Hardware stack — Parallax Forums
Hardware stack
In my ongoing quest to understand the P2 better level, I was wondering what about this 8-level hardware stack for fastest subroutine calls/returns and push/pop operations. And later K / Stack: The 8-level hardware stack used for subroutine calls (stores C, Z, and PC) and temporary 32-bit push/pop storage.
Does this mean that there's some extra ram in each cog that can hold 8 call frames for CALL/RET pairs? What happens if the call stack is deeper than 8? The Propeller-2-Assembly-Language-PASM2-Manual-20221101-1.pdf doesn't seem to mention this.
It seems that the CALLA and friends is a bit better described as it is all relative to a pointer to hubram.
  • TonyB_TonyB_ Posts: 2,254
    edited 2025-11-11 15:43
    Each cog has its own 8-level 32-bit hardware stack that will wrap around if stack level deeper than eight, which is unlikely to occur. HW stack is implemented in a logic as a big shift register and there's no stack pointer.
    During skip sequences a CALL suspends skipping until there is a RET back to the same stack level as the CALL. This means a CALL counts as only one skip instruction and calls can be nested.
    CALLA & CALLB are different from other CALL instructions as they use hub RAM for the stack with PTRA & PTRB as stack pointers. Note that stack grows upwards.
  • TMMTMM Posts: 22
    I understood the rest of your post. I've read this part several times now and looked up the SKIPF and SKIP instructions again to refresh my memory. However I really do not understand this section at all :sweat_smile:
    Could you give me a more step by step explanation? I had found no correlation between CALL/RET pairs and SKIPs, I'm quite confused.
    Thank you!
    edited 2025-11-11 18:05
    Thank you!
    If you never use SKIPF then you can ignore the rest of this message.
    Below is part of the rotate/shift code for an 8086 emulator. Most of these 8086 instructions have a direct P2 equivalent that can be used for multi-bit rotate/shift. However, multi-bit byte or word RCL and RCR cannot be done by a single P2 instruction. The code below shows eight of 32 skipping instructions that follow a SKIPF. I can spare only one instruction each for 8086 RCL & RCR but that is all right as each P2 CALL counts as a single skipping instruction. Skipping is disabled inside RCL_dest_count and RCR_dest_count and both of these routines could contain a CALL to call a nested subroutine, which itself could also contain a CALL, etc.
    The skipping logic keeps track of the hardware stack level and after the RET or _RET_ at the end of RCL_dest_count or RCR_dest_count the HW stack level will be the same as it was when the initial CALL was made and therefore skipping will resume. The a-h and A-H comment characters are used to automatically create the correct skipping patterns for byte and word data width, respectively, using a program I've written.
    Conclusion: CALL and its associated subroutine (no matter how long) counts as only one instruction during skipping sequences, which makes skipping much more powerful.
    rol     dest,count          wc  'a||||||| A|||||||  c = CF
    ror     dest,count          wc  '|b|||||| |B||||||  c = CF
    call    #\RCL_dest_count        '||c||||| ||C|||||  c = CF
    call    #\RCR_dest_count        '|||d|||| |||D||||  c = CF
    shl     dest,count          wc  '||||e||| ||||E|||  c = CF
    shr     dest,count          wc  '|||||f|| |||||F||  c = CF
    mov     dest,FFFF           wc  '||||||g| ||||||G|  = -1, nc
    sar     dest,count          wc  '|||||||h |||||||H  c = CF
  • TMMTMM Posts: 22
    I understand now what you were trying to say! Thank you!
    I suppose that if you try to skip or skipf in a function being called then things will go very wrong?
    Yes, subroutines called from a skipping sequence cannot themselves use skipping because that will destroy the original remaining skip bits. There is only one level of skip bits.
    Ideally a future P3 or P2+ would have 64-bit wide stack so that skip bits could be pushed and popped and each stack level could support skipping.
  • TMMTMM Posts: 22
    That makes sense, yes! Thanks for all the explanations!
