Looking for a way to save AUDS/AUGD/SETQ state - Page 3 — Parallax Forums
13»
  • roglohrogloh Posts: 6,268
    edited 2026-03-01 06:57
    Just did the real run from PSRAM test using P2-EVAL and my own PSRAM board at 160MHz. Only made a small improvement in the total tick count but that's to be expected given the number of iterations and the fact that only 31 rows are ever loaded.
    Worked first go which is great but almost makes me believe it's not real. Now want to intentionally impair PSRAM to ensure it's legit. Will just yank the breakout board out for that. UPDATE: yep crashed right away with the board removed. So it's loading the code from the PSRAM now! :smiley:
    2K performance run parameters for coremark.
    CoreMark Size    : 666
    Total ticks      : 1853091552
    Total time (secs): 11
    Iterations/Sec   : 18
    Iterations       : 200
  • RossHRossH Posts: 5,717
    @roghloh
    160MHz is just the default for flexspin C .
    I thought the P2 was originally designed for a maximum 180Mhz clock speed, although it has since shown it can generally go much, much faster. For myself I tend to use 200Mhz, but Catalina's default is 180Mhz, because I thought that was still the design maximum. If there is now a reason to make the default slower than that, I'd like to know it.
    Haven't considered it yet but in theory multiple COGs running from external memory could each have their own I-caches and share a common external memory, with a commensurate reduction in performance. The main limitation here is that this model doesn't keep directly accessed data in the external RAM, just code,
    That would be analogous to Catalina's SMALL mode, which only stores code in external RAM (as opposed to LARGE mode is where both code and data are stored in external RAM). But even multi-processing in SMALL mode would be a huge win. My biggest problem is that I always tried to keep Catalina compatible with both the P1 and the P2, which I have (just about!) managed. But that is largely just nostalgia on my part - I have really fond memories of the P1, but I knew one day this compatibility would probably have to come to an end.
    I will follow progress with interest :)
    @RossH said:
    @roghloh
    There's no reason for that IMO, 160MHz is just what flexspin had setup as the default from way back.
    I think it's probably doable to have multiple COGs sharing the external RAM for their code (or even run different code as separate applications). Right now for this proof of concept setup I init an I-cache and block mapping table at startup time in another linked module called extmem.c whose addresses I pass into the COG external memory handler routines executed from LUTRAM during startup. The only change needed would be to not have this as defined a global variable block but allocated on a per COG stack instead via alloca in main() or something like that. I'm running the cache transfer requests through my external memory mailbox so other COGs can certainly make other requests in parallel to the COG executing external C routines. I can easily already prove that out to myself by introducing another video COG which shares the memory but I know it would work, just slower.
  • evanhevanh Posts: 17,128
    Probably originates from the Prop2-Hot days. Its design was targetted for 160 MHz I think.
    Now I have something functioning running via external memory and a cache, I was wondering about some of the potential target applications that might work with a larger memory model on a P2. I wonder if flexspin/spin2cpp could be setup to compile itself as a P2 application or whether the small 512k of HUBRAM for data would be a major limitation. This is assuming most/all of the executable code is stored externally with say a 64kB I-cache and (say) a 16-32kB block mapping table and some required library and filesystem APIs are present leaving up to 436kB or so for data. Flexspin on my Mac is only a 2.8MB executable so with any luck it might still compile to fit within some 16MB external address space (PSRAM) on a P2. I guess there would be some native OS and memory management APIs used that would need to be ported/provided on a P2 but it's more of whether it could be made to compile with much less available RAM for data that I'd be concerned about.
    Is there any scope for something like this or is it a fools errand even considering the idea compiling flexspin source from itself, especially without a linker?
