I can't reproduce your results exactly - that is probably due to the use of a different type of SD card. However, the important thing here is how much using the cache speeds things up.
These results use a Sandisk 32Gb Extreme, at 300Mhz, in Catalina NATIVE mode:
As expected, using the cache speeds things up quite dramatically, and shows that this is a much more significant way to improve performance than just improving the low level SD card driver speed.
One other thing to note - you MUST format the SD card between each test, otherwise the tests are not using the same sectors on the SD card - and this makes a MASSIVE difference to the speeds - SD card manufacturers seem to cheat by making the first sectors much faster than subsequent sectors - presumably to give good results on simple speed tests.
Still working on the LARGE mode testing - I can't seem to get consistent results, which indicates I may have a bug with the cache in LARGE mode.
I would argue the opposite then. If there is something the cards are doing to make it faster at the start then messing it up plenty before the real test would be in order. Otherwise you'd be falling for a cheat.
I suppose you could start with writing a known number of files to the card, rather than an empty card. The main thing it that it be redone exactly the same way before each test (and using the same formatting and file writing program) otherwise you may be using different clusters (in different sections of the card) for different tests - and you will get different results.
Even so, if you are using different file system implementations (e.g. DOSFS vs FatFS) they may allocate clusters to files differently, so you may still get differences. But it is probably fairest to start with an empty card, or at least write a test that utilizes more of the card than just a few sectors (in this case, about 200 - see next post).
This test program only uses about 200 sectors (204 I think), so any cache size 100kb or so would give the same results - which would easily fit in Hub RAM. But my program uses PSRAM for the cache, so the cache could be up to 16Mb. A smaller cache (say 64kb or 32kb ) would give still give good - but slightly slower - results.
That's a page of vague fear-mongering. There's not one reason why given there. Although there is a hint about size boundaries. GParted has used 1 MB partitioning boundaries forever. Ie: First partition starts at 1 MB offset by default.
I always now use the SD Association format program, but out of interest I re-ran your program using a blank 32Gb Sandisk Extreme SD card, but formatted with different programs - the SD Association one, the Windows one, and the Linux one (gparted). All different. The differences were generally small (between 5% and 10%) but the SD Association was fastest, then gparted, then Windows.
I note it has a --discard option. I coded a full card discard for some of my cards not long ago - to see if that made any difference to testing speed but it didn't. Probably because it only matters after the card has been written 100%.
Well, I've learnt a good place to put these manually added binaries is in /usr/local/bin. It was, surprisingly, a totally empty directory. There is meant to be a ~/.local/bin as well but, although the directory already existed, the default path doesn't search it.
Disk /dev/sdg: 29.72 GiB, 31914983424 bytes, 62333952 sectors
Which is exactly 30436.5 MB.
SDA formatted:
Device Boot Start End Sectors Size Id Type
/dev/sdg1 8192 62333951 62325760 29.7G c W95 FAT32 (LBA)
GParted formatted:
/dev/sdg1 2048 62332927 62330880 29.7G b W95 FAT32
GParted formatted, with additional LBA flag set:
/dev/sdg1 2048 62332927 62330880 29.7G c W95 FAT32 (LBA)
GParted formatted, LBA flag set, no alignment, 4 MB unused at beginning:
Ha! I found the issue that was giving me such inconsistent results when using the cache in XMM programs!
I have to thank you for your test program, @evanh - it drew my attention to a piece of horribly inefficient code in my cache functions. It bamboozled me for a while because the affect on NATIVE programs is so small as to be almost unnoticeable - but in XMM programs (which execute from PSRAM and therefore execute more slowly) it was inefficient enough that in some cases it made the cached version of the function execute SLOWER than the non-cached version!
Still testing, but rewriting just a couple of lines has so far improved the performance of the self-hosted version of Catalina (which executes from PSRAM) by another 20%!
However, it does make me wonder what other silly things I have yet to find!
I've done some benchmarking on my new SD card cache, and the results are looking pretty good.
Here are the latest times for compiling some Catalina demo programs, using the self-hosted version of Catalina running at 300Mhz on the P2 Eval board equipped with the Hyper RAM add-on:
hello.c (~5 SLOC) - 3 mins
othello.c (~500 SLOC) - 4 mins
startrek.c (~2200 SLOC) - 18 mins
chimaera.c (~5500 SLOC) - 55 mins
dbasic.c (~13500 SLOC) - 104 mins
Compile times are now between 2 and 3 times faster than the initial release. I always wanted to get down to 3 minutes for a simple "Hello, World!" type C program, and this version finally achieves that.
All compiles done using Catalina's Quick Build option - which in hindsight was perhaps not the best name to choose!
The improved cache will be included in the next release.
That's a nice improvement but I'm kind of surprised it's not better than this. If hello.c has 5 lines of code do you know how many lines of additional header files are being parsed?
Have you looked into what sort of cache hit rate you are getting and what proportion of the 3 mins is just waiting to read/write external memory? I guess it would be possible to instrument your cache driver to spit out hits/miss ratios during a compile and the average time taken for a hit and a miss.
With the old 20-33MHz DOS machines I used to use back in the day running Turbo Pascal and Turbo C etc, compiling a hello world type of program would maybe only take like 10-30secs or so (just roughly guessing from my old memory). It certainly was a lot less than 3mins. I'd imagine a 300MHz P2 should be somewhere in the vicinity of that depending on the cache performance.
Is most of the time looking up data structures, or blocked doing file IO, or from lots of cache misses? It'd be interesting to know where the bottleneck is if you wanted to speed it up further.
