Revised P2 PLC (Testing) — Parallax Forums
RaymanRayman Posts: 16,208
edited 2026-03-18 13:35 in Propeller 2
Currently have a Bud DMB-4775 enclosure based PLC going with P2 SWaP module. This is all fine, but not entirely happy with some things, mostly the way have to carve the enclosure. Also, the SWaP module is kind of a pain to assemble...
So, now looking at the slightly larger DMB-4773 Bud enclosure. With this one, and some rearranging, just have to carve the upper part of the enclosure and then can cover it up nicely with a 3D printed cover.
The Amphenol modular connector is moved up by putting it on a separate board. This is probably a good idea anyway, in case another project wants a different connector or no connector at all...
The other big change looking at is possibly replacing SWaP with what am calling "P2 Core" module.
This is now 1.6" square with castellated edges and also 0.05" pitch headers, so can be soldered to board or connected using headers. Looking at 20-pin headers on all four sides. Think that should be enough...
The P2 Core module is a proven design with 4 layers and can be well overclocked. It also has a regulator for VDD on each group of 8 pins, so is better for analog signals. But, the main thing is that it is much easier to assemble than SWaP...
  • RaymanRayman Posts: 16,208
    There's a lot more flexibility here... Could still use SWaP on main board if wanted, could be better for some things...
    Really like the idea of putting that modular connector on a separate board, so can be exchanged for something else or just not used at all.
    I previous arrangement the large bottom board needed a cut out to accommodate the modular connector, but here the top board will need a cut out.
    This may be better as the top board isn't maybe as important...
    In fact, if leaving the top cover in place, don't even need the small top board...
    Nice thing with either SWaP or P2 Core is that these other boards can be simple 2-layer designs, easily customizable...
  • Do you already have some feature list of what interfaces or applications you are planning to support?
    The connector module has Ethernet, USB-A, USB-C... but what are the two connectors at the bottom?
    edited 2026-03-03 15:15
    @ManAtWork Good questions... The two on the bottom are just plain RJ45. Planning on connecting them with 5V, GND, and 4 P2 I/O in the way @refaQtor suggested, as a simple way of connecting to external interfaces...
    The Ethernet is going to go to a header on main PCB. One would need to connect something to this header to make the port useful. It could be a simple passive thing to just provide a third RJ45, or it could be a Wiznet device for ethernet.
    The USB-C is for serial interface with optional power and/or programming.
    The USB-A would go to ESD chip and then to P2 for keyboard, mouse, etc. support.
    So, this all goes on the main board. The revised plan is to have that modular connector attach to the main board with 1 or 2 headers, so it can be at the right vertical height.
    But, one could also just not use the modular connector board and thereby have more I/O connectors on the bottom board.
    I'm not 100 % sure yet that this is going to work out physically, but looks good in SolidWorks, so am hopeful.
    The other new plan for the main board is to have all the connectors to the bottom board be the 12-pin Eval style arrangement.
    Will use IDC cable to connect middle (main) board to bottom board with the I/O and power supply.
    This has the advantage of being able to play around with Eval style accessories as well, before installing into enclose anyway.
    Also, this would let the bottom board be connected to other Eval style P2 boards for testing.
    Just seems like adds some flexibility...
    Guess the idea is that the main (middle) board can be flexible enough to be used for most applications, while the top and bottom boards are application specific.
    The top board is not really even needed, could just not use it and leave the DMB-4773 top cover in place.
    But, I'll probably do one with small LCD and some buttons, and 3D printed bezel on top of that.
    Might use the clear plastic cover on top of that with holes for the buttons, not sure yet...
    The bottom board is more of a challenge. This is where the real interface to other things goes...
    If main goal was to sell a bunch, maybe I'd copy the Arduino PLC thing and have some 10A relay outputs there so could turn on lights or small motors or something.
    But, I'm more interested in plain 24 VDC Digital I/O, so will probably just do a bunch of that...
    edited 2026-03-03 15:29
    Almost have the "P2 Core Module" design done. Just need to connect through hole I/O to vias to be castellated...
    Passes design rule check already.
    This seemed to be almost too easy... Somethings that means there's a horrible mistake...
    Think will use OSHPark to get a quick first try.
    I'm liking them for price and speed and guess can live with purple pcb for prototypes...
    1573 x 1504 - 638K
    Made some quick decisions as to where to put power and I/O on the headers...
    Doesn't need to be final, but might be.
    The thing about power and GND in this particular case is that it doesn't matter all that much...
    The 1.8 V VDD all goes through one trace to a fill that goes all the way around under the P2 chip on the top plane and is well bypassed by the 0402 caps right next to VDD pins.
    The VIO actually goes first to regulators, one for every 8 pins, that is also well bypassed.
    So, where the actual power pins are doesn't matter so much.
