90's style 3D (Now with Music and Sound Effects!!) - Page 6 — Parallax Forums
12346
  • @evanh said:
    @rogloh said:
    ... Be good to locate that so it's reliable/not broken on flexspin but I know it's someone else's codebase.
    To be fair to the original author, Kye, he wrote it in Spin1 for the Prop1. It's since been ported to Spin2.
    Yes I noticed. There probably is some sort of timing dependency built in there somewhere that varies depending on the compiler. I'd expect it to be in the lower level part that touches the SD card, not the FAT part.
  • evanhevanh Posts: 17,146
    That's possible too. My fix up in bashed3 wasn't exactly thorough.
  • RaymanRayman Posts: 16,197
    Got wall tiles working in exmem. This is a big step. Allows for actual game...
    Had to rotate wall tile images 90 deg CCW to make simple...
    Guess soon time to work on sprites...
    Havent' tried this latest version but I found that after a bit of walking about for a while in the map the two screen side by side halves started to diverge into noticeable separate windows. Might be some co-ordinate error accumulation over time causing rendering issues..
    Interesting… there are two cogs, one for each half so suppose that is possible…
    Might need better coordination…
    Guess needs more testing.
  • Yeah they seem to be getting out of sync over time when you navigate the map for a while - doesn't show up immediately but doesn't take long to happen either.
    If the symptom was one vertical line being wrong in center of screen, that was a bug, fixed in latest version above...
    Think will try to put floor tiles in exMem too. Need to read in single words for that one.
    Guessing should use: R_READWORD = %1001 << 28
    But, don't really know how or why...
    Is better in any way from readburst?
    Is the usage the same?
    Guess floor tiles in exMem is pointless unless also add a map so can have several floor tiles in the map...
    They are different.
    You can choose to read individual words into the mailbox data location itself, or you can read a burst of multiple words into some arbitrary specified HUB address. It's all documented. If you have consecutive words to read it'll be a lot faster to use the burst method, because every mailbox request operation incurs the polling and address setup overhead. But for a single item being read it's marginally faster to use a single word read over a burst. If required there is also the atomic Read-Modify-Write operation possible too using new data and a bitmask in the second and third mailbox parameters.
    edited 2025-10-16 20:30
    Ok, reading words from exRam to do floors is not going to work.
    It's just too slow and sometimes most of the screen is tiles.
    But, was able to add a floor tile map so can have several different floor tiles.
    This example is with four floor tiles in HUB RAM.
    Think there is room at the moment for 12.
    But, there are still things to add like sprites and sound.
    Think sprites can be in exRam, because they work a lot like walls. So, grab 64 pixels at a time.
    Sound can probably be in uSD.
    Just added AI generated splash screen to show at start up.
    Instead of using a VAR for display buffer, now using this file as an embedded bitmap.
    It just gets written over when game starts.
    Nice to have it showing something at t=0.
    Unfortunately, my monitor is taking a few seconds to think about the VGA signal it's getting before displaying it,
    so had to add a delay so can actually see the splash screen.
    320 x 240 - 123K
    Fixed a bug with floor map. Seems it was missing a couple rows.
    Also, looked to see what happens if there are no interior walls, so all floor cast.
    It is not good.
    But, this works:
    fMap            byte    "BBBBBBBBCCCCCBBBBBBB"
                    byte    "B         C        B"
                    byte    "C         C        B"
                    byte    "C         C        B"
                    byte    "A         C        B"
                    byte    "A         C        B"
                    byte    "B                  B"
                    byte    "B         C        B"
                    byte    "C         C        B"
                    byte    "F AAAAAAAAAAAAAAAAAB"
                    byte    "E         D        B"
                    byte    "F         D        B"
                    byte    "D         D        B"
                    byte    "B         D        B"
                    byte    "B         D        B"
                    byte    "B         D        B"
                    byte    "B         D        B"
                    byte    "B         D        B"
                    byte    "B         D        B"
                    byte    "BBBBBBBBBBBBBBBBBBBB"
    Guess that's OK.
    You may be able to make use of the request list feature if you have a group of items stored in PSRAM (like tiles or sprites) that need to be read to hub. You can prepare a list of memory addresses and submit it to the driver and it will go off in the background and retrieve them for you (or write them to PSRAM). If you can overlap this with other non external memory work to be done by the COG you can get better utilization in the code. It may or may not be of use in this case, but still useful to be aware of.
    Yep, so typical, the hardware will be sync'ing in a couple of frames but the management software inserts a couple of seconds of blank screen just to be annoying.
    Started implemented sprites.
    Now have one, single pixel wide sprite going.
    Seems if make sprites 64-pixels tall, then can reuse the wall drawing subroutine to draw the sprites.
    This is a huge speed benefit.
    Now implementing sprite calculations in another cog (still one left for audio).
