Catalina - C and Lua for the Propeller 1 & 2 - Page 24 — Parallax Forums
1181920212224»
  • RossHRossH Posts: 5,710
    @evanh said:
    Oh, man, forgotten how I got Catalina working on Linux previously ... I suspect I worked from something prebuilt ...
    See the document BUILD.TXT for instructions on building Catalina on both Windows and Linux. Linux is pretty straightforward.
    edited 2025-11-25 23:57
    I've just updated my earlier post (here) with a slightly improved version of payload. This new version is also on GitHub, and will be included in the next Catalina release.
    When using payload in 'dumb' mode on Windows, payload now maps the keyboard so that programs see the same input that they would see under a terminal emulator operating in vt100 mode.
    This makes programs such as Catalyst and the vi text editor (which are designed to work with a vt100 terminal emulator) work better under the Windows Console Host and the Windows Terminal app, which interpret some vt100 escape codes, but do not generate vt100 keyboard output.
    There are no changes to 'dumb' mode on Linux, since most Linux terminals already do this.
    Ross.
    sigh - Windows gets you every time :(
    I just discovered that to use ANSI escape codes in a Console Host window (i.e. what used to be plain old cmd.exe) now requires a registry setting. If you use the Terminal App instead of the Console Host, you don't need to worry about this. but I tend to still use the Console Host because it is both simpler and and faster than the Terminal App.
    Attached is a simple batch file to set or clear the appropriate registry setting. It will be included in the next Catalina release. In the meantime, just unzip it into Catalina's bin directory, and then to enable ANSI escape code processing enter:
    ansi_mode on
    or to disable it enter:
    ansi mode off
    To just check the current state enter:
    ansi_mode
    Note that because this is a registry setting, you only have to do it once. I made it possible to turn it on or off in just case it upsets other programs that use the Console Host window.
    Turning ANSI mode on makes the new version of payload (which adds 'dumb' terminal support) work properly in a Console Host window. Otherwise ANSI escape codes (e.g. used by Catalyst) will work when using the Terminal App, but not Console Host.
    Ross.
    I've put up a new Patreon video about Catalina's new smart "dumb" mode - see here.
    edited 2025-12-06 07:24
    I had a need to rebuild my Windows MinGW installation recently, which upgraded gcc to 15.2.0 (the most recent version). I found a few things in Catalina needed tweaking because this version of gcc raises errors in cases where previous versions did not. This does not affect any existing binaries, and there are no functional changes, so those who use Windows but do not need to rebuild Catalina don't need to do anything.
    I have uploaded the tweaks to GitHub, and will include them in the next release.
    Ross.
    An update: The problem is not with Catalina. It is with either the latest version of gcc or MinGW, or with Windows. More investigation required. I hope the problem is with gcc or MinGW, because I can get around those simply by reverting to a version that works. If the problem with with Windows, then it will be a lot more difficult to find, and may be impossible to fix.
    Just to repeat - the currently compiled Windows binaries (both on SourceForge or GitHub) are fine.
    Ross.
    Ha! Found it!
    The problem is with the expansion of wildcards on the Windows command line - a process known as 'globbing'. On Linux, the command processor always does this for you. On Windows you have to do it yourself, but gcc can also do it for you.
    What has happened is that in the current release of gcc/MinGW/Windows (not 100% sure which) globbing is apparently now turned off by default, whereas it used to be on by default.
    All I had to do was add the line:
    extern int _CRT_glob = 1; /* 0 turns off globbing; 1 turns it on */
    I have added this line near the top of the following files:
    • source\catalina\catalina.c
    • source\catalina\catbind.c
    • source\catalina\bcc.c
    • source\lcc\etc\lcc.c
    • source\lcc\cpp\cpp.c
    • source\lcc\src\main.c
    I will fix this on GitHub and also include it in the next release.
    Ross.
    Catalina 8.8.4 has been released on GitHub and SourceForge.
    This is a full release. It adds a 'dumb' terminal mode to payload, updates Cake and the VT100 test program (vttest), and a has few minor non-functional changes that allow Catalina to compile correctly with the latest version of gcc.
    Here is the relevant extract from the README.TXT:
    New Functionality
    1. Payload now has a 'dumb' mode, which is enabled by using the -I option
       but specifying either "dumb" or "none" as the terminal name (e.g. -Idumb
       or -I none). In dumb mode (after download, if a file is also specified)
       payload just echoes all characters received on the serial port to stdout,
       and all characters received on stdin to the serial port. Dumb mode can be
       terminated by entering TWO consecutive CTRL-D characters.
