Cyberbot Ping))) Roaming Program- Python - Error " Does not support "/" Does Not support for "None"
in Robotics
Going thru the Ping tests for the 32700 two errors pop up
line 10 " Does not support "/" Does not support for "None"
I have no "/" in the code only ","
that "/" is what the error calls out
In line 11 " Does not support "*" and " Does not support for " None" "
I thought * is a valid symbol ?
Note all the above is the copied script from the tutorial/course
see attached
Error occurs both in the Ping _test _with_ serial _monitor (although it runs )
and in ping__theremin
The Ping-servo_ test works okay
Please - help to debug the above - see attached
thanks
You might want to reach out to "support@parallax.com" for help with the micro:bit
Just one guess though... assuming you've copy/pasted a published example, I wonder if it is for the v3 python version you are using, or the previous v2 ?
It looks like you've installed the two .py objects into your micro:bit module (cyberbot.py and ping.py), so it looks like some sort of syntax mismatch in that IDE (which is why I wondered if that example was targeting v2 originally, and might not have been updated yet)
If you solve it, please post the solution back here
I wonder if that assignment to distance is working ok on the same line as the distance var is created.
Does this work instead ?
while True: val = ping(16).distance('cm') print('Distance: ' + str(val) + ' cm') #bot(22).tone((val*50),50)Might be a sidetrack, but on line 6 it seems there's an extra space after
bot(22).
