flexspin compiler for P2: Assembly, Spin, BASIC, and C in one compiler - Page 128 — Parallax Forums
1122123124125126128»
  • JonnyMacJonnyMac Posts: 9,447
    Version 7.3.0 doesn't understand a PNut constant (this works in Propeller Tool and Spin Tools).
  • ersmithersmith Posts: 6,209
    Thanks for catching this Jon. Chip added p_invert_out as an alias for p_invert_output, but I didn't notice that change (the table in flexspin was created based on an older version of the docs, I guess). I've added that and p_true_out to github and they'll be in the next release.
  • RaymanRayman Posts: 15,605
    @ersmith The "shell.c" example doesn't seem to compile in FlexProp IDE...
    In which version of FlexProp, and on which OS? It works for me with 7.4.2 on Linux. I seem to recall that there was a bug in shell.c in an earlier version (7.4.0 perhaps?)
    Thanks @ersmith Guess just having a hard time keeping up to date... Think that was 7.3...
  • __deets____deets__ Posts: 207
    edited 2025-08-31 14:20
    I'm trying to the this driver working: https://github.com/libdriver/sx1268
    It makes use of a variadic function for debug prints. See
    typedef struct sx1268_handle_s
        void (*debug_print)(const char *const fmt, ...);                      /**< point to a debug_print function address */
    When trying to compile with flexcc, I get
    /tmp/test.c:33: error: Bad number of parameters in call to debug_print: expected 2 found 1
    if the function is called without any argument beyond the format part for a simple print-statement without any actual string interpolation.
    GCC eats this just fine.
    I'm on the latest and greatest release I'd say:
    Propeller Spin/PASM Compiler 'FlexSpin' (c) 2011-2025 Total Spectrum Software Inc. and contributors
    Version 7.4.2-HEAD-v7.4.2 Compiled on: Aug 31 2025
    Any suggestions welcome.
    Edit: I just saw that there's no actual string interpolation used, so for some immediate progress I just redefined the debug function to be non-variadic. I still think this is a bug (and would prefer to use the driver unaltered of obvious reasons).
    @deets thanks for the bug report. It is fixed in github in version 7.4.4.
  • Hi Eric,
    I was playing with flexspin and think I found a problem with the P1 converter.
    This spin code:
            if phsa > 15
              adjust := -(phsa >> 2)      ' /4
            elseif phsb > 15
              adjust := +(phsb >> 2)      ' /4
    Produced this pasm code:
            cmps phsa, #16 wc
     if_b   jmp #LR__0002
            mov arg04, phsa
            shr arg04, #2
            neg _var05, arg04
            jmp #LR__0003
    LR__0002
            cmps phsb, #16 wc
     if_ae  mov _var05, phsb
     if_ae  shr _var05, #2
    LR__0003
    But the cmps phsx, #16 wc isn't right because phsx used in the destination field gets the shadow register value, not the count.
    Changing to this works:
        mov   temp, phsa
        cmps  temp, #16 wc
    I though you might want to know about this.
    Interestingly, this spin code:
            long[pa] := phsa
            long[pb] := phsb
        mov     arg04, phsa
        wrlong  arg04, arg07
        mov     arg04, phsb
        wrlong  arg04, arg08
    Which is expected and correct.
    @Sapphire Thank you for the bug report! We hadn't properly considered the implication of read restrictions on the CMP instruction. I think this should be fixed now in the github sources, and the fix will be in the next release (7.5.0).
  • Wuerfel_21Wuerfel_21 Posts: 5,535
    edited 2025-09-04 15:37
    Interesting thing I don't think I ever confirmed: Does P2 have source-only registers? Because currently the INA/INB registers there are considered as such by flexspin...
    I thought it does have the same kind of shadow register scheme. But I may be remembering an earlier revision of the chip.
  • evanhevanh Posts: 16,701
    edited 2025-09-04 23:50
    The shadow registers will be there, cogRAM is a generic block of dual-ported SRAM after all. Not that I've wanted to but I don't know of any way to access them.
    I've used INB as a null bin for an unwanted result write. It worked as intended but I wouldn't know if the instruction actually wrote anything to a shadow register.
  • I guess the easiest way to check would be to WRLONG INA,somewhere, but not at the workstation rn, so I can't.
    On the Prop2 that fetches from the actual INA special register. You get a copy of the pins written to hubRAM.
  • If that's true, there'd have to be a !gl_p2 check in SrcOnlyHwReg
    I can confirm this works now, thanks!
    However I've hit the next problem: something is awry with a bunch of indirect function calls. After trying some more complex code to actually send a LoRa packet, the program behaves weird. It stops producing printf-output. I have no clue why.
    The driver has a little helper function:
    static uint8_t a_sx1268_spi_write(sx1268_handle_t *handle, uint8_t reg, uint8_t *buf, uint16_t len)
      printf("a_sx1268_spi_write\n");
      //printf("a_sx1268_spi_write:%02X, %p, %d\n", reg, buf, len);
      /* return 0; */
        if (len > (384 - 1))                                              /* check the length */
            handle->debug_print("sx1268: len is over 383.\n");            /* len is over 383 */
            return 2;                                                     /* return error */
        memset(&handle->buf[0], 0, sizeof(uint8_t) * 384);                    /* clear the buffer */
        handle->buf[0] = reg;                                             /* set the reg */
        memcpy(&handle->buf[1], buf, len);                                /* copy the buffer */
        if (handle->spi_write_read(&handle->buf[0], len + 1, NULL, 0) != 0)   /* spi write */
            return 1;                                                     /* return error */
        else
            return 0;                                                     /* success return 0 */
    The printfs/return at the beginning are mine. The way it's written now, I see a bunch of "a_sx1268_spi_write" on my terminal.
    However the moment I swap the comments & print the second line (giving me the args), I see no output at all anymore.
    This baffles me.
    I fear this needs the full project to reproduce. I could send this zipped to you with build instructions? I'm using Linux, but assume other platforms work as well.
    Try changing the "X" hexadecimal formatting to an "x" instead. There has been prior bugs with that in the past.
    edited 2025-09-07 16:25
    I’m using that format specifier in other places with no issues. My guess is that the underlying cause has more to do with the memory access patterns (pointers to stack variables taken etc.). As the prints are only debugging, it fails without them as well. It’s just a very succinct change to trigger that.
    Maybe a -O0 on the compile can rectify behaviour then.
    Some things you could try:
    (1) Add #undef printf before the failing printf calls (to ensure they really are calling library functions, rather than __builtin_printf)
    (2) Compile with -O0 to rule out optimization bugs, as Evan suggested
    (3) Compile with -2nu instead (a completely different code production path)
    (4) Light up an LED before the printf call to make sure it's really getting there, and another one after the printf to see if it's getting back but just not producing serial for some reason
    If you can zip it up with build instructions I can try to take a look at it, too. (I use Linux as well, so any build scripts you use there should be OK for me.)
  • Thanks. I’ll be traveling a week, but try to make it happen next Sunday. Just to be a bit clearer about the nature of the problem: the print statement mentioned is the place something goes wrong.
    But the going of wrongs is of a global Nature. There’s print statements long before that, and none of those work either. Quite confusing.