       As the name implies, in dumb mode, payload does not do any character
       processing on either input or output characters (except for detecting
       two successive CTRL-D characters) - If the Propeller program does any
       terminal-dependent stuff (e.g. cursor movement, screen manipulation,
       applying colors etc) this will work if that capability is implemented
       by the terminal window in which payload is executing. In general, this
       means many things will work quite smoothly (in Windows) using cmd.exe,
       conhost or the terminal app, or (in Linux) in any window type derived
       from an xterm.
       On Windows, the keyboard is assumed to be an extended ASCII keyboard,
       and the keyboard input is mapped to that which would be generated by a
       terminal emulator operating in vt100 mode. This is done so that programs
       see the same keyboard input when -I dumb is specified as they would see if
       either -i or -I vt100 was specified. This makes both the Windows Console
       Host and Terminal App behave more like a real terminal emulator in vt100
       mode when used with programs like Catalyst or the vi text editor.
    2. A new batch file (ansi_mode.bat) is included to set or clear the registry
       setting that enables processing ANSI escape codes in the Console Host
       window (this is enabled by default in the Terminal App). To enable ANSI
       escape code processing in Console Host enter:
          ansi_mode on
          ansi mode off
       Note that the setting will only affect NEW Console Host Windows, not
       the current window. To just check the current state enter:
           ansi_mode
        Because this setting is in the registry, this only has to do be done
        once, not on each login, or each time a Console Host window is opened.
        It can be turned off again if it upsets other programs that use the
        Enabling ANSI mode makes the new 'dumb' terminal option offered by payload
        work correctly in a Console Host window. Otherwise ANSI escape codes (e.g.
        used by Catalyst) work in the Terminal App, but not Console Host.
    Other Changes
    1. The vttest program, which is used to test vt100 compatibility, has been
       updated to the latest version. Note that this program is NOT required to
       use Catalina - it is a utility that can be used to test compatibility
       of various vt100 terminal emulators, including Catalina's terminal emulator
       (Comms.exe) as well as the Windows Console Host and Terminal App. See the
       README file in /source/comms/vttest for more details.
    2. There were two problems in the build scripts in /source/geany_bundle:
       1. The build_all script used the pacman cache. This only worked if the
          packages had already been downloaded. Now they are downloaded on each
          build.
       2. The option to unpack compressed packages is now --zstd, not -xz
       Affected Windows only.
    3. In the blackbox debugger, calls to the function blackbox_close() should have
       no parameters. This caused recent versions of gcc to throw an error. No
       functional changes. Affected Windows only.
    4. In awka, the function awka_init_parachute() was being defined incorrectly
       in error.c to accept parameters. This causes the latest versions of gcc to
       throw an error. No functional changes.
       Affected Windows and Linux.
    5. When compiling awka, the Catalina parallelizer and the Catalina optimizer
       with the latest version of gcc, the option -std=c99 must be added for
       the programs to compile correctly. No functional changes.
    6. When compiling lcc with the latest version of gcc, the definition of
       _spawnvp() must be changed to match that in stdio.h for the program to
    7. There is an issue with the current version of gcc/MinGW on Windows, which
       means that 'globbing' (expansion of wildcard characters on the command line
       was disabled by default. It can be manually re-enabled for programs that
       need it by including the following line near the top of the main program
       file:
    8. There is an issue with versions of gcc which reserve the keyword
       "constexpr", which was used by LCC as an identifier. This has now been
        changed in LCC to "cnstexpr". No functional changes.
    9. Non-C89 compatible comments in LCC (i.e. introduced using //) have now
       been replaced with C89-compatible comments (i.e. /* ... */). No functional
       changes.
    10. There is an issue in MinGW32 that means some programs may fail to compile
       with gcc when an old version of libwinpthread-1.dll exists in the PATH.
       An error message that "clock_gettime64" was not found is generated.
       The current fix is that "libwinpthread-1.dll" in Catalina's bin and
       catalina_geany/bin directories have been replaced with the latest version.
       However, in case this fix causes other problems, the old version are still
       included, but have been renamed to "libwinpthread-1.dll.old".
    Catalina 8.8.5 has been released on GitHub and SourceForge.
