Array of Longs in PASM2 — Parallax Forums
JonnyMacJonnyMac Posts: 9,588
edited 2026-01-12 21:04 in PASM2/Spin2 (P2)
While making a suggestion in another post about putting an array into inline PASM (which works), I started some personal experiments and ran into a snag. In short, I'd like to access an array in PASM2 with a variable index, but code like I used to use in the P1 isn't working. Please -- gently -- show me where I've gone wrong. Thanks.
pub method(p_in, p_out)
  org
                        setq #(32-1)
                        rdlong array, p_in
                        mov       i, #0
loop                    mov       pntr, #array
                        add       pntr, i
                        setd      update, pntr
                        nop
update                  shr       0-0, #1                       ' NOT WORKING
                        incmod    i, #31                wc
        if_c            jmp       #loop
                        setq #(32-1)
                        wrlong array, p_out
done                    ret
array                   res       32
pntr                    res       1
i                       res       1
  end
  • TonyB_TonyB_ Posts: 2,259
    edited 2026-01-12 22:11
    Add another nop or
    altd is an alternative that doesn't require nop
    loop                    altd      i, #array
    update                  shr       0-0, #1
  • JonnyMacJonnyMac Posts: 9,588
    That did it. Thank you, Tony.
    edited 2026-01-12 22:27
    setd is an instruction I've never used but altd and alts I use a lot.
  • RaymanRayman Posts: 15,953
    RES in inline assembly? Surprised that works...
    One thing that trips me up a lot is only adding 1 to long pointers when need to add 4...
    I was surprised, too. Remember, we have about $120 (288) instructions available for inline assembly, so we do need to be mindful of that, and that variables defined with RES are going to end up with whatever is in the cog RAM at those locations.
    Yeah, that sometimes gets me, too.
    I was so excited about fixing with another nop that I jumped right to that. Then I popped back and saw the altd -- much nicer and saves a bit of code. This is the adjustment.
      org
                            setq #(32-1)
                            rdlong array, p_in
                            mov       i, #0
    loop                    altd      i, #array
    update                  shl       0-0, #2
                            incmod    i, #31                wc
            if_nc           jmp       #loop
                            setq #(32-1)
                            wrlong array, p_out
    done                    ret
    array                   res       32
    i                       res       1
      end
    Thanks, again!
    Jon, I think you are interested in PASM2 tips and the (untested) code below is optimal for speed. Two improvements: altd/alts/altr adds sign-extended S[17:9] to D (which leaves D unchanged for 9-bit #S) and rep repeats an instruction block by jumping back to the start in zero cycles.
      org
                            setq    #(32-1)
                            rdlong  array, p_in
                            mov     i, #0
                            rep     #2,#32
                            altd    i, s
                            shl     0-0, #2
                            setq    #(32-1)
                            wrlong  array, p_out
    done                    ret
    s                       long    1 << 9 + array  'add +1 to i in altd
    array                   res     32
    i                       res     1
      end
    edited 2026-01-13 02:19
    That's pretty nifty, Tony. I'll keep both in a recipe book as the first allows random access of array elements.
    I'm still learning how to decode Chip's notes in the PASM instruction list, althought Ada's docs make mention of auto-incrementing value. By using a traditional loop and debug I was able to see this working. Based on your comment, I did change the increment value. One thing... I was a little confused that # is not required with array in the line that declares s.
      org
                            setq      #(32-1)
                            rdlong    array, p_in
                            mov       i, #0
                            mov       j, #32
    loop                    debug(uhex_long(i))
                            altd      i, s
                            shl       0-0, #2
                            djnz      j, #loop
                            setq      #(32-1)
                            wrlong    array, p_out
    done                    ret
    s                       long      1 << 9 + array                ' add +1 to i in altd
    array                   res       32
    i                       res       1
    j                       res       1
      end
    Again, thanks!
  • One thing that trips me up a lot is only adding 1 to long pointers when need to add 4...
    @Rayman, thank you - me too - I was wondering why the whole buffer wasn't being processed!