    Output of make for building spin2cpp etc is shown below. It has dependencies on bison and builds each module separately before final link step.
    bison -p spinyy -t -b build/spin -d frontends/spin/spin.y
    bison -p basicyy -t -b build/basic -d frontends/basic/basic.y
    bison -p cgramyy -t -b build/cgram -d frontends/c/cgram.y
    frontends/c/cgram.y: conflicts: 5 shift/reduce
    gcc -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/lexer.o -c frontends/lexer.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/uni2sjis.o -c frontends/uni2sjis.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/symbol.o -c symbol.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/ast.o -c ast.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/expr.o -c expr.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/dofmt.o -c util/dofmt.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/flexbuf.o -c util/flexbuf.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/lltoa_prec.o -c util/lltoa_prec.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/strupr.o -c util/strupr.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/strrev.o -c util/strrev.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/strdupcat.o -c util/strdupcat.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/to_utf8.o -c util/to_utf8.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/from_utf8.o -c util/from_utf8.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/sha256.o -c util/sha256.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/softcordic.o -c util/softcordic.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/preprocess.o -c preprocess.c
    gcc -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/testlex testlex.c build/lexer.o build/uni2sjis.o build/symbol.o build/ast.o build/expr.o build/dofmt.o build/flexbuf.o build/lltoa_prec.o build/strupr.o build/strrev.o build/strdupcat.o build/to_utf8.o build/from_utf8.o build/sha256.o build/softcordic.o build/preprocess.o -lm
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/common.o -c frontends/common.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/case.o -c frontends/case.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/spinc.o -c spinc.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/functions.o -c functions.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/cse.o -c cse.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/loops.o -c loops.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/hloptimize.o -c frontends/hloptimize.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/hltransform.o -c frontends/hltransform.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/types.o -c frontends/types.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/pasm.o -c pasm.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/outdat.o -c backends/dat/outdat.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/outlst.o -c backends/dat/outlst.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/outobj.o -c backends/objfile/outobj.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/spinlang.o -c frontends/spin/spinlang.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/basiclang.o -c frontends/basic/basiclang.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/clang.o -c frontends/c/clang.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/bflang.o -c frontends/bf/bflang.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/outasm.o -c backends/asm/outasm.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/assemble_ir.o -c backends/asm/assemble_ir.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/optimize_ir.o -c backends/asm/optimize_ir.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/asm_peep.o -c backends/asm/asm_peep.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/inlineasm.o -c backends/asm/inlineasm.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/compress_ir.o -c backends/asm/compress_ir.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/outbc.o -c backends/bytecode/outbc.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/bcbuffers.o -c backends/bcbuffers.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/bcir.o -c backends/bytecode/bcir.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/bc_spin1.o -c backends/bytecode/bc_spin1.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/outnu.o -c backends/nucode/outnu.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/nuir.o -c backends/nucode/nuir.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/nupeep.o -c backends/nucode/nupeep.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/outcpp.o -c backends/cpp/outcpp.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/cppfunc.o -c backends/cpp/cppfunc.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/outgas.o -c backends/cpp/outgas.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/cppexpr.o -c backends/cpp/cppexpr.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/cppbuiltin.o -c backends/cpp/cppbuiltin.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/compress.o -c backends/compress/compress.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/lz4.o -c backends/compress/lz4/lz4.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/lz4hc.o -c backends/compress/lz4/lz4hc.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/outzip.o -c backends/zip/outzip.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/zip.o -c backends/zip/zip.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/directive.o -c mcpp/directive.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/expand.o -c mcpp/expand.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/mbchar.o -c mcpp/mbchar.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/mcpp_eval.o -c mcpp/mcpp_eval.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/mcpp_main.o -c mcpp/mcpp_main.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/mcpp_system.o -c mcpp/mcpp_system.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/mcpp_support.o -c mcpp/mcpp_support.c
    gcc -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -DGITREV=v7.6.1-11-g71ce9b99  -o build/version.o -c version.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/becommon.o -c backends/becommon.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/brkdebug.o -c backends/brkdebug.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/printdebug.o -c frontends/printdebug.c
    gcc -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/spin.tab.o -c build/spin.tab.c
    build/spin.tab.c:8750:5: warning: variable 'spinyynerrs' set but not used [-Wunused-but-set-variable]
    int yynerrs;
    build/spin.tab.c:68:17: note: expanded from macro 'yynerrs'
    #define yynerrs spinyynerrs
    1 warning generated.