    This is a full release. The impetus for this release was the recent release of both Lua 5.4.8 and Lua 5.5.0. Lua 5.4.8 is the latest and greatest stable Lua release, while Lua 5.5.0 is the first of the next generation of Lua releases - interesting, but not mature or stable enough just yet to make it the default. However, while testing Lua 5.4.8 I found some issues that needed fixing, and also did some preparation work for the changes that will be coming in Lua 5.5.X.
    New Functionality
    1. Lua 5.5.0 has now been included in this release. However, Lua 5.5.X is not
       yet mature or stable enough to replace Catalina's fully integrated
       version, which remains at 5.4.X. However, Lua 5.5.0 is fully functional
       when used stand-alone, apart from the capabilities enabled by defining the
       ENABLE_PSRAM or ENABLE HYPER Catalina symbols when compiling Lua. Those
       capabilities are deeply embedded in the internals of Lua 5.4.X, were
       developed before the more general capability of using PSRAM as XMM RAM
       was added, and are deprecated in this release. They are likely to be
       dropped altogether in the next Catalina release.
       To build Lua 5.5.0, go to the folder demos\catalyst\lua-5.5.0 and use the
       build_all script in the same way as used to build Lua 5.4.X. For example:
          build_all P2_EDGE SIMPLE VT100 MHZ_200 OPTIMIZE
       To copy all the executables to an SD card, use the copy_all script. Note
       that this script will supersede any existing Lua binaries and programs on
       the SD Card. For example, if drive the SD Card is detected as drive H, the
       command to enter would be:
         copy_all h:
    2. The version of Lua fully integrated into Catalina has been updated from
       version 5.4.4 to 5.4.8. There is no new Lua functionality in this update,
       just a few Lua bug fixes. However, there have been some minor tweaks to
       some example programs as a result, mainly the multi-processing with Lua
       examples. This is because the changes may not affect Lua's functionality,
       but they do sometimes affect Lua's memory utilization. The updated example
       programs now work with both Lua 5.4.X and Lua 5.5.X.
       Note that the compiled (i.e. binary) format of Lua programs has changed
       between versions 5.4.X and 5.5.X. This means that the corresponding version
       of the lua compiler (luac) must be used. If the wrong version is used, the
       following error message will be displayed:
         bad binary format (version mismatch)
    3. There are now only two copies of the Lua 5.4.X source files in this release
       of Catalina (in previous releases there were three copies). The Lua source
       files that used to be in demos/catalyst/lua/5.4.X are now copied from
       source/catalina/lua-5.4.X when Catalyst is compiled using the build_all
       scripts, and deleted again by the clean_all scripts (similar to the way
       the self-hosted version of Catalina itself is built). Note that when the
       Windows installer is used to install Catalina, this means that to compile
       Catalyst from source, the Catalina sources MUST be installed. This option
       is now the default.
       A copy of the Lua 5.4.X source files still exists in the library source
       tree. This duplication is likely to remain so that the stand-alone version
       of Lua can be updated independently from the integrated version.
       Note that when Lua is built as part of Catalina (it is used for scripting
       in both payload and blackbox) the standard Lua Makefiles are used. When it
       is built as part of Catalyst, the Makefiles in the src folder are used
       (Makefile.Catalina on Linux, or Makefile.Catalina.mgw on Windows).
    4. Partly in anticipation of Lua 5.5.X becoming Catalina's default integrated
       version of Lua, the multiple different versions of the Lua initialization
       file (variously called linit.c, iinit.c or xinit.c) which enabled different
       Lua libraries in previous releases have all been replaced with a common
       version (linit.c). In this release, this file must still be present and
       compiled in the same folder as the Lua application, but this will change
       in Lua 5.5.X, which uses a different initialization process).
       Specific libraries to be enabled or disabled are now specified on the
       Catalina command line (or in a catapult pragma) as follows:
         propeller  always enabled
         hmi        always enabled
         threads    enabled by -lthreads
         serial     enabled by -lserial2 or -lserial8
         wifi       enabled by -lwifi
         service    enabled by -C LUA_SERVICE
         linenoise  enabled by -C LUA_LINENOISE
         If memory is very tight, the optional debug, utf8 and os libraries can
         be disabled by -C LUA_NO_OPT, and if only integer math is required then
         the math library can be disabled by -C LUA_NO_MATH - but neither of
         these are used in any of the demo programs, and doing so is deprecated
         because these options will not be available when Lua 5.5.X becomes the
         default version of Lua.
