P2 Edge Rev B, FlexProp 7.3.0 Program not saving to flash — Parallax Forums
Been a while since I worked with this stuff but I remember that I could run a program, cycle the power and the program would still be there and would auto-start. Now it doesn't store to flash, or have I forgotten something?
The switches haven't changed (I have two of these modules).
Even when I select "Compile and flash" I get a message in the terminal:
ERROR: timeout waiting for checksum at end: got 1
Try increasing the FIFO setting if not large enough for your setup
Press enter to continue...
Can't find anything re: FIFO :|
  • MicksterMickster Posts: 2,900
    Maybe I'm mistaken. Used an older version and the terminal gives me:
    Invalid option -SPI
    loadp2 - a loader for the propeller 2 - version 0.060 Sep 23 2023
    usage: loadp2
    [ -p port ] serial port
    [ -b baud ] user baud rate (default is 115200)
    [ -l baud ] loader baud rate (default is 2000000)
    [ -f clkfreq ] clock frequency (default is 80000000)
    [ -m clkmode ] clock mode in hex (default is ffffffff)
    [ -s address ] starting address in hex (default is 0)
    [ -t ] enter terminal mode after running the program
    [ -T ] enter PST-compatible terminal mode
    [ -v ] enable verbose mode
    [ -k ] wait for user input before exit
    [ -q ] quiet mode: also checks for exit sequence
    [ -n ] no reset; skip any hardware reset
    [ -9 dir ] serve 9p remote filesystem from dir
    [ -FIFO bytes] modify serial FIFO size (default is 1024 byte
    s)
    [ -? ] display a usage message and exit
    [ -DTR ] use DTR for reset (default)
    [ -RTS ] use RTS for reset
    [ -xDEBUG ] enter ROM debug monitor
    [ -xTAQOZ ] enter ROM version of TAQOZ
    [ -xTERM ] enter terminal, avoid reset
    [ -CHIP ] set load mode for CHIP
    [ -FPGA ] set load mode for FPGA
    [ -PATCH ] patch in clock frequency and serial parms
    [ -NOZERO ] do not clear memory before download (default)
    [ -ZERO ] clear memory before download
    [ -SINGLE ] set load mode for single stage
    [ -NOEOF ] ignore EOF on input
    filespec file to load
    [ -e script ] send a sequence of characters after starting
    P2
    [ -a arg1 [arg2 ...] ] put arguments for program into memory
    In -CHIP mode, filespec may optionally be multiple files with address
    specifiers, such as:
    @ADDR=file1,@ADDR=file2,@ADDR+file3
    Here ADDR is a hex address at which to load the next file, followed by = or +
    If it is followed by + then the size of the file is put in memory followed by
    the file data. This feature is useful for loading data that a program wishes
    to act on. For example, a VGA program which displays data from $1000 may be
    loaded with:
    The main executable code must always be specified first
  • VonSzarvasVonSzarvas Posts: 3,622
    edited 2025-07-28 10:23
    Make sure the FLASH switch is ON-upward (and the two arrow switches OFF). -- if FLASH is already on, then toggle it on/off a couple times; might just be a lazy connection from sitting/bashing around.
    Also ensure the SD card is removed (if you have one inserted :)
    Still the same with both Rev B modules. I get the same message as in OP. The binary is only 7KB :|
    Just realized that the #2 module fired-up blinking an LED so clearly that program was successfully stored, many moons ago.
  • RaymanRayman Posts: 15,895
    edited 2025-07-28 14:55
    I’d try with prop tool or spin tools
    Or -single
    Or maybe add fake data so program is bigger…
    Or -single
    Cheers, Ray.
    Yeah I had the same idea re: prop tool. It doesn't complain when sending the binary but the progress indicator is done in the blink of an eye and the program doesn't execute. I don't believe spin tools directly handles binaries(???).
    Ya know what, I'll get back to my desk and try some regular SPIN programs to see if any different :+1:
    Sure enough :+1:
    Blink1.spin2 saves to flash and runs after a power cycle. :|
  • JonnyMacJonnyMac Posts: 9,554
    It does. Use F11 just like in Propeller Tool. Note that it does use its own loader.
