feed back servo
pilot0315
Howdy,
I am finally trying to work with the feedback servo. Looking for some simple code.
I am attempting to use one like a standard servo with limited rotation for say 45 degrees both
directions. I think I saw a few years ago someone who was playing with them but cannot find it.
Just plain simple code hopefully with some documentation comments so I can understand what is being
done.
I have several and would like to use them.
Thank you in advance.
Martin
Hi
I think there are several "Feedback Sevos". Which exact type do you have?
One type can just be used as a normal servo but the additional line will give a voltage for the angle that you can measure using adc.
@"Christof Eb."
All are labeled: feedback servo 360 high speed
Ok, so these are continuous rotation servos.
For the application as a standard servo I would buy a standard servo. I don't see the advantage to build a control loop for the angle via P1.
They are servos set for CR with an extra wire (yellow); on that wire is a pulse that [roughly] provides the position value of the device. I tried. Don't like them. I prefer robotic actuators like Lewan Soul (inexpensive) or Dynamixels. They all run on a single wire bus (open collector, half-duplex serial), and provide a lot more information.
https://www.amazon.com/dp/B073XY5NT1
If memory serves me, the LX-1x cannot provide angle when in continuous rotation mode (because it's being used as a motor).
