Modulino --> QWIIC — Parallax Forums
Modulino --> QWIIC
Just noticed these things on the Arduino page:
https://store-usa.arduino.cc/collections/boards-modules/products/modulino-pixels
They look a lot like some QWIIC things from Adafruit and Sparkfun.
If reading it right, think it is QWIIC, they just went with a tan plastic connector instead of the usual black.
This is nice as it adds to the collection of QWIIC things.
Am a fan of QWIIC, so have started adding to generic boards, like the P2 Platform and the SWaP Carrier.
Makes it easy to play with things...
Added it to SWaP carrier after @JonnyMac mentioned existence of a vertical QWIIC connector...
Guess this doesn't have to be just P2, pretty sure would be fine with P1 too... Maybe better as lower cost entry...
  • JonnyMacJonnyMac Posts: 9,506
    edited 2025-09-12 01:08
    I made a board like the P2 Eval for the P1 (FLiP). Any time I build a P2 accessory board that has two spare pins, I just throw on a QWIIC.
    Technically, QWIIC (Sparkfun) and STEMMA QT (Adafruit) are marketing names for the JST SM04B-SRSS-TB (H) and BM04B-SRSS-TB (V) which seem only to be available in ivory. I prefer the black parts from Sparkfun; thankfully these can be obtained through Digikey with my other parts.
    Digikey:
    • H ivory: 455-SM04B-SRSS-TBCT-ND
    • V ivory: 455-BM04B-SRSS-TBCT-ND
    • H black: 1568-14417-ND (Sparkfun)
    • V black: 1568-16766-ND (Sparkfun)
    1002 x 968 - 234K
  • RaymanRayman Posts: 15,799
    edited 2025-09-11 21:20
    @JonnyMac Board looks good, you should sell it! (maybe you already are? don't check P1 page often enough...)
    Might move reset button closer to the edge of board?
    Sometimes find the desire to create some sort of shield for things like this and they often prevent access to the reset button...
    Think seeing RESN on one of the pins though, so guess one could just add another reset button, if needed...
    edited 2025-09-11 21:38
    I built that board for Josh and me so we'd have a quick prototyping/development for use with P2-type accessory boards. Long term we may start building boards that we resell, but that's down the road. Right now Elite just sells full products (and spare parts to existing customers).
    Diptrace doesn't allow for an orthographic view in its 3D window so the reset button looks out-of-place. In the attached image is my V1 board and you can see that there is no access problem. I put it at that end of the FLiP for people who are used to hunting for the little reset button on that end of the FLiP
    V2 has Grove connector added (shared with the QWIIC pins) because there seem to be a lot of low-cost experimenter boards that use Grove. Also, the header with the programming pins is meant to be compatible with the Parallax WiFi adapter.
    480 x 480 - 2M
    edited 2025-09-11 21:40
    Looks good. Think there are also QWIIC to Grove adapter cables, so could just use QWIIC connectors...
    There probably are, but it I was updating the board, anyway, and it seemed like an easy add. My friend John Huffman bought a kit of parts to learn with, and all the boards in it use Grove, and it comes with a bunch of Grove cables. For this scenario -- especially for newcomers who aren't as adept at acquiring parts as we are -- putting the connect on made sense.
    Just remembered that an Australian company called Core Electronics has its own set of boards that are QWIIC-compatible.
    -- https://core-electronics.com.au/piicodev.html
    More toys , gotta like that
  • AribaAriba Posts: 2,694
    Another source for Qwiic modules:
    https://smart-prototyping.com/Zio
    @Ariba Wow! Thanks. All kinds of stuff there...
    edited 2025-09-12 11:36
    Zio also seems to post Eagle files for their PCBs. Like that. Sparkfun does this too, but think they are switching to Kicad...
    Just saw ad for Arduino plug and make kit…
    Definitely looks like Qwiic to me.
    Think there’s a space here for P1/P2 to do something similar…
    Guess one sorta issue with QWIIC stuff is that most boards have pullups for I2C signals (According to AI anyway).
    This could be an issue if many of them share the same bus.
    Have to see what this Arduino kit does about that...
    Ok, found it: All of the Modulino® nodes that use dedicated I2C interface controllers have the footprints to provide the option to
    mount I2C pullup resistors, but no resistors are mounted.
    This seems like the right way to do it. Think main board should have the pullups...