    Other Changes
    1. There was a bug in the Multiprocessing versions of Lua (i.e. mlua and
       mluax) that may have led to a program lock-up when multiple factories were
       in use (for example, it may have occurred when executing the example
       programs ex9.lua or ex12.lua). Affected the Propeller 2 only.
    2. There was a bug in Catalyst that limited commands to 8 characters when
       no extension was specified. So (for example) the program "bin/dbasic.bin"
       would be correctly found and executed if the command was entered as:
          dbasic
          dbasic.bin
          bin/dbasic.bin
       but NOT if entered as:
          bin/dbasic
       Instead, "cannot open file BIN/DBASIC" would be displayed.
       Affected the Propeller 1 and Propeller 2.
    3. Some Lua programs have been updated to allow for the use of either Lua 5.4
       or Lua 5.5. In particular, Lua 5.5 requires different parameters to the
       collectgarbage() function. The following code takes the lua version into
       account, and can be used set a specific garbage collection mode and/or
       parameters in a way that is backwards compatible:
          lua_version = tonumber(string.sub(_VERSION, 5, 7));
          if lua_version and lua_version < 5.4 then
            -- default mode is incremental, so just set parameters ...
            collectgarbage("setpause", 150);
            collectgarbage("setstepmul", 500);
          elseif lua_version and lua_version < 5.5 then
            -- incremental mode is optional, so set it with parameters ...
            collectgarbage("incremental", 150, 500);
          else
            -- mode and parameter setting now separate in Lua 5.5 ...
            collectgarbage("incremental");
            collectgarbage("param", "pause", 150);
            collectgarbage("param", "stepmul", 500);
          end
    4. To minimize Lua's use of memory, the threads functions wait() and workers()
       also used to do garbage collection in previous releases - this was done to
       collect garbage after workers and threads had been initiated. However, a
       better solution is to do this explicitly if needed, and also for threads
       themselves to be able to perform garbage collection if required, so a new
       "thread safe" function for invoking the Lua garbage collector has been
       added to the threads module. The threads.gc() function can combine the
       functionality of collectgarbage() and threads.sbrk() (which are often used
       together to maximize free Lua memory and also defragment the C heap) into
       one function. See the updated "Lua on the Propeller 2 with Catalina"
       document for more details. The example program ex9.lua demonstrates the
       new function. If backwards compatibility is necessary, Lua code such as
       the following can be used to detect if the threads.gc() function is
       available or not:
          if threads.gc then
             threads.gc(1) -- also invokes sbrk(true)
          else
             -- note: not guaranteed thread safe ...
             collectgarbage()
             thread.sbrk(true)
          end
    5. Upgrading to Lua 5.4.8 has made some programs that used the integrated
       version of Lua (i.e. the version in the Catalina library) slightly larger,
       which may cause the program to run out of Hub RAM. For example, the Aloha
       WiFi RPC demo program sluarfx.c is now too large to execute correctly if
       compiled in NATIVE mode, and so has been replaced by the functionally
       identical program slaurcx.c which instead uses COMPACT mode.
       This change may affect other programs. Affected the Propeller 2 only.
    6. The 'Aloha from Lua' document mentioned that the rpc_network table could
       be in the common.lua module, but in the RPC demo programs the table was
       instead duplicated in the server.lua, remote.lua and serverbg.lua modules.
       While this is technically ok, it complicates the process of configuring
       the demo programs. Now, the document and all the demo programs have been
       made consistent, with only one copy of the rpc_service table in the
       common.lua module. Affected the Propeller 2 only.
    7. There were a couple of issues with the WiFi version of ALOHA:
        (a) There was an undocumented limitation on the size of an WiFi RPC
            request. The code currently limits such requests to a maximum of 512
            bytes (the RPC response can be larger). This limit caused one of the
            demo programs (i.e. the 'complete' demo) to work with the serial
            version, but not the WiFi version because the string used was too
            long. The example has now been corrected to work with both, and the
            'ALOHA from Lua' document also has been updated. This limit may be
            increased in a future release.
        (b) The Lua dispatcher could fail to retrieve all data returned by an
            RPC call when the response consisted of multiple data packets.
    edited 2026-01-27 10:46
    I just pushed an update to Catalina's ENABLE_HYPER and ENABLE_PSRAM Lua options to github.
