Ok so I found the culprit. I've written a program (years ago) that opens the serial port and just prints out what it reads. I call it stail for serial tail. And this detects when the propeller is being programmed, and shuts down the serial port so the loadp2 can do it's work, waits a second and tries to re-open the port.
And it appears that has changed its behavior, possibly my new underlying Linux or something. After fiddling with it, I don't seem to suffer from this stray reset. And guess what, the not-working.spin2 happens to work.
DIEZ 2026-02-01: sx1268_init:0
sx1268-send-test: 0
Lora1: sx1268: start send test.
Lora1: sx1268: chip is busy.
Lora1: sx1268: set standby failed.
sx1268-send-test:failed
VAR
long position
long timeStamp
PUB GetPosition (): pos | p, t, ct, dt, v, h
p:= @position
ORG
setq #1 ' atomic read of p+t
rdlong p,p
END
ct:= getct ()
position and timeStamp are written by another cog. I assumed that p and t are consecutive registers which are later used in another assembler inline section. I think Chip used tricks like this in P1 Spin a lot which relied on the order of stack parameters and local variable in memory. But in P1 Spin those were in hub RAM, not cog RAM. The problem is that FlexSpin assigns registers in the order the variables appear in the code of the function, not in the list of local variables in the header. So _var01 is allocated to p and _var02 to ct instead of t.
I know this is not a bug. It was never promised to work, just my optimistic assumption. But is there a way to make it work? If I do
p:= position
t:= timeStamp
instead my code works but, of course, the access to p and t is not atomic. SETQ + RDLONG is a nice way to avoid locks and delays.
Easiest would be to add {++opt(!fast-inline-asm)} between PUB/PRI and the function name. That'll force it to do the whole interpreter-style variable copy (slow and nasty) for ORG/END sections.
But I think if the variable you read into is a quad, array or structure, it will always place that in consecutive registers, so try that first.
If those locals are exclusively Pasm used then move them into a group of labelled RES's at end of ORG section.
VAR
long position
long timeStamp
PUB GetPosition (): pos | ct, dt, v, h
ct:= @position
ORG
rdlong p,ct
ret
p res 1
t res 1
END
ct:= getct ()
Eric,
Looks like a regression in the includes at some point. The newer _sdmm_open() base function, used by _vfs_open_sdcardx(), for starting up Flexspin's built-in SD driver is not declared anywhere now. I've previously been directly using this function due to its compatibility with the external driver plug-in mechanism. To get it in scope now, I place the following line in my top source file:
vfs_file_t *_sdmm_open(int pclk, int pss, int pdi, int pdo) _IMPL("filesys/block/sdmm_vfs.c");
I didn't know that I can declare local array variables, so far. But I tried and it seems to work.
PUB GetPosition (): pos | p[2], t, ct, dt, v, h
p:= @position
ORG
rdlong p,p
END
t:= p[1]
ct:= getct ()
@evanh Your idea is also good but unfortunatelly doesn't work in my case. I have a second inline assembler section after some calculations in Spin2 and I couldn't acess the p and t res 1 variables from the second section. Ok, it would work with some additional copy instructions but is way more complicated than the solution above. But thanks, anyway.
@evanh said:
I'd never have two Pasm sections split. That's double dipping on the Fcache overheads. I sure hope there's a damn good reason not to just merge them.
Yeah, you're absolutely right. I could translate the Spin code between the two assembler sections to assembler, too. I kept it because it was easier to debug and also for historical reasons. This was a P1 program, once. I've ported it to the P2 and added the 64 bit arithmetic later.
p:= @position
ORG
rdlong p,p
END
t:= p[1]
ct:= getct ()
dt:= ct - lastTime
if p <> lastPos ' position changed?