    gcc -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/basic.tab.o -c build/basic.tab.c
    build/basic.tab.c:3843:5: warning: variable 'basicyynerrs' set but not used [-Wunused-but-set-variable]
    int yynerrs;
    build/basic.tab.c:68:17: note: expanded from macro 'yynerrs'
    #define yynerrs basicyynerrs
    gcc -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/cgram.tab.o -c build/cgram.tab.c
    build/cgram.tab.c:3944:5: warning: variable 'cgramyynerrs' set but not used [-Wunused-but-set-variable]
    int yynerrs;
    build/cgram.tab.c:68:17: note: expanded from macro 'yynerrs'
    #define yynerrs cgramyynerrs
    gcc -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/spin2cpp spin2cpp.c cmdline.c build/common.o build/case.o build/spinc.o build/lexer.o build/uni2sjis.o build/symbol.o build/ast.o build/expr.o build/dofmt.o build/flexbuf.o build/lltoa_prec.o build/strupr.o build/strrev.o build/strdupcat.o build/to_utf8.o build/from_utf8.o build/sha256.o build/softcordic.o build/preprocess.o build/functions.o build/cse.o build/loops.o build/hloptimize.o build/hltransform.o build/types.o build/pasm.o build/outdat.o build/outlst.o build/outobj.o build/spinlang.o build/basiclang.o build/clang.o build/bflang.o build/outasm.o build/assemble_ir.o build/optimize_ir.o build/asm_peep.o build/inlineasm.o build/compress_ir.o build/outbc.o build/bcbuffers.o build/bcir.o build/bc_spin1.o build/outnu.o build/nuir.o build/nupeep.o build/outcpp.o build/cppfunc.o build/outgas.o build/cppexpr.o build/cppbuiltin.o build/compress.o build/lz4.o build/lz4hc.o build/outzip.o build/zip.o build/directive.o build/expand.o build/mbchar.o build/mcpp_eval.o build/mcpp_main.o build/mcpp_system.o build/mcpp_support.o build/version.o build/becommon.o build/brkdebug.o build/printdebug.o build/spin.tab.o build/basic.tab.o build/cgram.tab.o -lm
    gcc -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/flexspin flexspin.c cmdline.c build/common.o build/case.o build/spinc.o build/lexer.o build/uni2sjis.o build/symbol.o build/ast.o build/expr.o build/dofmt.o build/flexbuf.o build/lltoa_prec.o build/strupr.o build/strrev.o build/strdupcat.o build/to_utf8.o build/from_utf8.o build/sha256.o build/softcordic.o build/preprocess.o build/functions.o build/cse.o build/loops.o build/hloptimize.o build/hltransform.o build/types.o build/pasm.o build/outdat.o build/outlst.o build/outobj.o build/spinlang.o build/basiclang.o build/clang.o build/bflang.o build/outasm.o build/assemble_ir.o build/optimize_ir.o build/asm_peep.o build/inlineasm.o build/compress_ir.o build/outbc.o build/bcbuffers.o build/bcir.o build/bc_spin1.o build/outnu.o build/nuir.o build/nupeep.o build/outcpp.o build/cppfunc.o build/outgas.o build/cppexpr.o build/cppbuiltin.o build/compress.o build/lz4.o build/lz4hc.o build/outzip.o build/zip.o build/directive.o build/expand.o build/mbchar.o build/mcpp_eval.o build/mcpp_main.o build/mcpp_system.o build/mcpp_support.o build/version.o build/becommon.o build/brkdebug.o build/printdebug.o build/spin.tab.o build/basic.tab.o build/cgram.tab.o -lm
    gcc -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/flexcc flexcc.c cmdline.c build/common.o build/case.o build/spinc.o build/lexer.o build/uni2sjis.o build/symbol.o build/ast.o build/expr.o build/dofmt.o build/flexbuf.o build/lltoa_prec.o build/strupr.o build/strrev.o build/strdupcat.o build/to_utf8.o build/from_utf8.o build/sha256.o build/softcordic.o build/preprocess.o build/functions.o build/cse.o build/loops.o build/hloptimize.o build/hltransform.o build/types.o build/pasm.o build/outdat.o build/outlst.o build/outobj.o build/spinlang.o build/basiclang.o build/clang.o build/bflang.o build/outasm.o build/assemble_ir.o build/optimize_ir.o build/asm_peep.o build/inlineasm.o build/compress_ir.o build/outbc.o build/bcbuffers.o build/bcir.o build/bc_spin1.o build/outnu.o build/nuir.o build/nupeep.o build/outcpp.o build/cppfunc.o build/outgas.o build/cppexpr.o build/cppbuiltin.o build/compress.o build/lz4.o build/lz4hc.o build/outzip.o build/zip.o build/directive.o build/expand.o build/mbchar.o build/mcpp_eval.o build/mcpp_main.o build/mcpp_system.o build/mcpp_support.o build/version.o build/becommon.o build/brkdebug.o build/printdebug.o build/spin.tab.o build/basic.tab.o build/cgram.tab.o -lm
