Pixy2 code issues
@"Ken Gracey"
@"Aristides Alvarez"
@JonnyMac
Hey guys.
Just bought the pixy2. Demo code in Simple ide does not work. Simple ide will not open it.
The JM demo code in P1 won't open to the serial terminal. Added the ter.start as it was not there.
Propeller tool does not have the "jm_fullduplexserial" tried reverting it but there are subroutine calls that have differences that are too numerous to count. Tried to find  the afore mentioned in github, forums, etc and only finde P2.
Spin Tools IDE does not support .side.
There are 7 download file categories. Finally found something in the files downloaded that appears to work. It is hidden under: 30028-pixy2 demo c code 2 24 2020.
Is there any P1 or P1 that works??
Lastly do you have the raw manuals with all the hex codes, commands  and stuff for both.
Nojoy.
According the the downloads P2 demo code is there and is not.
Other than that the pixy2 looks great! But no demo code.
Awaiting demo code for the Husky cam as I got that too.
Any suggestions.
Thanks in advance.
Martin
That code worked five years ago when I wrote it -- and Ken and I did a lot of testing.
I found P1 and P2 demos. I opened and adjusted for updates to libraries that have changed due to namespace conflicts with Spin2 (I tend to keep my Spin1 and libraries consistent with Spin2).
I did not go looking for a PixyCam to retest; that's on you.
I have provided P1 and P2 archives. Please unzip the archives and copy ALL of the libraries to your master library folder so you have the latest. I don't spend a lot of time worrying about updating ObEx, so you won't always find my latest code there.
@JonnyMac
Thank you for your help.
I understand the ObEx stuff, I will test the PixyCam and let you know.
Also did the command codes come directly from the processor docs or was there a manual specifically for the Pixy?
Martin
If memory serves, I used the Pixy API as a guide and stuck as closely as I could without violating what I feel are best practices for Spin. For example, in the Pixy API you will find constants with "PIXY_" on the front -- we don't need those extra characters in Spin so I dumped them. The Pixy API uses camelCase for function names while my style uses snake_case, hence
becomes
You shouldn't have any problems connecting the Spin demos to the Pixy API docs if you'll be a bit patient. As I said, I delivered working code to Ken and he verified it.
https://docs.pixycam.com/wiki/doku.php?id=wiki:v2:full_api