    I had intended to deprecate these options, but it turned out that adding them to Lua 5.5.0 was trivial, and also Lua 5.5.0 claims to substantially reduce Lua's run-time data requirements, which means these options (which allow larger Lua code sizes without the performance hit of using XMM RAM) may turn out to be very useful in Lua 5.5.X.
    These options provide an alternative way to use PSRAM to Catalina's normal SMALL and LARGE XMM options, which use the PSRAM or HYPER RAM as general-purpose external memory. Instead, these option build a special version of Lua that uses the PSRAM as a dedicated cache for Lua code only. These options are described in the Catalyst Reference Manual. Using PSRAM as XMM RAM is easier and more flexible - it is but also much slower. The ENABLE_PSRAM and ENABLE_HYPER options help fill a significant gap in the performance/size tradeoff.
    To illustrate this, here is a comparison of a trivial Lua fibo benchmark program, executed with Lua 5.5.0 and using various memory configurations. I have normalized the results so that the fastest mode is 1.0:
    • NATIVE : 1.0 uses only Hub RAM. Max Lua code and data ~85kb
    • NATIVE with ENABLE_PSRAM : 1.3 uses PSRAM for Lua code and Hub RAM for Lua data and C code and data. Max Lua code 16Mb. Max Lua data ~75kb
    • COMPACT : 4.5 uses only Hub RAM. Max Lua code and data ~245kb
    • COMPACT with ENABLE_PSRAM : 5.9 uses PSRAM for Lua code and Hub RAM for Lua data and C code and data. Max Lua code 16Mb. Max Lua data ~240kb
    • SMALL : 8.7 uses PSRAM for C code and Hub RAM for C data and Lua code and data. Max C code ~15.5Mb. Max Lua code and data ~465kb
    • LARGE : 13.5 uses PSRAM for C and Lua code and data. Max C and Lua code and data ~15.5Mb
    EDIT: Added NATIVE with ENABLE_PSRAM
    EDIT: Fixed SMALL Max sizes.
    Oops! The Catalina 8.8.5 packages on Sourceforge contain an extraneous directory that can prevent Lua 5.5.0 from compiling. This does not affect GitHub.
    I have updated the packages, but if you have already downloaded them you do not need to do so again - all you need to do is remove one (empty!) directory:
    To do so, open a Catalina command line window and then (on Windows):
    rmdir "%LCCDIR%\demos\catalyst\lua-5.5.0\src\catalina"
    Or (on Linux):
    rmdir "$LCCDIR/demos/catalyst/lua-5.5.0/src/catalina"
    I have pushed another bunch of small updates to GitHub. Catalina's Multi-processing extensions to Lua are not Propeller specific - they should also work when Lua is compiled natively for Windows or Linux (in which cases they use Posix threads in place of Catalina threads).
    However, I had not tested this with Lua 5.5.0 and had not realized that this version of Lua made some internal changes which my extension modules also needed to adopt to make them compile correctly with gcc (they compiled correctly with Catalina).
    A few minor tweaks and the versions of Lua with Multi-processing extensions (i.e. mlua and mluax) now also work on Windows and Linux again in Lua 5.5.0 (they already worked on the Propeller).
    However, I also found that Multi-processing Lua example 6 (i.e. ex6.lua) contains a race condition, which is exposed in the Linux version (it does not seem to affect the Propeller or Windows versions). I will have to have a think about this one - the problem is inherent in Posix condition variables, not in Lua or Catalina. If I can't fix this example, then I will include a new one in the next release.
    Ross.
