New PNut-TS compiler for P2 development on Windows, Mac, Linux (yes, RPi) - Page 3 — Parallax Forums
13»
  • Hi @"Stephen Moraco",
    Just some more info on this issue:
    I am running on the latest Debian 13 Trixie but also see the same on Fedora 42 and Debian 12
    I can run from command line but would really like to understand the VSCODE situation.
    I appreciate your tremendous work in the propeller community and understand you are juggling many things !
    Bob
  • NEWS
    We've just released v1.52.2; we've improved performance where we can.
    Here's what's new/fixed:
    v1.52.2
    Improved performance
    • Several small changes to the code allow us to compile faster (I'm seeing ~1.9x to ~2x), but this depends on the style of your code. Your mileage may vary.
    PNut-TS is found at its Public Repository, while the latest Releases are also found there at the Releases Page
    We do comprehensive regression testing in preparation for each release. We also add to our regression suite to test all new capabilities. You can review our coverage testing via regress at PNut-TS Coverage Testing
    If you spot any issues with code generation or compilation, you can review the testing process. This should help you identify differences between PNut v52a and PNut_TS v1.52.2.
    We look forward to hearing what you find.
    As always, you can report issues here, or, better yet, if fixes are needed, report problems on the repository issues page. (You can also see the current list of what's been reported at this page.)
    Stephen & Chip