    For convenience, the 1.8V ones are all close together and close that trace that brings it to the P2...
    2836 x 1855 - 62K
    Just remembered that the network RJ45 connector has integrated magnetics. So, guess it can't be generally used like the others...
    The plan is coming together and it's looking great. Now have main board and top board finished. Top board features 1.8" LCD (does anybody else do this (think not)), power led, a P2 reset button, and a general purpose reset button.
    Except for the LCD and uSD seems consistent with Arduino version. Arduino can't handle updating LCD in PLC loop, so this is a real moment to shine for P2...
    Now working on bottom board. Feels to me like this should be the one very custom board, application specific, maybe. But, working on a very general purpose one with sixteen 24VDC inputs and eight 24 VDC outputs.
    All I/O still either mechanically or optically isolated... Don't wany any way for outside signals to perturb P2...
    The ratio of inputs to outputs changeable at design time, maybe at build time too? Hmm.. Maybe, have to look at that...
    One thing new for this revision is want to make all the bottom board components through hole.
    This makes it easier for people to assemble on their own, with their own designs. Right?
    Also, arguably easier to replace components using desoldering gun. Although, for me hot air gun on SMT is just as fast... But maybe can't hot gun some plastic things...
    Anyway, a lot of people I'm sure are more comfortable with through hole vs SMT, and the bottom board is where that can make sense.
    On the flip side, maybe new tariff situation means can get SWaP modules made for cheap …
    This revised concept should be compatible with SWaP with new main board…
    Wait.. can we do this now? Have to check .. that might be very nice..,
    If main board could do either SwaP or Core might be perfect…. Ying and yang
    Ordered a bunch of prototypes today for OSHPark...
    537 x 1130 - 63K
    451 x 538 - 86K
    437 x 526 - 135K
    432 x 730 - 141K
    492 x 534 - 127K
    Got the boards, now time for FFF (Form, Fit, & Function) testing...
    2000 x 1126 - 637K
    Tested out the fit and it is really good. Very happy with how it is looking so far...
    1126 x 2000 - 844K
    1126 x 2000 - 846K
    1286 x 724 - 169K
    1286 x 724 - 146K
    724 x 1287 - 189K
    Got the USB and power supplies assembled and working on middle board.
    This USB-C connector is kind of in parallel with the one on the Modular connector. This one is for testing outside of the box...
    Doing something slightly different with USB power for this one. Just letting the 5.1k resistors negotiate power, saving a mosfet... Seems to be fine.
    480 x 640 - 107K
    It's got a pulse ! :)
    329 x 143 - 8K
    360 x 480 - 79K
    360 x 480 - 67K
    Got three of these core modules from oshpark assembled…
    First one worked out perfect. Second one, made mistake of applying extra solder to the pin headers while connected to main board. Learned that is not a good idea as had to break headers to remove core from main module :(
    Think can be fixed though.
    Third one has dead short on power supply . Haven’t found where yet. Think it might be internal layer.
    I’m thinking the oshpark specs aren’t quite as tight as seeed fusion, but a mystery at this point. Guess should count lucky that 2 of three are good.
  • ke4pjwke4pjw Posts: 1,308
    I used a Harbor Freight IR camera to troubleshoot a failure in one of my boards. Found exactly where the short was and it was on an internal layer. Not sure it was a manufacturing defect, but a thermal issue with the poor selection of linear regulator and heatsink on my part damaging the board.
    I slowly raised the voltage to just before the supply shuts down due to over current. It made enough heat to be seen on the camera.
    This is an awesome board, BTW!
    Just ordered revised middle and top boards from oshpark.
    Fixing some issues, adding some text, but mainly reverting uSD to normal pinout so can use the new @"Stephen Moraco" dual uSD/Flash driver.
    This saves a pin and allows for extra button on top. Thought one button was enough for interaction with LCD, but two is better.
    Other button is reset button. Copying this idea from the arduino PlC. Guess it’s a good idea…
    Also ordered a batch of core modules from Seeed Fusion. The tariffs are still there :(
    Thought the edge plating would be a problem, but seems not, was option in regular service.
    The Oshpark ones reached around 340 MHz with regular VDD and 380 MHz with overclock raised VDD with 2 cog VGA test. pretty good considering their inner layers are only 1/2 oz.
    New boards will have 1 oz inners so should be better.
    Don’t really want overclocking for PLC but good for other applications. Plus gives me a good feeling to know operating well within margins…
  • Very nice design and workmanship Sir! Thanks for sharing.
    @pmrobert Thanks!
    It pains me, but think need to increase headers from 20 to 24 pins. That will allow bringing out all the various VIO.
    Saves one from supplying a separate 3.3 VDC supply to other things like uSD and Flash...
    Also can help in the case of sensitive ADC with calibration, I think....
    Looks like there is just enough room for this, so going to wire it up and see how it looks...