    edited 2026-02-07 07:10
    Here is an updated version of ex6.lua - it is functionally identical to the previous versions, but eliminating the race condition has made it a little more complex. However, it now works properly on the Propeller as well as on Windows and Linux:
    t = threads
    -- we want four simultaneous threads
    t.workers(4)
    -- here is how we will identify them, which
    -- is also a string for each one to output
    eeny  = "eeny "
    meeny = "meeny "
    miney = "miney "
    mo    = "mo\n"
    -- we need four condition variables
    -- (one for each thread)
    t.condition(eeny)
    t.condition(meeny)
    t.condition(miney)
    t.condition(mo)
    -- generate a thread function
    function Thread(me, next, count, last)
       return function()
         t = threads
         repeat
            t.lock(me)
            t.update(me, true)
            t.wait(me)
            t.update(me, false)
            t.unlock(me)
            t.output(me)
            count = count - 1
            if (count > 0) or not last then
               next_ready = false
               while not next_ready do
                  t.lock(next)
                  next_ready = t.shared(next)
                  t.unlock(next)
               end
               t.signal(next)
            end
         until count == 0
       end
    end
    -- wait till a thread is "ready"
    -- (i.e. waiting on its condition variable)
    function wait_till_ready(this)
       local this_ready = false
       while not this_ready do
          t.lock(this)
          this_ready = t.shared(this)
          t.unlock(this)
       end
       return this_ready
    end
    count = 20
    -- create the threads
    t.new(Thread(eeny,  meeny, count, false))
    t.new(Thread(meeny, miney, count, false))
    t.new(Thread(miney, mo,    count, false))
    t.new(Thread(mo,    eeny,  count, true))
    -- wait till eeny is "ready"
    wait_till_ready(eeny)
    -- kick things off
    t.signal(eeny)
    -- wait for threads to complete
    t.wait()
    This version is now on GitHub, along with an updated description in the Lua on the Propeller 2 with Catalina document.
    Ross.
    EDIT: Thought I'd add a brief explanation here as to why this version eliminates the race condition. The key is to lock the condition mutex each and every time you access the condition (which in this version is now a shared variable rather than the condition variable itself).
    For example:
    t.lock(next)
    t.unlock(next)
    What this does is guarantee that the "condition" (represented here by the shared variable "next") is not in the process of changing when you access it - i.e. the lock ensures that any change is completed before you are given access (your process is stalled if required until this is true). That's all that's needed - but without that you can (in this instance) retrieve a "condition" of true when in fact it is not yet true, but will be almost immediately afterwards. This is a classic race condition! - if the thread execution is interleaved at exactly the wrong instant, you are in fact working with the wrong information, and the result is usually a deadlock!
    This stuff is hard ... but interesting and necessary ... if you want to do parallel processing :)
    edited 2026-02-12 01:10
    I just pushed a few updates to the catapult and eLua/ALOHA demos to GitHub. Here is the summary:
    • Implement a new FIXED_ARGS Catalina option, which enables the allocation of the maximum memory that might be required for command line arguments, rather than the actual memory used. Note that FIXED_ARGS has no effect if NO_ARGS is specified for the same compilation.
    • Add -C FIXED_ARGS to all catapult primary program compilations.
    • Fix the use of alloca() in various catapult and ALOHA demos so that the catapult memory buffer allocation does not depend on the command-line arguments.
    • Add a new catapult demo (demos/catapult/lua_lua) to illustrate that the primary and secondary programs can both be instances of Lua, and that the secondary can be multi-threaded (typically, the primary cannot because it executes from XMM RAM).
    Note that the new catapult demo is a different thing to eLua - eLua implements a full-blown client/server architecture between potentially many Lua instances, which can be running on different Propellers connected by serial or WiFi connections. The new demo is much smaller (and much simpler) because the two instances of Lua run on the same propeller and (apart from sharing data via Hub RAM) otherwise execute independently.
    Catalina 8.8.6 has been released on GitHub and SourceForge.
    This is a full release. This release has a few minor enhancements, fixes a bunch of minor issues, and adds a demo of eLua to the pre-built binaries.
    New Functionality
    1. If a compiled version of a Lua module exists, it is now loaded in
       preference to the uncompiled version - e.g. given 'require "module"'
       Lua will now try to load "module.lux" and load it if it exists,
       otherwise it will try "module.lua". The full search path is now:
           ?.lux; ?.lua;
           ?/init.lux; ?/init.lua;
           lua/?.lux; lua/?.lua;
           lua/?/init.lux; lua/?/init.lua
       This search path can be set using the environment variable LUA_PATH,
       so to revert to the previous behaviour use the Catalyst command:
           set LUA_PATH="?.lua;?/init.lua;lua/?.lua;lua/?/init.lua"
    2. When the Catalyst pre-built demos are built for a Propeller 2 platform
       with XMM RAM (i.e. the P2_EDGE or P2_EVAL) then eLua is now also built
       (i.e. elua, elaux, eluafx, eluas, eluasx). An eLua demo of the Game of
       Life is also copied into the folder 'life'.
       See the file life/README.TXT for details on executing this demo. In
       particular, note that 'exec life/rebuild' must be executed before
       the demo can be executed.