    edited 2026-03-02 06:52
    Interesting observation. Running CoreMark with the I-cache row count total configured as 4 active rows each containing 256 byte blocks (instead of 255 rows I used above) still works! Performance drops by half. It's quite a small test program so its working set is very small. In this case the I-cache is only 1kB in size holding 256 P2 instructions. I probably should add some cache row load/miss counter which would help in dimensioning the cache size for the application.
    CoreMark Size    : 666
    Total ticks      : 3473502264
    Total time (secs): 21
    Iterations/Sec   : 9
    Iterations       : 200
    @rogloh
    Go for it! Catalina could use some competition! :)
    edited 2026-03-08 05:30
    Currently wondering where to go next with this code...
    So far I've basically proven the general concept of using flexspin to build code to run with external memory can be made to work on a P2. :smile:
    I've found that prefixing "FAR_" to function names to identify them for storage in the external memory segment is rather tedious when the project contains lots of files and functions. Not only do you need to modify all the source code that will target the external memory, the calling code also has to be modified to prefix the same FAR_ to the function name. This is not really very scalable and was only done for this proof of concept in order to get something working before flexspin might potentially be modified to enable a proper external memory solution.
    Another alternative is to locate all code in external memory by default when the external memory option is enabled for the build and perhaps use some function list or attribute that places some subset of this code in internal memory otherwise. This is better if you wanted to port a large project to the P2, the bulk of which would be held in external RAM but has some small number of critical loop / non-cachable functions which make sense to keep in internal hub RAM for sharing with other COGs (eg. any included SPIN2 object APIs) or if it could really benefit from some optimizations that are only allowed in regular internal memory code to increase performance further.
    I've started down that path but already found one big problem with this plan is that the cache initialization step at startup time requires some minimal number of functions to be called before the PSRAM is configured to respond to cache row loading. Right now it that would be identifying the PSRAM mailbox address and running the PSRAM startup code and these API functions are needed to be called before the system is ready to execute from external memory. So some method of identifying which functions need to remain in HUBRAM is going to be required even just for system initialization at the very start, even if everything else targets external memory for storage.
    If this external memory functionality is going to become available in flexspin we ideally require some way to quickly identify which functions are to be placed into external memory, possibly by using some new #define or #pragma, or use some new attribute list option per function.
    For now I believe it's probably easier to just enable this external memory code storage feature on a file by file basis and selectively pull out the functions that need to remain in internal hub memory - you could probably move them into other files if the set is small. One way I was thinking of how to achieve it is just to separate the internal/external module's functions by their module file order on the command line, with the extmem.c module that configures the external memory also being the delimiter that separates them. Something like
    flexspin -2 main.c intmodule1.c intmodule2.c extmem.c extmodule1.c extmodule2.c
    This keeps main.c, intmodule.c intmodule2.c and extmem.c in internal memory, while storing extmodule1.c and extmodule2.c in PSRAM for example.
    I started going down this path and am already finding that for the standard library functions that get called, we don't really get much control as they are simply included by whatever parent module calls them, and they'll sit in the same location as their caller. So it's still not ideal.