last2Pos:= lastPos
last2Time:= lastTime
lastPos:= p
lastTime:= t
elseif dt > maxPeriod ' < min. speed
last2Pos:= p ' force v=0
lastTime:= ct - maxPeriod
last2Time:= lastTime - maxPeriod ' avoid timer overflow
else
lastTime:= t ' update in the case dithering changed t
' v:= (lastPos - last2Pos) * cycleTime / (lastTime - last2Time)
' pos:= lastPos + v*dt / cycleTime
p:= lastPos - last2pos
t:= lastTime - last2Time
ct:= cycleTime
ORG ' use 64 bit arithmetic because v*dt or p*cycleTime could be >2^31
abs p wc
qmul p,ct ' (lastPos - last2Pos) * cycleTime
getqx p
getqy h
setq h
qdiv p,t ' / (lastTime - last2Time)
getqx v
qmul v,dt ' * dt
getqx v
getqy h
setq h
qdiv v,ct ' / cycleTime
getqx p
negc p
END
pos:= lastPos + p
@evanh said:
Eric,
I don't think that function was ever declared in header files, it was probably getting dragged in as a side effect of something else. Anyway, I've added an explicit declaration now. Thanks for catching this.
Yes, that should work. So should structures, but if you're directly manipulating elements in assembly language using an array might be clearer.
Remember, I separated out some of the SDMM stuff because it was getting compiled in and bloating binaries even when using an external block driver (SDSD). I think dead code elimination doesn't work well for functions that are referred to by function pointers somewhere.
Right, but I don't think just declaring the function should cause any issues. I looked at your patch that did the re-arrangement, and I don't think sdmm_open was declared before that either (unless I missed something).
@ManAtWork said:
I've just tried to recompile some code I've written in 2022. IIRC it worked back then and didn't throw any error messages. But now I get
Ok, I can use __asm const. But "improving" the optimization leads to breaking code that has worked, before.
Pipelined CORDIC operations were never guaranteed to work in non const/volatile context because the compiler is free to delete/add/move instructions, since the semantics of pipelined operations depend on exact timing (i.e. if the result window is missed, an instruction is skipped). This is too difficult to deal with, so CORDIC-related IR transformations are created with the assumption of a single operation in flight at a time. Removing a QMUL when there's no associated GETQX (e.g. has been removed by dead code pass) is necessary for correctness (this was actually causing bugs at some point).
Ok, this is true for compiler generated code where optimization and dead code removal makes sense. But if I'm pretty sure that my assembler code is already highly optimized I think it's safer to just use __asm const all the time, right? Or could you imagine a case where this causes problems?
const and volatile are generally a good thing to use when you're crafting it to the hardware. Leaving them out is you saying you're happy to have the optimiser rearrange things.
Basically, for the code you showed, use __asm const or __asm volatile (if you expect it to loop often).
Using __asm const prevents the compiler from modifying the insides of the block at all (except for register allocation) and can cause missed optimizations around the block, too. If you're just writing a quick couple of instructions that would be hard to express in C in the middle of a function, the plain __asm block is better.
random example pulled from a project:
#ifdef __propeller2__
__asm {
sub bc,#1
testb d,bc wc
bmask bc
if_nc sub d,bc
#else
bc = 1 << (bc - 1); /* MSB position */
if (!(d & bc)) d -= (bc << 1) - 1; /* Restore negative value if needed */
#endif
A lot of the compiler's builtin functions are also implemented using this. For example the 64 bit compare:
' compare signed alo, ahi, return -1, 0, or +1
pri _int64_cmps(alo, ahi, blo, bhi) : r
asm
cmp alo, blo wc,wz
cmpsx ahi, bhi wc,wz
if_z mov r, #0
if_nz negc r, #1
endasm
If the input values are constants, they can be propagated through the code.
To recap:
Spin syntax
C syntax
does what
ASM / ENDASM
__asm {}
Treated the same as compiler-generated instructions
ORGH/END
__asm const {}
Instructions can not be modified by optimizer (thus typically assemble as-is into hub RAM)
ORG/END
__asm volatile {}
Block is copied into cog RAM before executing, can not be modified by optimizer)
I'm not sure if this was added a long time ago and I just never noticed, or if it was really recently added (I don't look at the P(2)ASM output for most things), but this:
annotating the PASM output with the original spin code is great, so thanks heaps for adding it! It really helps identify more at-a-glance "what" is being compiled to "what." I'd considered asking awhile back if it'd be possible to name the regs used more closely to the original spin locals, but this makes it much easier to trace.
It has always been there I think. I can see old compiles I still have, sitting in dark corners, from 2021, producing it.
