Looking for a way to save AUDS/AUGD/SETQ state - Page 3 — Parallax Forums
13»
  • roglohrogloh Posts: 6,264
    edited 2026-03-01 06:57
    Just did the real run from PSRAM test using P2-EVAL and my own PSRAM board at 160MHz. Only made a small improvement in the total tick count but that's to be expected given the number of iterations and the fact that only 31 rows are ever loaded.
    Worked first go which is great but almost makes me believe it's not real. Now want to intentionally impair PSRAM to ensure it's legit. Will just yank the breakout board out for that. UPDATE: yep crashed right away with the board removed. So it's loading the code from the PSRAM now! :smiley:
    2K performance run parameters for coremark.
    CoreMark Size    : 666
    Total ticks      : 1853091552
    Total time (secs): 11
    Iterations/Sec   : 18
    Iterations       : 200
  • RossHRossH Posts: 5,709
    @roghloh
    160MHz is just the default for flexspin C .
    I thought the P2 was originally designed for a maximum 180Mhz clock speed, although it has since shown it can generally go much, much faster. For myself I tend to use 200Mhz, but Catalina's default is 180Mhz, because I thought that was still the design maximum. If there is now a reason to make the default slower than that, I'd like to know it.
    Haven't considered it yet but in theory multiple COGs running from external memory could each have their own I-caches and share a common external memory, with a commensurate reduction in performance. The main limitation here is that this model doesn't keep directly accessed data in the external RAM, just code,
    That would be analogous to Catalina's SMALL mode, which only stores code in external RAM (as opposed to LARGE mode is where both code and data are stored in external RAM). But even multi-processing in SMALL mode would be a huge win. My biggest problem is that I always tried to keep Catalina compatible with both the P1 and the P2, which I have (just about!) managed. But that is largely just nostalgia on my part - I have really fond memories of the P1, but I knew one day this compatibility would probably have to come to an end.
    I will follow progress with interest :)
    @RossH said:
    @roghloh
    There's no reason for that IMO, 160MHz is just what flexspin had setup as the default from way back.
    I think it's probably doable to have multiple COGs sharing the external RAM for their code (or even run different code as separate applications). Right now for this proof of concept setup I init an I-cache and block mapping table at startup time in another linked module called extmem.c whose addresses I pass into the COG external memory handler routines executed from LUTRAM during startup. The only change needed would be to not have this as defined a global variable block but allocated on a per COG stack instead via alloca in main() or something like that. I'm running the cache transfer requests through my external memory mailbox so other COGs can certainly make other requests in parallel to the COG executing external C routines. I can easily already prove that out to myself by introducing another video COG which shares the memory but I know it would work, just slower.
  • evanhevanh Posts: 17,092
    Probably originates from the Prop2-Hot days. Its design was targetted for 160 MHz I think.
    Now I have something functioning running via external memory and a cache, I was wondering about some of the potential target applications that might work with a larger memory model on a P2. I wonder if flexspin/spin2cpp could be setup to compile itself as a P2 application or whether the small 512k of HUBRAM for data would be a major limitation. This is assuming most/all of the executable code is stored externally with say a 64kB I-cache and (say) a 16-32kB block mapping table and some required library and filesystem APIs are present leaving up to 436kB or so for data. Flexspin on my Mac is only a 2.8MB executable so with any luck it might still compile to fit within some 16MB external address space (PSRAM) on a P2. I guess there would be some native OS and memory management APIs used that would need to be ported/provided on a P2 but it's more of whether it could be made to compile with much less available RAM for data that I'd be concerned about.
    Is there any scope for something like this or is it a fools errand even considering the idea compiling flexspin source from itself, especially without a linker?
    Output of make for building spin2cpp etc is shown below. It has dependencies on bison and builds each module separately before final link step.