    Any other ideas on the best way forward with this...?
    ps. I'm looking at the LVGL project (GUI/graphics library) as something that might be useful as a demo for this external memory feature. A large amount of its code could be stored in external memory keeping hub RAM free for other stuff (including a graphics framebuffer). Unfortunately I'm currently having issues with its build process with flexspin in general so it may not be a good example demo if I can't get it to build with flexspin. Still learning/persevering for now before possibly abandoning the idea...by default lvgl seems to want to build a static library that is then linked to the application code whilst flexspin wants all files on the same command line and doesn't directly support linking. Not sure if/how it can be split up instead.
    edited 2026-03-08 11:30
    @rogloh
    I think you are on the right track doing it file by file using compile-time options. Trying to do it within the language without mangling things too much would be tricky (look at the complexities Microsoft had to introduce in their version of C to accommodate "near" and "far" pointers). Ideally, you compile each file separately with the appropriate memory model, and then use a binary linker to figure out to to put it all together and get it to execute.
    But that assumes you have a suitable linker. I don't know much about flexspin - maybe it has one you can modify. But it would be a big job!
    Catalina does not have a linker - for programs that use a single memory model you don't really need a linker - and for programs that use multiple memory models I built a separate utility (called Catapult) to help automate the build process. Catapult essentially turns anything to be executed from Hub RAM into a binary blob that can be loaded at run time either from external memory or from a disk file. The blobs can be loaded in separate Hub RAM locations, or all in the one location (i.e. as overlays). In Catalina, each component executes on a different cog, and they communicate via the Registry - this sounds complex but it actually simplifies many things. However, that would not be an option in flexspin - you might have to implement something similar yourself. But even when using Catapult you still effectively have do the linkage between the components yourself.
    See (for example) demos/catapult/srv_c_p2.c - the my_service_list table in that program is essentially doing manually what it would be ideal to have a linker or other utility do automatically - it does so by using "proxy" functions. When I get time I may add the capability for Catapult to automatically generate those proxy functions. This would have been too difficult for me to do in lcc (which is a bit of a monster) but now that Catalina also uses Cake (which does semantic analysis of the C source code) it should be a lot easier. But even if the proxy functions have to be manually created, the idea of using them may be worth exploring - all the complexity could at least be contained in one file.
    One downside of the way Catalina does things is that if both a hub function and an external function call the same functions, you end up with two completely separate copies of each called function - one that executes from Hub RAM, and the other that executes from external RAM. Again, this makes some things easier, but it also complicates other things if the functions are not built to deal with such a possibility - for example, you cannot use stdio library functions from two different components - all stdio library calls have to be done from within one of the components.
    Ross.
    @rogloh
    I was thinking some more about this last night. In particular, the idea of using "proxy" functions, which do whatever is required to invoke the actual functions compiled to use a different memory model.
    In my previous post I thought that this would require additional processing of the source code to generate the necessary information, but my midnight brainwave was that debuggers already require the same information. For example, Catalina's -g option causes lcc to generate a standard "stabs" file (with a .debug extension) containing information about each function in the source. Catalina's Blackbox debugger uses this information.
    You may find that flexspin has something similar that could help automate the creation of proxy functions.
    Another option would be to add pragmas to the source code to include the necessary information required to call each external function compiled with a different memory model. This does not require a change in the language, and is probably the option I will explore first, because Catapult already uses pragmas (and processing "stabs" files is a black art!).
    Ross.
    edited 2026-03-09 01:39
    @RossH said:
    @rogloh
    Interesting, I guess one issue with that is that it would slow down ALL function calls via these proxies.
    I don't think flexspin has that. The only other output file I know of apart from the .p2asm intermediate source is the listing file. And that just gives me opcodes and preliminary HUB RAM addresses assuming a normal internal memory target for everything in the set of files passed. This p2asm file is what I mess about with with my sed scripts to reorder it and insert an ORG $100000 at the internal/external address boundary before re-assembling the updated file to a final binary.
