Saving P2 program state when the power goes off?
bob_g4bby
Very often, the state of a P2 based module requires saving at switch-off and restoring at switch on. We have several good libraries for flash or sd card file management now. However, that begs the question - how to save those critical project variables with the least amount of effort? Saving individual variables would seem to be more work than saving one structure of variables. A smartpin can be made to monitor the unregulated power voltage and the capacitor across the regulated supply ensures there's enough time to save and close the file before the P2 stops. Any hints and tips?
Cheers, bob
Interesting question ….
Maybe save entire hub to nonvolatile every so often and restore if reboot detected ?
That’d be easy but not sure if would be ok
If these "variables" don't change much and are acting more like configuration settings then possibly keep them stored in some i2c or SPI accessible NVRAM / EEPROM to begin with and read them back into RAM at run time and update the NVRAM whenever they change. If they change too much then the device may start to wear however, depending on the HW chosen.
If it’s just a few bytes., some new i2c rtc have user ram…