    bison -p spinyy -t -b build/spin -d frontends/spin/spin.y
    bison -p basicyy -t -b build/basic -d frontends/basic/basic.y
    bison -p cgramyy -t -b build/cgram -d frontends/c/cgram.y
    frontends/c/cgram.y: conflicts: 5 shift/reduce
    gcc -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/lexer.o -c frontends/lexer.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/uni2sjis.o -c frontends/uni2sjis.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/symbol.o -c symbol.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/ast.o -c ast.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/expr.o -c expr.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/dofmt.o -c util/dofmt.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/flexbuf.o -c util/flexbuf.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/lltoa_prec.o -c util/lltoa_prec.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/strupr.o -c util/strupr.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/strrev.o -c util/strrev.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/strdupcat.o -c util/strdupcat.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/to_utf8.o -c util/to_utf8.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/from_utf8.o -c util/from_utf8.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/sha256.o -c util/sha256.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/softcordic.o -c util/softcordic.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/preprocess.o -c preprocess.c
    gcc -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/testlex testlex.c build/lexer.o build/uni2sjis.o build/symbol.o build/ast.o build/expr.o build/dofmt.o build/flexbuf.o build/lltoa_prec.o build/strupr.o build/strrev.o build/strdupcat.o build/to_utf8.o build/from_utf8.o build/sha256.o build/softcordic.o build/preprocess.o -lm
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/common.o -c frontends/common.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/case.o -c frontends/case.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/spinc.o -c spinc.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/functions.o -c functions.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/cse.o -c cse.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/loops.o -c loops.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/hloptimize.o -c frontends/hloptimize.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/hltransform.o -c frontends/hltransform.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/types.o -c frontends/types.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/pasm.o -c pasm.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/outdat.o -c backends/dat/outdat.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/outlst.o -c backends/dat/outlst.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/outobj.o -c backends/objfile/outobj.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/spinlang.o -c frontends/spin/spinlang.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/basiclang.o -c frontends/basic/basiclang.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/clang.o -c frontends/c/clang.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/bflang.o -c frontends/bf/bflang.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/outasm.o -c backends/asm/outasm.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/assemble_ir.o -c backends/asm/assemble_ir.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/optimize_ir.o -c backends/asm/optimize_ir.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/asm_peep.o -c backends/asm/asm_peep.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/inlineasm.o -c backends/asm/inlineasm.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/compress_ir.o -c backends/asm/compress_ir.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/outbc.o -c backends/bytecode/outbc.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/bcbuffers.o -c backends/bcbuffers.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/bcir.o -c backends/bytecode/bcir.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/bc_spin1.o -c backends/bytecode/bc_spin1.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/outnu.o -c backends/nucode/outnu.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/nuir.o -c backends/nucode/nuir.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/nupeep.o -c backends/nucode/nupeep.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/outcpp.o -c backends/cpp/outcpp.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/cppfunc.o -c backends/cpp/cppfunc.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/outgas.o -c backends/cpp/outgas.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/cppexpr.o -c backends/cpp/cppexpr.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/cppbuiltin.o -c backends/cpp/cppbuiltin.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/compress.o -c backends/compress/compress.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/lz4.o -c backends/compress/lz4/lz4.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/lz4hc.o -c backends/compress/lz4/lz4hc.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/outzip.o -c backends/zip/outzip.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/zip.o -c backends/zip/zip.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/directive.o -c mcpp/directive.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/expand.o -c mcpp/expand.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/mbchar.o -c mcpp/mbchar.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/mcpp_eval.o -c mcpp/mcpp_eval.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/mcpp_main.o -c mcpp/mcpp_main.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/mcpp_system.o -c mcpp/mcpp_system.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/mcpp_support.o -c mcpp/mcpp_support.c
    gcc -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -DGITREV=v7.6.1-11-g71ce9b99  -o build/version.o -c version.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/becommon.o -c backends/becommon.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/brkdebug.o -c backends/brkdebug.c
    gcc -MMD -MP -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/printdebug.o -c frontends/printdebug.c
    gcc -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/spin.tab.o -c build/spin.tab.c
    build/spin.tab.c:8750:5: warning: variable 'spinyynerrs' set but not used [-Wunused-but-set-variable]
    int yynerrs;
    build/spin.tab.c:68:17: note: expanded from macro 'yynerrs'
    #define yynerrs spinyynerrs
    1 warning generated.