    I think a special pragma to enable and disable external memory target (applies globally) would be useful. If the command line input is sorted to be internal modules first following by external modules, then a single pragma could change the target model applied from then on when invoked (until it is optionally disabled). This would avoid needing lots of source code modifications. It could simply be placed in a single file once (e.g my extmem.c file) and it would also limit which optimizations can be applied to the functions it compiles when enabled. Otherwise adding a special "FAR" attribute per function is a lot of changes if the source code is extensive. Then if you do have a few special functions in your mostly external source that do need to target internal memory instead you could either pull them out into a separate file or if not, just place the pragma around those functions to disable/re-enable FAR mode at will. It's probably the most convenient way to go.
    Ross.
    edited 2026-03-09 05:19
    After testing out the method of separating code by command line order it looks like I was wrong about how flexspin brings in its dependent functions called by each of its compiled modules. I'm now not totally sure how it generates the order of code in the p2asm output file. A few internal library functions get pulled into the same part of the code that calls them, but most library functions seem to actually be placed at the end of the group of compiled files. What differentiates this actual placement I don't know.
    Here's the function order in the image you get when building the coremark benchmark according to this command line file order.
    flexspin -DITERATIONS=200 -O0,const -gbrk core_main.c extmem.c core_list_join.c core_util.c core_matrix.c core_state.c core_portme.c
    It starts out with a small handful of internal functions, then the module code seem to follow, then some more internal library functions, then some SPIN2 modules incorporated in the C source, then a whole bunch of __system__ prefixed functions. I guess I can try to place some fixed file at the end of the compiled file list that defines a specific function name I can search for to disable external memory placement in my scripts... Messy but maybe achievable. :(
    popregs__ret  <--- special function in COGRAM (ignore)
    ___default_getc_ret  <--- why are these ones placed here?
    ___default_putc_ret
    ___default_flush_ret
    ___lockio_ret
    ___unlockio_ret
    ___getftab_ret
    _printf_ret  <---  called in core_main.c (again why here)
    _FAR_iterate_ret  <--- defined in core_main.c
    _main_ret   <--- defined in core_main.c
    _extmeminit_ret  <--- defined in extmem.c
    _FAR_calc_func_ret  <--- defined in core_list_join.c
    .... <--- lots of other functions but still in command line file order
    _portable_init_ret <--- defined in core_portme.c
    _portable_fini_ret  <--- defined in core_portme.c
    __dofmt_ret  <--- all of these functions now seem to be from internal library functions
    __strrev_ret
    __fmtpad_ret
    __fmtstr_ret
    __fmtchar_ret
    __uitoall_ret
    __uitoa_ret
    __fmtnum_ret
    __fmtnumlong_ret
    _disassemble_0254_ret
    _emitsign_0256_ret
    __fmtfloat_ret
    __getiolock_0295_ret
    __rxtxioctl_0356_ret
    ___dummy_flush_0357_ret
    _parseint_0408_ret
    _parseflags_0415_ret
    _parsesize_0419_ret
    __asfloat_0421_ret
    ___default_filbuf_ret
    _psram_spin2_start_ret  <--- defined in my psram.spin2 file
    _psram_spin2_startx_ret
    _psram_spin2_stop_ret
    _psram_spin2_write_ret
    _psram_spin2_getMailbox_ret
    _psram_spin2_lookupDelay_ret
    _psram16drv_spin2_getDriverAddr_ret <--- another nested SPIN2 file declared in psram.spin2 as an OBJ
    __system___getcnt_ret  <--- now all these __system___* functions are placed here
    __system___cogid_ret
    __system___cogstop_ret
    __system___locknew_ret
    __system___lockret_ret
    __system___coginit_ret
    __system___txwait_ret
    __system___setbaud_ret
    __system___txraw_ret
    __system___rxraw_ret
    __system___dirl_ret
    __system___dirh_ret
    __system___drvl_ret
    __system___pinr_ret
    __system___rdpin_ret
    __system___rdpinx_ret
    __system___div64_ret
    __system___wrpin_ret
    __system___wxpin_ret
    __system___wypin_ret
    __system____builtin_memset_ret
    __system__longfill_ret
