; int start; int data; } shared_data_t; /* * Forward declare the client function (so the server can start it) */ void hub_client(shared_data_t *s); #pragma catapult primary binary(srv_c_p2) mode(XMM) /****************************************************************************** * * * The server (primary) - loads the client, then executes a C dispatcher, * * dispatching calls to the C functions specified in my_service_list * * * ******************************************************************************/ /* * Define the C functions implemented by the server - note the use of * '#pragma catapult service' to identify functions that need to have * proxy functions created for clients to call. */ #pragma catapult service func_1 type(short) int func_1(long l) { // example SHORT_SVC t_printf("Hello, World (from C func_1!)\n"); t_printf("Args: l=%ld\n", l); return l + 1; } #pragma catapult service func_2 type(long) int func_2(long l) { // example LONG_SVC t_printf("Hello, World (from C func_2!)\n"); t_printf("Args: l=%ld\n", l); return l + 2; } #pragma catapult service func_3 type(long_2) int func_3(long l1, long l2) { // example LONG_2_SVC t_printf("Hello, World (from C func_3!)\n"); t_printf("Args: l1=%ld, l2=%ld\n", l1, l2); return l1 + l2 + 3; } #pragma catapult service func_4 type(float) float func_4(float f1, float f2) { // example FLOAT_SVC t_printf("Hello, World (from C func_4!)\n"); t_printf("Args: f1=%f, f2=%f\n", f1, f2); return f1 + f2 + 4; } #pragma catapult service func_5 type(long_float) long func_5(float f1, float f2) { // example LONG_FLOAT_SVC t_printf("Hello, World (from C func_5!)\n"); t_printf("Args: f1=%f, f2=%f\n", f1, f2); return (long)(f1 + f2) + 5; } #pragma catapult service func_6 type(shared) long func_6(shared_data_t *shared) { // example SHARED_SVC t_printf("Hello, World (from C func_6!)\n"); shared->data++; return shared->data; } /* * Define a service list to use for dispatching calls to the server. * We can autofill the list by using #pragma catapult service_list, * specifying type C. Note that the list must be terminated with * a null entry -i.e. {"", NULL, 0} */ svc_list_t my_service_list = { #pragma catapult service_list type(C) {"", NULL, 0} }; /* * the main function does all the initialization */ void main() { shared_data_t shared = { 0, 0, 0 }; int cog; // re-register this cog as a server (it will already // be registered, but as a kernel, not a server) _register_plugin(_cogid(), LMM_SVR); // register the services, so clients can find them _register_services(_locknew(), my_service_list); // load the client function - it will wait for the // 'start' field of the shared_data argument to be set RESERVE_AND_START(hub_client, shared, ANY_COG, cog); #ifdef __CATAPULTED // wait for the client to be ready (required if the client // prints messages, to prevent garbled output, and only if we // have been processed by Catapult, otherwise this blocks!) while (!shared.ready); #endif // the server is ready - start the client t_printf("Server ready - press a key to begin ...\n"); k_wait(); shared.start = 1; // dispatch calls made to the services in my_service_list DISPATCH_C(my_service_list); } #pragma catapult secondary hub_client(shared_data_t) address(0x77178) mode(NMM) stack(500) /****************************************************************************** * * * The client (secondary) - calls services provided by the server (primary) * * * ******************************************************************************/ void hub_client(shared_data_t *s) { int i = 0; long l = 0; float f = 0.0; t_printf("Client ready - press a key to start the server ...\n"); k_wait(); // tell the server we are ready s->ready = 1; #ifdef __CATAPULTED // wait till we are told to start by the server before proceeding // (only if we have been processed by Catapult, otherwise this blocks!) while (s->start == 0); #endif t_printf("The client calls from cog %d ...\n", _cogid()); t_printf("... to the server on cog %d\n", _locate_plugin(LMM_SVR)); // call the services ... while(1) { t_printf("\nPress a key to continue ...\n"); k_wait(); i = func_1(1000); t_printf("result of func_1 = %d\n", i); i = func_2(2000); t_printf("result of func_2 = %d\n", i); i = func_3(3000, 4000); t_printf("result of func_3 = %d\n", i); f = func_4(5000.0, 6000.0); t_printf("result of func_4 = %f\n", f); l = func_5(7000.0, 8000.0); t_printf("result of func_5 = %ld\n", l); i = func_6(s); t_printf("result of func_6 = %d\n", i); } }The Getting Started with Catapult document has been updated and is also on GitHub, along with similar updated client/server examples that use Lua to implement the server instead of C, and also versions of both that run on a Propeller 1 equipped with suitable XMM RAM (such as the C3).
Ross.
Ross.
Ha! Catalina breaks the 3 minute barrier!
Ross.