EDIT: Ah, found a 2020 dated compile that doesn't have it.
EDIT2: Sept 2020 compile has it. 2019 compiles didn't produce a .p2asm by default.
Wow...I don't know how I never noticed it...again I don't use the pasm output much, but still...
EDIT: Ah ok I see why - I don't have -l in my editor's build task. I was using FlexProp in this particular case for the DEBUG output and it has that flag enabled by default.
I couldn't immediately remember the compiled source comments either, to be honest. But when I looked up one of my efforts I realised I'd been using them to double check where I looked in the assembly on those occasions I did check things.
stailfor serial tail. And this detects when the propeller is being programmed, and shuts down the serial port so the loadp2 can do it's work, waits a second and tries to re-open the port.And it appears that has changed its behavior, possibly my new underlying Linux or something. After fiddling with it, I don't seem to suffer from this stray reset. And guess what, the not-working.spin2 happens to work.
So more investigation needed.
I just tried this:
VAR long position long timeStamp PUB GetPosition (): pos | p, t, ct, dt, v, h p:= @position ORG setq #1 ' atomic read of p+t rdlong p,p END ct:= getct () ...position and timeStamp are written by another cog. I assumed that p and t are consecutive registers which are later used in another assembler inline section. I think Chip used tricks like this in P1 Spin a lot which relied on the order of stack parameters and local variable in memory. But in P1 Spin those were in hub RAM, not cog RAM. The problem is that FlexSpin assigns registers in the order the variables appear in the code of the function, not in the list of local variables in the header. So _var01 is allocated to p and _var02 to ct instead of t.
{++opt(!fast-inline-asm)}between PUB/PRI and the function name. That'll force it to do the whole interpreter-style variable copy (slow and nasty) for ORG/END sections.But I think if the variable you read into is a quad, array or structure, it will always place that in consecutive registers, so try that first.
VAR long position long timeStamp PUB GetPosition (): pos | ct, dt, v, h ct:= @position ORG setq #1 ' atomic read of p+t rdlong p,ct ... ret p res 1 t res 1 END ct:= getct ()Eric,
vfs_file_t *_sdmm_open(int pclk, int pss, int pdi, int pdo) _IMPL("filesys/block/sdmm_vfs.c");I didn't know that I can declare local array variables, so far. But I tried and it seems to work.
PUB GetPosition (): pos | p[2], t, ct, dt, v, h p:= @position ORG setq #1 ' atomic read of p+t rdlong p,p END t:= p[1] ct:= getct ()@evanh Your idea is also good but unfortunatelly doesn't work in my case. I have a second inline assembler section after some calculations in Spin2 and I couldn't acess the p and t res 1 variables from the second section. Ok, it would work with some additional copy instructions but is way more complicated than the solution above. But thanks, anyway.
PUB GetPosition (): pos | p[2], t, ct, dt, v, h p:= @position ORG setq #1 ' atomic read of p+t rdlong p,p END t:= p[1] ct:= getct () dt:= ct - lastTime if p <> lastPos ' position changed? last2Pos:= lastPos last2Time:= lastTime lastPos:= p lastTime:= t elseif dt > maxPeriod ' < min. speed last2Pos:= p ' force v=0 lastTime:= ct - maxPeriod last2Time:= lastTime - maxPeriod ' avoid timer overflow else lastTime:= t ' update in the case dithering changed t ' v:= (lastPos - last2Pos) * cycleTime / (lastTime - last2Time) ' pos:= lastPos + v*dt / cycleTime p:= lastPos - last2pos t:= lastTime - last2Time ct:= cycleTime ORG ' use 64 bit arithmetic because v*dt or p*cycleTime could be >2^31 abs p wc qmul p,ct ' (lastPos - last2Pos) * cycleTime getqx p getqy h setq h qdiv p,t ' / (lastTime - last2Time) getqx v qmul v,dt ' * dt getqx v getqy h setq h qdiv v,ct ' / cycleTime getqx p negc p END pos:= lastPos + pI don't think that function was ever declared in header files, it was probably getting dragged in as a side effect of something else. Anyway, I've added an explicit declaration now. Thanks for catching this.