    gcc -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/basic.tab.o -c build/basic.tab.c
    build/basic.tab.c:3843:5: warning: variable 'basicyynerrs' set but not used [-Wunused-but-set-variable]
    int yynerrs;
    build/basic.tab.c:68:17: note: expanded from macro 'yynerrs'
    #define yynerrs basicyynerrs
    gcc -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/cgram.tab.o -c build/cgram.tab.c
    build/cgram.tab.c:3944:5: warning: variable 'cgramyynerrs' set but not used [-Wunused-but-set-variable]
    int yynerrs;
    build/cgram.tab.c:68:17: note: expanded from macro 'yynerrs'
    #define yynerrs cgramyynerrs
    gcc -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/spin2cpp spin2cpp.c cmdline.c build/common.o build/case.o build/spinc.o build/lexer.o build/uni2sjis.o build/symbol.o build/ast.o build/expr.o build/dofmt.o build/flexbuf.o build/lltoa_prec.o build/strupr.o build/strrev.o build/strdupcat.o build/to_utf8.o build/from_utf8.o build/sha256.o build/softcordic.o build/preprocess.o build/functions.o build/cse.o build/loops.o build/hloptimize.o build/hltransform.o build/types.o build/pasm.o build/outdat.o build/outlst.o build/outobj.o build/spinlang.o build/basiclang.o build/clang.o build/bflang.o build/outasm.o build/assemble_ir.o build/optimize_ir.o build/asm_peep.o build/inlineasm.o build/compress_ir.o build/outbc.o build/bcbuffers.o build/bcir.o build/bc_spin1.o build/outnu.o build/nuir.o build/nupeep.o build/outcpp.o build/cppfunc.o build/outgas.o build/cppexpr.o build/cppbuiltin.o build/compress.o build/lz4.o build/lz4hc.o build/outzip.o build/zip.o build/directive.o build/expand.o build/mbchar.o build/mcpp_eval.o build/mcpp_main.o build/mcpp_system.o build/mcpp_support.o build/version.o build/becommon.o build/brkdebug.o build/printdebug.o build/spin.tab.o build/basic.tab.o build/cgram.tab.o -lm
    gcc -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/flexspin flexspin.c cmdline.c build/common.o build/case.o build/spinc.o build/lexer.o build/uni2sjis.o build/symbol.o build/ast.o build/expr.o build/dofmt.o build/flexbuf.o build/lltoa_prec.o build/strupr.o build/strrev.o build/strdupcat.o build/to_utf8.o build/from_utf8.o build/sha256.o build/softcordic.o build/preprocess.o build/functions.o build/cse.o build/loops.o build/hloptimize.o build/hltransform.o build/types.o build/pasm.o build/outdat.o build/outlst.o build/outobj.o build/spinlang.o build/basiclang.o build/clang.o build/bflang.o build/outasm.o build/assemble_ir.o build/optimize_ir.o build/asm_peep.o build/inlineasm.o build/compress_ir.o build/outbc.o build/bcbuffers.o build/bcir.o build/bc_spin1.o build/outnu.o build/nuir.o build/nupeep.o build/outcpp.o build/cppfunc.o build/outgas.o build/cppexpr.o build/cppbuiltin.o build/compress.o build/lz4.o build/lz4hc.o build/outzip.o build/zip.o build/directive.o build/expand.o build/mbchar.o build/mcpp_eval.o build/mcpp_main.o build/mcpp_system.o build/mcpp_support.o build/version.o build/becommon.o build/brkdebug.o build/printdebug.o build/spin.tab.o build/basic.tab.o build/cgram.tab.o -lm
    gcc -g -Wall -fwrapv -Wc++-compat -I. -I./backends -I./frontends -Ibuild -DFLEXSPIN_BUILD -o build/flexcc flexcc.c cmdline.c build/common.o build/case.o build/spinc.o build/lexer.o build/uni2sjis.o build/symbol.o build/ast.o build/expr.o build/dofmt.o build/flexbuf.o build/lltoa_prec.o build/strupr.o build/strrev.o build/strdupcat.o build/to_utf8.o build/from_utf8.o build/sha256.o build/softcordic.o build/preprocess.o build/functions.o build/cse.o build/loops.o build/hloptimize.o build/hltransform.o build/types.o build/pasm.o build/outdat.o build/outlst.o build/outobj.o build/spinlang.o build/basiclang.o build/clang.o build/bflang.o build/outasm.o build/assemble_ir.o build/optimize_ir.o build/asm_peep.o build/inlineasm.o build/compress_ir.o build/outbc.o build/bcbuffers.o build/bcir.o build/bc_spin1.o build/outnu.o build/nuir.o build/nupeep.o build/outcpp.o build/cppfunc.o build/outgas.o build/cppexpr.o build/cppbuiltin.o build/compress.o build/lz4.o build/lz4hc.o build/outzip.o build/zip.o build/directive.o build/expand.o build/mbchar.o build/mcpp_eval.o build/mcpp_main.o build/mcpp_system.o build/mcpp_support.o build/version.o build/becommon.o build/brkdebug.o build/printdebug.o build/spin.tab.o build/basic.tab.o build/cgram.tab.o -lm
    edited 2026-03-02 06:52
    Interesting observation. Running CoreMark with the I-cache row count total configured as 4 active rows each containing 256 byte blocks (instead of 255 rows I used above) still works! Performance drops by half. It's quite a small test program so its working set is very small. In this case the I-cache is only 1kB in size holding 256 P2 instructions. I probably should add some cache row load/miss counter which would help in dimensioning the cache size for the application.
    CoreMark Size    : 666
    Total ticks      : 3473502264
    Total time (secs): 21
    Iterations/Sec   : 9
    Iterations       : 200
    @rogloh
    Go for it! Catalina could use some competition! :)