    QVector instruction turns out to be very useful there:
    DAT
    org 0
    SpriteEntry
                    mov     ptra,pPlayer
                    mov     ptrb,pSprites
    SpriteLoop
                    waitatn
                    rdlong  fplayerx,ptra[0]
                    rdlong  fplayery,ptra[1]
                    rdlong  fspritex,ptrb[0]
                    rdlong  fspritey,ptrb[1]
                    'calc angle and distance to sprite (fixed at (256,256) for now)
                    mov     fspritex, #256
                    sub     fspritex,fplayerx
                    mov     fspritey, #256
                    sub     fspritey,fplayery
                    qvector fspritex,fspritey
                    getqy   spritearc
                    shr     spritearc,#16
                    mul     spritearc,##ANGLE360
                    shr     spritearc,#16
                    getqx   dist 'distance to sprite
                    'mov     spritearc,#200
                    'mov     dist,#100
                    wrlong  dist,ptrb[2]
                    wrlong  spritearc,ptrb[3]
                    jmp     #SpriteLoop
    pPlayer         long 0
    pSprites        long 0
    fspritex        long 0
    fspritey        long 0
    spritearc       long 0
    fplayerx        long 0
    fplayery        long 0
    dist            long 0
    fit     $1F0
    Lots more to do, but looking achievable
    edited 2025-10-26 20:57
    Made a little map of what the cogs are up to in order to better synchronize things.
    Main cog is very underutilized. May put the USB polling somewhere else and have a second spare cog...
    1545 x 999 - 111K
    Guess facing the unfortunate truth that adding transparent sprites is going to half the update rate from 60 fps to 30 fps. :(
    Problem is that sprites can take up most of the screen and so takes a long time to draw....
  • roglohrogloh Posts: 6,311
    edited 2025-11-02 06:54
    Perhaps another COG allocated can help speed it up. Why does EXMEM need two COGs? EDIT: sorry misread that (2) meaning 2 cogs. But can you allocate another COG? Polling the USB keyboard might be possible in your video COG during blanking if you can do it in PASM2 instead.
    Could increase graphics cogs from 2 to 3, but not enough. 4 might be, but then sound might be difficult...
    Could also drop floor casting, but don't want to...
    Was reading that Doom ran at 35 fps. Should be able to match that...
  • Yeah with something demanding like this you'll probably need to get creative to try to eke out every last cycle of performance however you can. Also try to make sure no one COG stops the others from working for any longer than needed. So for example if one COG only does something useful for some smaller portion of the screen display time, it could perhaps reload itself dynamically to do something else (like audio sample generation) for the remaining time etc. Tricks like that help too.
    edited 2025-11-03 20:49
    Think have sprites working now...
    For sorting, trying a 1 pass bubble sort.
    Thinking that might be enough as the order shouldn't change much from frame to frame.
    But, the sprite cog has a lot of unused time where a multi-pass sort could go...
    This is the bubble sort single pass subroutine:
    DAT 'BubbleSortSub
    BubbleSortSub
                    'Implementing bubble sort
                    mov     ptrb,pSprites  '    index, x  ,  y   ,dist, angle
    SpriteSortLoop
                    setq    #5*2-1
                    rdlong  s0,ptrb
                    cmp     n0,#0 wcz 'end of list?
            if_e    jmp     #SpriteSortLoopEnd
                    cmp     n3,s3 wcz 'compare next with current
            if_b    add     ptrb,#5*4 'next in list
            if_b    jmp     #SpriteSortLoop
                    'swap
                    setq    #5-1
                    wrlong  n0,ptrb
                    add     ptrb,#5*4
                    setq    #5-1
                    wrlong  s0,ptrb
                    jmp     #SpriteSortLoop
    SpriteSortLoopEnd
                    RET
    640 x 480 - 200K
    Ah, I believe bubble sorts are only used as an educational aid. To demonstrate algorithmic thinking. You might want to use some faster options, eg: https://en.wikipedia.org/wiki/Quicksort
    That is normally true, but Bubble sort is the fastest when the list is mostly already sorted... Which seems to be the case here...
    So, the sprites are 64x64 pixels, just like the walls and floors.
    But, seems like inefficient to draw all the columns when many of them could be all transparent...
    Especially for human aspect ratio things and columns.
    Think should make a list of empty columns for every sprite. Maybe just a vertical sum...
  • idea of using an incremental sort that is good, but with bubble sort you run into the worst case immediately when the view direction inverts
    Is that right? I'm sorting on distance between player and sprite. Think that is rotationally invariant...
  • I guess that works and avoids issues that view direction cross product would have
    Was just checking how behaves with a lot of sprites...
    The wide open map is OK with a large amount of sprites with 16-bit PSRAM.
    But, chokes with 4-bit PSRAM.
    4-bit does work with the regular map that isn't so wide open though.
    So, there's a balance to think about...
    640 x 480 - 186K
    Thinking now about an actual game…
    How is this?
    Some of Santa’s elves have escaped to the maze
    Santa must tase them and bag them back to the workshop
    Sadistic or funny?
