@ersmith said:
... so at least in theory someone could hook up multiple SD cards to a single P2.
I've done it. I've bulk copied files from one card to another as one of my test programs ... Or at least I tried, it was a while back and I don't remember the outcome to be honest.
EDIT2: Err, maybe this is all a rubbish idea? I see the struct __using("filesys/block/sdmm.cc") *SDMM; is located in _sdmm_open() function. That's where things are different.
Ada/Eric,
Just thinking about the recent relocation of _sdmm_open() and co. for init of the inbuilt driver. In my driver, I've been happily placing that functionality all directly into the driver source file. It feels tidy to me ... I'm thinking the same could be done here as example for any future third-party driver endeavours. Then all drivers internally get the same API layout.
Only different becomes the whereabouts a driver gets loaded. With third-party it is explicitly a struct __using() in the user code as opposed to buried in the headers.
EDIT: On achieving identical API, splitting off _vfs_open_sdcardx() from _sdmm_open() would be in order. While _sdmm_open() would go into the driver, the legacy functions of _vfs_open_sdcard() and _vfs_open_sdcardx() could go back where they came from. And sdmm_vfs.c would be no more.
Eric,
In the 4-bit SD card driver, in the name of performance, I'm thinking about the idea of patching the presets directly into the hubRAM stored __asm volatile {} code section. This is instead of the current approach of prefilling a structure and then copying the presets from there to cogRAM upon each inline entrance.
I'm not seeing any way to do it without throwing away all locality. Also, I need to keep parameter passing feature of function calling so can't use a global __pasm code section.
EDIT: I guess, what I really need from the parameter passing is its efficient register passing. A global __pasm section could probably be coded to be loaded like fcache and also use a specific set of registers for parameters too ...?
On that note I've never seen how to define a __pasm code section in C. There's no examples that I've seen and the docs don't say much I don't think.
@evanh said:
Eric,
I don't think there'd be much advantage to that, would there? a SETQ / RDLONG will fetch the parameters at 1 cycle/long once it gets going, the same as the time taken to load them with the FCACHE invocation.
I see you did figure out how to get __pasm going; it is pretty straightforward, and I think there are examples in the flexprop samples directory. It is an area where we could use more documentation.
Right, the plan was to make it a single fast burst copy. I was also hoping to find other additional hand optimisations along the way ... alas Ada pointed out my big oversight in doing the merge in the first place. Which made me decide I was chasing imaginary savings.
So I didn't even bother to find out why there was some massive overhead occurring in the first attempt.
Next idea, is there any easy way to port include/filesys/fatfs/ff.c to a spin2 object that Pnut can compile?
I've already ported the 4-bit SD mode driver to work with FSRW and co but those handlers are slow and old in comparison. So slow that Flexspin's SPI mode is a lot faster.
That's a good question. At one I was working on a "wrapper" mode that would produce Spin wrappers for the generated assembly code, with the intention that PNut could compile these -- this is triggered by the -w option of flexspin. But it never got finished, so I'm sure it's bit-rotted. You could try starting with the -w output and manually fixing it up, depending on how many entry points were required. The whole mechanism was intended to run in another COG though (it was originally for P1 where the Spin cog just isn't available) so it may or may not be useful for you. And -w is probably only practical for small objects, which ff.c isn't .
Hmm, it chews a lot of cogRAM, 105 longwords, that wouldn't really have any place to hide other than consuming almost half of the inline assembly caching space. I guess that's not an impossible layout.
Of that there is 9 var, 5 arg and 18 local registers. I know Pnut has 16 registers that are used for inline scratch space but I wouldn't know if they have any symbolic names. Not a big loss really.
@evanh said:
I had to compile from fatfs.cc to satisfy dependencies but I have got something - A 10,000 line source file. I'll look at it tomorrow.
Ugh, that sounds like it's probably a mess. I hate to say it, but the odds of it working are very low, given how incomplete the -w code is. You may be better off translating it by hand.
I tried to use Google's new AI mode and upload source file but it goes out to lunch on each attempt - Javascript Smile that's entirely unneeded. I looked at Claude too but that appears to need an account setup before it'll do anything.