    Ah, forgot to correct myself; it was Propeller IDE that I tried. Really nice looking IDE, wish it supported FlexBasic B)
    So I found FlexProp 5.5.2 archived in my DropBox and now I have success :+1:
    What am I to deduce? Edge Rev B not compatible with newer FlexProp? I don't see that being the case. :|
    I guess I need to go grab my KISS modules.
    Craig
    Hi Jon,
    As far as I can tell, you can't load a binary (compiled with FlexProp) in order to use F11(??)
    Right now I am compiling with FlexProp 7.3.0 and then when I need to stick my program in flash I just use FlexProp 5.5.2 to Flash Binary.
    Sorry, I may have misunderstood; I thought you wanted to compile and load a binary which F11 will do.
    That said, @macca has another tool that is a GUI loader for precompiled modules. This was made to help developers help their customers. You can get it from Marco's web site: https://maccasoft.com/en/propeller-firmware-loader/
  • ersmithersmith Posts: 6,231
    It looks like something is broken in the flash programmer in loadp2 for Windows, which is weird: I don't know how we've missed that.
    Fortunately, proploader can also program flash, so on the command line you can do something like:
    bin/proploader.exe -2 -Dbaud-rate=230400 -e blink.binary -t
    to flash and run a program like "blink.binary".
    You can also use the FlexProp GUI to do this if you go to "Commands > Configure Commands" and change the "Flash command" string to:
    "%D/bin/proploader" -k -2 -Dbaud-rate=%r %P "%B" -e
    (which is very similar to the "Wifi run command" just above it, but with -e for "flash eeprom" instead of -r for "run serial", and without the %9 -q)
    There’s a thread about this we need to find….
    Another trick is to make a fake spin2 file with only the binary embedded in a dat section…
    @JonnyMac
    Oh wonderful, many thanks, worked straightaway :+1:
    @ersmith
    Darn it :D
    I knew that this "Commands" (or something) had to exist. How the heck did I miss it :+1:
    Many thanks.
    Also, the latest terminal "Hit enter to continue" simply does a CR/LF whereas the older terminal would close.
    Was it this one?
    Found it:
    https://forums.parallax.com/discussion/175848/is-there-a-recommendation-for-binary-distribution-of-p2-code/p1
    Think need to use -SPI option for loadp2
    Undocumented? been a while...
  • evanhevanh Posts: 17,004
    I'm guessing -SPI has since been changed to -FLASH
    loadp2 - a loader for the propeller 2 - version 0.076 Mar 30 2025
    usage: loadp2
             [ -FIFO bytes]            modify serial FIFO size (default is 8192 bytes)
             [ -FLASH ]                program application to SPI flash
             [ -HIMEM=flash ]          addresses 0x8000000 and up refer to flash
             [ -e script ]             send a sequence of characters after starting P2
    edited 2025-07-29 16:00
    PS: Tested with -FLASH, and -v to get any reporting ...
    trying /dev/serial/by-id/usb-Parallax_Inc._Propeller_P2-EVAL-ES_DN43WU6I-if00-port0...
    P2 version G found on serial port /dev/serial/by-id/usb-Parallax_Inc._Propeller_P2-EVAL-ES_DN43WU6I-if00-port0
    Setting load mode to CHIP
    Setting clock_mode to 12427f8
    Loading fast loader...
    address=0x000fc000 size=2ac
    device response to header: `s'
    chksum: 3a OK
    Loading eeprom_check.binary - 8372 bytes
    address=0x00000000 size=20b4
    chksum: e7 OK
    highest hub address: 0x20b4 chksum: 0xea4ce5e4
    address=0x80000000 size=400
    device response to header: `k'
    Sending blocks: .chksum: 8e OK
    sending F 0x000020b4 to device
    ( Entering terminal mode.  Press Ctrl-] or Ctrl-Z to exit. )
       clkfreq = 20000000   clkmode = 0x100094b
      Compiled with FlexC v7.4.1-beta-v7.4.0-3-gd3cadbe0
    And pressing reset button repeats the terminal prints, so successful test.
    Bingo :):+1:
