Fastest qrotate of an array in hubram?
I have a 1024 element buffer in hubram of x0,y0,x1,y1,x2,y2 .. x1023,y1023. I set x1023,y1023 to 1000,0. I'm attempting to fill the buffer with a sinewave, amplitude 1000 with this code:-
code sine ( array arraysize binangle -- )
mov PTRA,b
shl PTRA,#3
add PTRA,c
sub PTRA,#8 ' ptra points to last sample in the array
rdlong xx,ptra++
rdlong yy,ptra ' xx,yy loaded with last sample in the array
mov zz,a ' zz loaded with the intersample binangle
mov PTRA,c ' PTRA points to start of array
rep #3,#preload ' repeat preloading a number of x,y points into the cordic queue
setq yy ' yy = y value of sample
qrotate xx,zz ' rotate xx,yy by zz binangle
add zz,a ' zz = zz + binangle
' rep #7,#therest ' repeat reading rotated x,y + writing more points to cordic
' getqx r2
' wrlong r2,ptra++ ' store rotated x in array
' getqy r2 ' store rotated y in array
' wrlong r2,ptra++
' setq yy ' y value
' qrotate xx,zz ' rotate x,y, by zz angle
' add zz,a ' zz = zz + binangle
rep #4,#preload ' repeat reading the remaining points from the cordic queue
getqx r2 ' store rotated x in array
wrlong r2,ptra++
wrlong r2,ptra++
3DROP; ' tidy up the data stack
end
If I uncomment the middle section, 'sine' crashes. I suspect my timing is off and cordic results are being lost. Has anyone successfully done an 'overlapped' cordic on a large buffer in hub ram. Some sample code would be appreciated if you have. I'm tempted to learn some more Spin and rewrite in Pnut, but (I presume) you can't single step this code, it would still leave me guessing at what's wrong. (The cordic engine doesn't slow down during single step and results would be lost)
Cheers, Bob
I'd be looking carefully at where PTRA ends up addressing.
That could be it, @evanh , I'll comment out the cordic stuff and stick in some ptra monitoring to see where it strays outside the array
Possible PTRA related problems aside (are you allowed to use PTRA? In Spin2 inline ASM you wouldn't be, it's used as stack pointer! PTRB is free instead), this can't possibly work because of the CORDIC pipelining.
With
rep #3,#preload ' repeat preloading a number of x,y points into the cordic queue setq yy ' yy = y value of sample qrotate xx,zz ' rotate xx,yy by zz binangle add zz,a ' zz = zz + binangleyou're issuing commands very 8 cycles (every available slot). Meanwhile the following loop
rep #7,#therest ' repeat reading rotated x,y + writing more points to cordic getqx r2 wrlong r2,ptra++ ' store rotated x in array getqy r2 ' store rotated y in array wrlong r2,ptra++ setq yy ' y value qrotate xx,zz ' rotate x,y, by zz angle add zz,a ' zz = zz + binanglewould run slower and more importantly, inconsistently. The first GETQX stalls until a result is available, then WRLONG will stall an amount depending on the current slice alignment, which may even be more than 8 cycles, which makes GETQY run too late to grab the first result.
Generally speaking, instructions with variable timings do not belong in a pipelined CORDIC loop. In this case, it's easy to fix: Just use FIFO writes (WFLONG) - they run in constant time. You can also use FIFO for non-sequential read/write in constant time, but that requires even more asynchronous thinking.
You also need to add delays to the preheat section to match the main loop. You can also simplify the code a little by not having a trailing section to grab remaining results - it's generally fine to just let unneeded CORDIC results fall off the end. Problems only occur if an unrelated CORDIC operation starts while some calculations are still running. E.g. you return to high level code and it immediately wants to do a QMUL/GETQX pair. Then the latter won't stall and grab a stale result. If QMUL is started with a stale result available, but none in progress (-> waited long enough to be no longer in progress), it does properly discard that.
So it'd look a bit like this (untested)
wrfast #0,ptra ' Start write pipe rep #4,#preload ' repeat preloading a number of x,y points into the cordic queue setq yy ' y value qrotate xx,zz ' rotate x,y, by zz angle waitx #8-2 ' loop timing adjustment add zz,a ' zz = zz + binangle rep #7,#therest ' loop length is 16 cycles (14 code + 2 stall) setq yy ' y value qrotate xx,zz ' rotate x,y, by zz angle getqx r2 getqy r3 wflong r2 wflong r3 add zz,a ' zz = zz + binangleNot sure how many preheat loops you'd need - I think 4?
Point is, results become available 56 cycles after command issue. In this case, that's 3 and a half iterations of the loop, which makes everything a bit confusing.
Bonus: an actually working (and IMO beatuiful) example of CORDIC pipelineing from my texture mapping thing. (Take note that QDIV is the same as QROTATE w.r.t. timing/behaviour) This does a lot more in the loop, but I think it features everything talked about above. It is conveniently an exact 56 cycle loop, so it doesn't need to loop the preheat. Note how the instructions are mostly(?) grouped in multiples of 8 cycles. That makes it a bit easier to count.
' Preheat qdiv rasV,rasZ ' <- First V divide ' [...] some more prep code for U qdiv rasU,rasZ ' U ... ' [...] some more prep code for L qdiv rasL,rasZ ' and L work the same as V add rasU,slopeUX add rasV,slopeVX add rasL,slopeLX add rasZ,slopeZX ' advance some outer loop variables add currU,slopeUY add currV,slopeVY add currL,slopeLY add currZ,slopeZY mov ptrb,span_start shl ptrb,#1 add ptrb,screen_line testb span_start,#0 wc ' odd/even start pixel? bitnc .ditherptch,#0 ' always flipped another time add ras_pixels,span_length ' Just for keeping count ' advance some more outer loop variables add raster_pos,raster_unit add screen_line,screen_workstride add long_edge,slp_long add short_edge,slp_top 'waitx #(56-56)-2 (wait not needed due to sufficient stuffing of unrelated instructions into the gap) rep @.pipetex,span_length qdiv rasV,rasZ getqx tmpV ' <- this grabs the previous V divide (possibly from preheat), 56 cycles ago zerox tmpV,tex_wrapv mul tmpV,tex_stride qdiv rasU,rasZ getqx tmpU zerox tmpU,tex_wrapu add tmpV,tmpU qdiv rasL,rasZ getqx tmpL add tmpV,texturebase rdfast bit31,tmpV ' <- starts async read of the pixel add rasZ,slopeZX setpiv tmpL bitnot .ditherptch,#0 add ptrb,#2 add rasU,slopeUX add rasV,slopeVX add rasL,slopeLX rfbyte pixel wz ' <- at most 13 cycles later it appears in the FIFO ' this block is 16cy rdlut pixel,pixel .ditherptch mixpix pixel,dither_even rgbsqz pixel wrfast bit31,ptrb ' <- yes, you can just do this to get a constant 4 cycle random write if_nz wfword pixel .pipetex ' Remaining 3 results just drop off the endMany thanks, @Wuerfel_21 , that's given me plenty to think about. Some new instructions to learn about too, using your website. I'll post any success I have, here.
Under the forth system Taqoz, I can use PTRA without any precaution, but using PTRB requires a save and restore as Taqoz uses it.
I've just bought the P2 HD Audio Add-on Set, with a view to making a software defined radio with it. One of the simplest components in the signal processing path is a low frequency sinewave generator - hence the coding baby steps above.
The front end of the receiver is a multiplier which mixes the incoming signal with an RF signal generator (an SI5351 module, which I wrote a driver for some while back) The difference signal is low frequency, which is easily digitised by the stereo A/D converter and read into the P2 for further processing, typically in 1024 sample blocks.
Such a project would probably be more interesting to other folks written in SPIN + assembler, but for now I'm making a first few experiments in forth. I've used PNUT a little and the debugger, with all it's graphics windows, would be invaluable in visualising what's going on.
Another simple software module which would be used in quite a few places is a gain control module. The signal is input, each sample is multiplied by a scaling factor (sometimes constant, sometimes slowly varying) and the scaled signal appears at the output. Such a module is used for several functions, to scale the signal to avoid arithmetic overflow, in providing a volume control and in the automatic gain control section. These codes are often a very small loop, ideally to be run from COG or LUT ram. Such code might be loaded just once on switch on, or it might be necessary to load it in per main dsp cycle or maybe it's best left in HUB to keep things simple (if it's fast enough there).
Hi @bob_g4bby
Ptra is used as instruction pointer in Taqoz. So I am not sure, that it can be used freely in any case.
As far as I remember not with a code word, that resides in cog or lut.
Cheers Christof
PS You are aware, that rep does not work in hub? That is not true.
A bit off topic:
Cgracey has used a cordic machine directly to implement bandpass filters in his speech synthesis for P1. There is a good paper about this use of cordic somewhere in the net....
As far as I remember you directly sum the incoming signal into the rotating value and it will add up to resonance, if the phase is kept.
@"Christof Eb." PS You are aware, that rep does not work in hub?
To test that, I wrote:-
code reptest " >PUSHX" mov a,#0 rep #1,#10 add a,#1 ret end reptest .(Remove the quotes above - I don't know how to defeat the forum autoformatting)
The answer displayed is 10, so REP worked in that case?!
Ptra is used as instruction pointer in Taqoz Nevertheless,I think you can get away without saving PTRA:-
code ptratest ">PUSHX" mov PTRA,#1234 mov a,PTRA ret end ptratest .The result is displayed as 1234 and Taqoz returns the user prompt as per normal
Try the same thing with PTRB, though, then Taqoz will crash. You have to save and restore PTRB if you want to use that.
Thank you for the cordic paper reference, I'll look that one out, cheers Bob
Ok, sorry, rep does work in hub, that was wrong. It's skipf, that does not work in hub. (((I have not used Taqoz for a few months. )))
I think, that you are "lucky" with PTRA in this case and probably as long as you do not use cog or lut placement of the routine (which would probably be faster). Cog/lut routines are called directly and fast via short word codes.
In your case, PTRA seems to be popped from the return stack as part of the "code" overhead.
Edit: Yes, this is done by _CODE which jumps after the asm code to EXIT to restore PTRA .
You could easily use the hardware stack to save and restore ptra.
Sorry for the distraction. Christof
Mm, sounds like it's safest to push and pop PTRA
SKIPF and REP (and in general, all instructions that don't mess with the FIFO) both work in hub code, but without the ususal performance benefit. SKIPF also essentially turns into plain SKIP, which has slightly different effect w.r.t. ALTx type instructions.