    3. The catapult and elua/ALOHA demos now allow fixed length path names of up
       to 128 bytes instead of just a DOS 8.3 file name. This allows eLua/ALOHA
       programs to be put into folders. The pre-built demos for the Propeller 2
       now contain an example of doing this - i.e. the Game of Life eLua demo in
       folder 'life'.
    Other Changes
    1. The build scripts for the P2_EDGE and P2_EVAL Catalyst demos were
       building cake to use a serial HMI even when compiling the VGA demos.
    2. There were issues with catapult programs that accepted command line
       arguments. The size and number of arguments could change the memory
       addresses allocated in the program, requiring it to be recompiled in
       each case. This has now been fixed by the addition of a new Catalina
       option -C FIXED_ARGS, which forces the program to always allocate the
       maximum possible number of bytes for command line arguments even if
       none were specified or supported. In cases where no command line
       argument support is required, This can be disabled using the existing
       option -C NO_ARGS. Affected the Propeller 2 only.
    3. Several of the catapult demos, including the ALOHA demos, were allocating
       hub RAM for file names BEFORE allocating the catapult memory buffers,
       which meant that the buffer addresses could change depending on the
       command-line arguments. All the demos now always allocate a fixed amount
       of Hub RAM to hold the file names so that the catapult buffers will
       always have the same addresses. Affected the Propeller 2 only.
    4. Updated the 'Aloha from Lua' document to match the current version of the
       Lua initialization file (linit.c).
    5. It was possible for the Serial ALOHA protocol to overrun the serial buffers
       in the case of large messages. Now a delay has been added when transmitting
       (defaults to 5ms every 16 characters, but it can be adjusted in aloha.c).
    6. Recent Lua updates have changed the size of Lua executables, and hence the
       size of Lua programs that can be executed from Hub RAM. The 'Game of Life'
       eLua demo is now too large to be executed with 'sluafx', but since it does
       not need floating point it can still be executed using 'sluafix'. The
       'Aloha from Lua' document has been updated accordingly.
    7. Removed all "just update version number" type comments - they served no
       useful purpose and just consumed space (especially in Lua scripts).
    8. Use $* in place of $1 $2 $3 ... $9 and %* in place of %1 %2 %3 .. %9
       wherever it is feasible to do so. This is necessary because Catalina now
       has so many symbols that may need to be defined on a command line (usually
       in scripts) it is now possible that more than 9 parameters need to be
       specified.
    While Linux users can easily rebuild Catalina from source, building Catalina on Windows is still such a painful process that I don't expect anyone but me ever bothers doing it. I am also sure most Windows users use the installer rather than cloning GitHub, so I have decided to simplify things by just including the Windows installer as a GitHub asset, instead of re-bundling the Windows binaries separately (I also realized I had made some silly mistakes in these bundles in the past, whereas the Windows installer is pretty thoroughly tested before each release).
    Catalina now incorporates everything I need for Propeller development, so apart from expected forthcoming Cake and Lua updates, the next few releases will probably only be for bug fixes.
    Ross.
    edited 2026-02-25 00:55
    I just posted a brief video on Patreon (here) to show how to execute the new eLua demo, which requires a terminal window size of 80x30 (i.e. 80 columns and 30 rows) to display correctly.
    Some Windows users have had trouble, probably because they use payload with the default terminal emulator settings, which sets the window size to 80x24 - and the terminal size can't be adjusted once payload starts.
    The solution is to either use a slightly more sophisticated vt100 terminal emulator, or use payload with the -Inone option, which disables its internal terminal emulator.
    Ross.
    edited 2026-03-02 07:39
    As discussed in this thread, attached is a zip file containing the coremark benchmarking program ported to Catalina.
    Unzip it into a directory such as demos/coremark and see the file CATALINA.TXT for more details.
    Ross.
  • Catalina is an open-source C compiler for Propeller 1 & 2 that also runs Lua (5.1.5 & 5.4.3). It supports embedded scripting, standalone Lua, and multi-threading with minimal RAM use. Catalina 5 adds full Lua multi-threading and pthreads-style support. Mac isn’t officially supported.
    edited 2026-03-04 04:46
    The current supported versions of Lua are 5.5.0 (the latest release) and 5.4.8 (the most stable release). The officially supported platforms are Windows and Linux (including Pi Os). Mac was supported by early Catalina releases, but I stopped supporting it when it became impossible to do so without actually owning a physical Mac, which is beyond my budget :)