EDIT: Ah, and ChatGPT won't take an upload without an account either, I wonder if that's Google's hang-up as well.
Eric,
I've just noticed, by reading programs written by others, that Spin2's longmove() can copy data from hubRAM to cogRAM - as a consecutive group of registers. Which is what I'm doing with my "presets", but I do it after entering the __asm{} code section in my C sources.
I've just noticed, by reading programs written by others, that Spin2's longmove() can copy data from hubRAM to cogRAM ...
That's interesting. In canonical [interpreted] Spin2 this is done with setregs().
Yes, and I know setregs() is not at all supported in Flexspin.
EDIT: Hehe, I'm not sure if longmove() is supported either now that I think about it ...
EDIT2: Okay, longmove() exists in Flexspin but works differently to Pnut. Placing an @ in front of a local variable converts it to stack stored variable in hubRAM. So then longmove() is solely a hubRAM to hubRAM copy only. Which also means those programs I've been reading are not Flexspin compatible.
So I'm using the right solution for Flexspin already.
I don't think the interpreter's longmove can move between cog and hub, I think it's only hub to hub. In the Spin2 interpreter all variables are kept in hub memory. They (or at least a subset of them) are temporarily copied to cog memory before ASM code executes, and then copied back afterwards.
Is there an equivalent to longmove() in FlexC?
memcpy() / memmove() would be the closest I think.
@ersmith said:
... In the Spin2 interpreter all variables are kept in hub memory. They (or at least a subset of them) are temporarily copied to cog memory before ASM code executes, and then copied back afterwards.
@ersmith said:
@deets : It's worth trying with the most recent github of flexspin/flexcc (7.6.0 beta). There was an uninitialized variable being used to determine structure packing which could cause different behavior on different machines, which lines up with what we see here.
Hey Eric,
after vacation and plenty of work and a messed up Linux PC that needed fixing I'm back on this. I've update to the latest commit
commit 4829fc4181ef0d0f12fae7b8dfaa7166ae051074 (HEAD -> master, tag: v7.6.1, origin/master, origin/HEAD)
Author: Eric Smith <ersmith@totalspectrum.ca>
Date: Sun Dec 14 18:46:21 2025 -0400
Updated spin2cpp
and tried the same setup as before. I did change a thing though: I added low level pin triggering to my debug arsenal. I hooked up a logic analyzer and can observe the same behavior as before: without the use of the rather big function to actually send data, things seem to work. However the moment I include that, I don't get any serial output anymore, and no SPI communication either. I do see my debug pin toggling as expected, so the top-level main code is executed as expected.
The code (all the same as before, with only the really minor modifications for adding the trigger pin) contains first a init-call, and then the attempt to send a buffer of data.
The init has two SPI transactions as consequences, and those are visible when not provoking the error.
But disappear (akin to printf) the moment I include the send code.
This points to this not being a progressive problem (internal data structures being overwritten over time causing mayhem), but instead a code generation issue - at least to my untrained eye.
Further investigation led to sx1268_lora_transmit being the culprit. If you look into that function, there's a big if-clause starting with
if (invert_iq_enable == SX1268_BOOL_FALSE) /* not invert iq */
and when I leave this within the code, the whole thing falls apart.
I attached the two versions of the p2asm where the differences are just that block being commented out.
Maybe the compiler runs into some register allocation limits or some such? I have no clue. Any other suggestions more than welcome.
@deets Could you upload the exact source code you used to create those .p2asm files, along with the flexspin command line you used? Also, what platform are you running on (WIndows 32 bits, Windows 64 bits, Linux Ubuntu, etc.)? There's no obvious reason that deleting code would change anything, and the generated code seems OK as far as I can see. IIRC correctly I was unable to reproduce your build last time, so I'd like to start by making sure that we are completely in sync -- any difference at all could be significant if it is a compiler bug. Which I'm still not completely convinced of: adding or deleting code changes where things are in memory, so a buffer overrun or bad pointer could be writing to a harmless location in one case and to some vital internal data structure in another.