    __system___make_methodptr_ret
    __system___int64_add_ret
    __system___int64_sub_ret
    __system___int64_cmpu_ret
    __system___int64_cmps_ret
    __system____builtin_strlen_ret
    __system____builtin_strcpy_ret
    __system___lockmem_ret
    __system___unlockmem_ret
    __system___getrxtxflags_ret
    __system___setrxtxflags_ret
    __system___tx_ret
    __system___rx_ret
    __system___basic_print_nl_ret
    __system___basic_print_char_ret
    __system___basic_print_string_ret
    __system___basic_print_integer_ret
    __system___basic_print_unsigned_ret
    __system___fmtchar_ret
    __system___fmtstr_ret
    __system___fmtnum_ret
    __system___seterror_ret
    __system___int64_signx_ret
    __system___int64_zerox_ret
    __system___int64_and_ret
    __system___int64_neg_ret
    __system___int64_muls_ret
    __system___int64_divmodu_ret
    __system___int64_divu_ret
    __system___int64_modu_ret
    __system___float_fromuns_ret
    __system___float_fromint_ret
    __system___float_negate_ret
    __system___float_mul_ret
    __system___float_div_ret
    __system___float_cmp_ret
    __system___float_Unpack_ret
    __system___float_Pack_ret
    __system____builtin_signbit_ret
    __system____builtin_ilogb_ret
    __system___float_pow_n_ret
    __system____default_getc_ret
    __system____default_putc_ret
    __system____default_flush_ret
    __system____getftab_ret
    __system___gettxfunc_ret
    __system___strrev_ret
    __system___fmtpad_ret
    __system___uitoa_ret
    __system___rxtxioctl_0563_ret
    __system____dummy_flush_0564_ret
    __system__asFloat_0625_ret
    __system__asInt_0627_ret
    __system__pack_0630_ret
    __system____default_filbuf_ret
    __system___struct__s_vfs_file_t_putchar__ret
    __system___struct__s_vfs_file_t_getchar__ret
    __system___struct___bas_wrap_sender_tx__ret
    __system___struct___bas_wrap_sender_rx__ret
    __system___struct___bas_wrap_sender_close__ret
    UPDATE:
    just modified my script to look for extmem_start and extmem_stop functions in the p2asm file to delineate the external memory target and this command seems to work (at least for the coremark application).
    flexspin -l -DITERATIONS=200 -O0,const -gbrk core_main.c extmem.c core_list_join.c core_util.c core_matrix.c core_state.c core_portme.c extmemoff.c
    I just created a closing extmemoff.c file with this function
    void extmem_end(void)
        return;
    which assembles to this code after I patched it in my output file. I can then use extmem_start and extmem_end function names to enclose the external memory target functions. Ugly but it works at least for now.
    _extmem_end
    '     return;
        callpa  ##_extmem_end_ret, farjmp_handler
    _extmem_end_ret
        ret
    FARCODE_END
    I've never really studied memory caching hardware but I've just come to a realisation that I've probably had an incorrect view of their behaviour. I've just been looking at a block diagram of HBM4, as recently posted to a news site, and it kind of drove home to me that cache doesn't initiate memory accesses at all. It only sits on the side lines and intercepts the data flows as suits it.
    Note the allowance for up to 32 pseudo channels. A unified L3 cache isn't going to distinguish between threads/cores where as direct core to main memory accesses will easily be separable into channels matching each core or thread.
    That's actually not at all how it typically works.
    You definitely need memory access from the cache system, to store dirty evicted lines back into memory. There's also often an uncore prefetcher that observes LLC miss patterns. Shared caches also need to keep track of which core "owns" a line to avoid corruption. If e.g. two cores want to modify one value each that happen to be next to each other in the same line, the coherency algorithm needs to stop the second core from wholly overwriting the line with its own L1 cached version (where the first value hasn't been changed). That sort of "false sharing" typically causes severe slowdown to ensure correctness.
    Mostly over and above where I was talking. The storing dirty lines I guess is slightly relevant in that the cache does address memory itself for that. But mainly I was talking about how the L3 cache is positioned in the data flow. For some reason I had imagined it stood in the middle, gobbling everything.
