Parallax USB Oscilloscope Software
in Accessories
I purchased a Parallax USB Oscilloscope 28014 about 10 years back but never put it to use. I would like to now, but do not have software for same.
I run Windows Vista 32 bit.
Can you help?
Can you help?
David
Sorry to hijack an old post. Will the above software attachments work in Windows 10 and Windows 11?
Probably the best way is to try it out.
Publison is only with us in spirit now so he won't be able to reply.
Doc
I just got a new windows 11 system old one died. While the software works just fine the driver for the PropScope does not load. Outdated FTDI driver.
It looks like someone at Parallax built the driver so maybe someone there can build a new one.
The PropScope is just a serial device after all and just need a serial driver with the correct VID/PID so that the software finds.
Alright, I uninstalled and reinstalled the driver from the PropScope install directory and it still was not working. And then all of sudden it showed up.
I guess after a while windows fixed it.
PropScope does work on windows 10 and 11.