Another thing you could try is instead of removing the if clause, make it always fail (in some non-obvious way, e.g. by testing a static variable that is always 0). That would also help to narrow down whether it's a compile time or run time issue.
struct __using("filesys/block/sdmm.cc") *SDMM;is located in _sdmm_open() function. That's where things are different.Ada/Eric,
struct __using()in the user code as opposed to buried in the headers.EDIT: On achieving identical API, splitting off _vfs_open_sdcardx() from _sdmm_open() would be in order. While _sdmm_open() would go into the driver, the legacy functions of _vfs_open_sdcard() and _vfs_open_sdcardx() could go back where they came from. And sdmm_vfs.c would be no more.
Eric,
__asm volatile {}code section. This is instead of the current approach of prefilling a structure and then copying the presets from there to cogRAM upon each inline entrance.I'm not seeing any way to do it without throwing away all locality. Also, I need to keep parameter passing feature of function calling so can't use a global __pasm code section.
Never mind, I took a stab and got it right. Tested and working as expected.
__pasm { testpasm mov pr0, #456 ret }Used an inline call to branch ...
... pr0 = 123; printf("testpasm=%d\n", pr0); __asm { call #testpasm } printf("testpasm=%d\n", pr0); ...Terminal output:
Here’s a crazy question …
Would it be possible to mix spin2 and basic code within one c file?
Sorta like the way you have pasm blocks?
Just wondering how impossible that would be…. Or, maybe already possible?
Guess could include as objects and be sorta the same thing?
That's what you need to do. Can't have different languages in the same object for various reasons.
SETQ / RDLONGwill fetch the parameters at 1 cycle/long once it gets going, the same as the time taken to load them with the FCACHE invocation.I see you did figure out how to get __pasm going; it is pretty straightforward, and I think there are examples in the flexprop samples directory. It is an area where we could use more documentation.
Things can get complicated with pasm in c…
Think sometimes gets loaded into cog first and other times just run via hubexec right?
include/filesys/fatfs/ff.cto a spin2 object that Pnut can compile?I've already ported the 4-bit SD mode driver to work with FSRW and co but those handlers are slow and old in comparison. So slow that Flexspin's SPI mode is a lot faster.
-woption of flexspin. But it never got finished, so I'm sure it's bit-rotted. You could try starting with the-woutput and manually fixing it up, depending on how many entry points were required. The whole mechanism was intended to run in another COG though (it was originally for P1 where the Spin cog just isn't available) so it may or may not be useful for you. And-wis probably only practical for small objects, which ff.c isn'tI had to compile from fatfs.cc to satisfy dependencies but I have got something - A 10,000 line source file. I'll look at it tomorrow.
Of that there is 9
var, 5argand 18localregisters. I know Pnut has 16 registers that are used for inline scratch space but I wouldn't know if they have any symbolic names. Not a big loss really.Ugh, that sounds like it's probably a mess. I hate to say it, but the odds of it working are very low, given how incomplete the
-wcode is. You may be better off translating it by hand.I tried to use Google's new AI mode and upload source file but it goes out to lunch on each attempt - Javascript Smile that's entirely unneeded. I looked at Claude too but that appears to need an account setup before it'll do anything.
Eric,
Hmm. Guess if longmove can copy to/from hub addresses below $400, could make that low hub useful for buffers and such...
oooooh, the penny drops. Thanks.
Hey Eric,
commit 4829fc4181ef0d0f12fae7b8dfaa7166ae051074 (HEAD -> master, tag: v7.6.1, origin/master, origin/HEAD) Author: Eric Smith <ersmith@totalspectrum.ca> Date: Sun Dec 14 18:46:21 2025 -0400 Updated spin2cppand tried the same setup as before. I did change a thing though: I added low level pin triggering to my debug arsenal. I hooked up a logic analyzer and can observe the same behavior as before: without the use of the rather big function to actually send data, things seem to work. However the moment I include that, I don't get any serial output anymore, and no SPI communication either. I do see my debug pin toggling as expected, so the top-level main code is executed as expected.
sx1268_lora_transmitbeing the culprit. If you look into that function, there's a big if-clause starting withand when I leave this within the code, the whole thing falls apart.