I don't think
struct vfswas a good choice.Oops yes, thanks. I've pushed an update.
void BackpropAsm (AxisBuffEntry* buffer, int wri, int rdi) { uint32_t dlo = 0; uint32_t dhi = 0; uint32_t v2lo = halfAcc2; uint32_t v2hi = 0; fixp30_t v1, vMax; uint32_t* ptr; uint32_t hA = halfAcc; uint32_t nA = nomAcc; uint32_t mlo, mhi; __asm{ .loop decmod wri,#AXIS_BUFFER_SIZE-1 mov ptr,wri shl ptr,#6 add ptr,buffer add ptr,#40 // v1= buffer[i].vNom rdlong v1,ptr mov vMax,hA add vMax,v1 qmul vMax,vMax // vMax² // <- here, line 290 add dlo,v1 wc addx dhi,#0 qmul v1,nA // v1 * nomAcc add ptr,#8 setq #2-1 wrlong dlo,ptr // buffer[i].dDec= dist getqx mlo getqy mhi shr mlo,#30 mov v1,mhi shl v1,#2 shr mhi,#30 or mlo,v1 cmp v2lo,mlo wcz // if (v2 > vMax²) break cmpx v2hi,mhi wcz getqx mlo getqy mhi if_a jmp #.break mov v1,mlo shl mhi,#3 shl mlo,#3 shr v1,#32-3 or mhi,v1 add v2lo,mlo wc // v2+= (v1 * nomAcc) * 8 addx v2hi,mhi cmp wri,rdi wz if_nz jmp #.loop .break } }Ok, I can use
__asm const. But "improving" the optimization leads to breaking code that has worked, before.Pipelined CORDIC operations were never guaranteed to work in non const/volatile context because the compiler is free to delete/add/move instructions, since the semantics of pipelined operations depend on exact timing (i.e. if the result window is missed, an instruction is skipped). This is too difficult to deal with, so CORDIC-related IR transformations are created with the assumption of a single operation in flight at a time. Removing a QMUL when there's no associated GETQX (e.g. has been removed by dead code pass) is necessary for correctness (this was actually causing bugs at some point).
__asm constall the time, right? Or could you imagine a case where this causes problems?constandvolatileare generally a good thing to use when you're crafting it to the hardware. Leaving them out is you saying you're happy to have the optimiser rearrange things.Basically, for the code you showed, use
__asm constor__asm volatile(if you expect it to loop often).Using
__asm constprevents the compiler from modifying the insides of the block at all (except for register allocation) and can cause missed optimizations around the block, too. If you're just writing a quick couple of instructions that would be hard to express in C in the middle of a function, the plain__asmblock is better.random example pulled from a project:
#ifdef __propeller2__ __asm { sub bc,#1 testb d,bc wc bmask bc if_nc sub d,bc } #else bc = 1 << (bc - 1); /* MSB position */ if (!(d & bc)) d -= (bc << 1) - 1; /* Restore negative value if needed */ #endifA lot of the compiler's builtin functions are also implemented using this. For example the 64 bit compare:
' compare signed alo, ahi, return -1, 0, or +1 pri _int64_cmps(alo, ahi, blo, bhi) : r asm cmp alo, blo wc,wz cmpsx ahi, bhi wc,wz if_z mov r, #0 if_nz negc r, #1 endasmIf the input values are constants, they can be propagated through the code.
To recap:
' pub main() | v, smp _main ' ' smp := 0 ' repeat MAX_V with v mov _var01, #0 callpa #(@LR__0002-@LR__0001)>>2,fcache_load_ptr_ LR__0001 ' smp += vts[v].sample add _var01, #1 cmps _var01, #64 wcannotating the PASM output with the original spin code is great, so thanks heaps for adding it! It really helps identify more at-a-glance "what" is being compiled to "what." I'd considered asking awhile back if it'd be possible to name the regs used more closely to the original spin locals, but this makes it much easier to trace.
Cheers
-lin my editor's build task. I was using FlexProp in this particular case for the DEBUG output and it has that flag enabled by default.I couldn't immediately remember the compiled source comments either, to be honest. But when I looked up one of my efforts I realised I'd been using them to double check where I looked in the assembly on those occasions I did check things.
