P2 DUAL uSD FAT32 and FLASH Filesystem (spin2/pasm2) — Parallax Forums
Stephen MoracoStephen Moraco Posts: 445
edited 2026-03-08 08:40 in Propeller 2
New P2 Dual Filesystem Driver — SD FAT32 + Flash in One Cog
Version 1.0.0
This is the first public release of a unified dual-filesystem driver for the P2 Edge Module. It gives you simultaneous access to both the onboard 16 MB Flash chip and a microSD card through a single worker cog and a single API — every file operation takes a device parameter, so you can read, write, and copy across both devices seamlessly.
Incorporates P2 uSD FAT32 FS v1.3.1 and P2 FLASH FS v2.0.0
What's in the box
  • Unified Driver (dual_sd_fat32_flash_fs.spin2) — SD FAT32 and Flash filesystems managed by one dedicated cog with automatic SPI bus switching, hardware lock serialization, 6 simultaneous file/directory handles (configurable), 3 of which can be flash files (configurable), per-cog working directories, and cross-device copyFile() / moveFile()
  • 7 Utilities — SD and Flash format, audit, and fsck (with auto-repair for SD), plus an SD card characterizer for benchmarking and card identification
  • Demo Shell — Interactive dual-device terminal with sd/fl device switching, dir, cd, type, hexdump, copy, format, fsck, audit, bench, and more
  • 4 Example Programs — Basic read/write, cross-device copy, data logger, and SD manifest reader copy to flash
  • Full Documentation
Testing: 1,308 regression tests across 29 suites (SD, Flash, cross-device, dual-device, multi-cog), all validated on P2 hardware.
Known limitations:
- 8.3 filenames only (no LFN)
- SPI mode only, 25 MHz maximum
Compiles with pnut/pnut-ts.
Set up to compile with FlexSpin and Spin Tools IDE, but needs testing.
(Working through issues with FlexSpin; watch for a point release shortly.)
Hardware: P2 Edge Modules P2-EC and P2-EC32MB (both have built-in microSD socket and onboard 16 MB Flash chip).
Need only one device? Standalone alternatives produce smaller binaries: P2 FLASH FS and P2 uSD FAT32 FS.
Visit the Repo for full documentation, including a driver tutorial, theory of operations, and utilities guide.
The release package can be downloaded from the Release page as dual-fs-driver-{version}.zip.
If you find issues, please file them at the Issues.
Enjoy!
Stephen
  • RaymanRayman Posts: 16,124
    This sounds great! Thanks.
    Is this flash file system compatible with the one Chip made?
  • Stephen MoracoStephen Moraco Posts: 445
    edited 2026-03-08 19:23
    Yes, it is the very same as the release in my repo quite a while ago. (links in the announcement post to the repo's)
  • NEWS
    I just released v1.1.0 - Incorporates P2 uSD FAT32 FS v1.3.2 and P2 FLASH FS v2.0.0
    Here's what's new/fixed:
    v1.1.0
    ### Fixed
    - BUGFIX: SPI write data integrity at power-of-2 half-period clock speeds (writeSector() and writeSectors())
    ### Added
    - Selective debug: 12-channel DEBUG_MASK system for debug[CH_xxx]() output -- developers enable 2-3 channels at a time to stay under the P2 255-record limit
    - FlexSpin compatibility: All 43 compilable files build with both pnut-ts and FlexSpin 7.6.1
    Enjoy!
    Stephen