Update: Actually if you have a 70% cache hit rate and a cache miss takes 1us to resolve (approx), then the resulting MIP rate drops from 150MIPs max (@300MHz) down to about 1MIP for each miss. So 30% of the instructions you run at ~1MIP and 70% you run at 150MIPs. Avg instruction rate is then 100 instructions serviced in 30/1us+70/150 microseconds or 100/30.467us = 3.28MIPs. This is ~10% of the ballpark of a slow old PC which I guess is more in line with your recent results - although this is with a RISC vs CISC ISA so still not really a proper comparison.
About 200.
Yes, the cache hit rate is good. In most of these programs, the cache is large enough to hold all the sectors used, and it is a "write-back" cache, so in fact the hit rate approaches 100%. I have not measured the time taken to actually read/write from PSRAM, since there is probably no way I could improve it much even if I found out that was a significant bottleneck.
Even with a cache hit rate of 100%, you still have to ultimately read and write hundreds of kilobytes - even megabytes (the core LCC program is nearly 2Mb) - from the SD card to compile even a 5 line program. Doing that from an SD card is going to take more time than doing it from a hard disk.
Then there is the fact that some of the work is done using Catalyst's scripting capabilities, which are quite slow because (for example) they have to reboot the Propeller and reload Catalyst (and then possibly also Lua) to execute each and every line of script. It's clunky, but it works.
Overall, I'd guess that somewhere between 30 seconds and 1 minute of every compilation time - even for just a 5 line program - is taken up by things that are just not that easy to speed up. The cache (once I got it working right) was actually a very easy win.
Much of the compliation time is spent in the C preprocessor (cpp). The one LCC uses is grindingly slow. I have thought about replacing it - there are open source ones that would be faster. That might save another 15 seconds or so.
Another big issue is the way Catalina does linking - the C library is not actually compiled to binary - it is just translated to PASM. That means every compilation - even for a 5 line program - is actually concatenating and then assembling a large chunk of the standard C library. This design decision probably looks a little crazy, but at the time it was not - in the very early days of the Propeller 1 there was simply no other choice. There was not even a publicly documented executable format for Propeller programs, and no tools available to use it if there had been - -i.e. no intermediate object formats and no linker! Even Spin's executable format had to be reverse engineered. Luckily, there were some clever people around at the time who did that, and who produced alternative Spin tools that expanded on the Parallax offerings. The very first version of Catalina actually spat out the complete program in a combination of Spin and PASM, and then used the Parallax Spin tool to compile/assemble the final result. Catalina soon outgrew the Parallax tools, but luckily by that time there were alternatives (bstc, HomeSpun, OpenSpin etc). On the P2, Catalina no longer uses any Parallax or Spin tools at all, since someone (Dave Hein) finally produced a proper assembler.
Finally, there is the insurmountable issue that because these programs are too large to fit in Hub RAM, they have to execute from external RAM. So the PSRAM is not only being used as an SD cache - it also being used to serve up the executable code itself. I also cache that, of course - but even so, executing code from external RAM can be anywhere from 2 to 10 times slower than executing the same code from Hub RAM.
I will of course look at further speed improvements, but from here on in every improvement will be harder work for less benefit. And I have other things I'd rather be doing.
About 200.
At 300MHz my rough rule of thumb is about 1us of time to read in a "small" block of data like 32 bytes or less for a transfer. If your transfer sizes are larger then add another 2*transfer size/sysclk micro seconds to the service time to account for the extra transfer time. If you write a custom memory driver that directly couples your cache to external memory interface and avoids the COG service polling overhead you can speed it up a bit, but you'll then lose the ability to easily share the memory with multiple COGs (or will have to invent your own memory driver sharing scheme which likely slows it down again as well).
Yeah, it will need to be read into PSRAM/HyperRAM initially. If the tools get swapped frequently during overall compilation that will add up.
Sounds like it.
Yeah I agree, additional steps like that would have to slow it down.
Yeah the external memory operation does slow it down a fair bit especially during cache misses.
This is a full release. It significantly improves the speed of the P2 self-hosted version of Catalina, and provides better support for the Parallax HyperFlash and HyperRAM add-on board on all P2 platforms. Please note especially the change of the default pins used for this add-on board, and also the VGA and USB adaptor boards. Plus a few other minor bug fixes and improvements.
Here is the relevant extract from the README.TXT:
New Functionality
1. On all Propeller 2 boards, the Parallax HyperFlash/HyperRAM add-on board
is now configured to use pin 0 by default rather than pin 16. This change
was made because pin 0 allows a wider range of clock frequencies to be
used on most boards, allowing (for example) the self-hosted version of
Catalina itself to be compiled at 300Mhz. To accommodate the change, the
VGA base pin has been changed to pin 16 and the USB base pin to pin 24.
2. A new utility to test the delay setting used for the PSRAM and HYPER RAM
drivers has been added in the file /demos/p2_ram/delay.c. This utility can
be used to verify that the current delay setting (configured in the platform
configuration file) works across a selected range of clock frequencies.
See the README.TXT file in that folder for more details.
3. Add a -Q option to the catalina command, which can also be specified by
defining the Catalina symbol QUICKFORCE (e.g. -C QUICKFORCE), to force a
Quick Build. This option is similar to the -q option except that it will
re-build the target file even if one already exists. If the target file
does not exist, then the -Q option has the same effect as the -q option.
4. For the Propeller 2, Catalyst can now be built for the P2 Edge to use
either the PSRAM (if installed - i.e. the P2-EC32MB) or the HyperRAM
add-on board (on base pin 0 by default). To specify that Catalyst and
associated utilities should use the HyperRAM rather than on-board PSRAM,
specify HYPER when building it using the build_all script. You can also
specify PSRAM to use the PSRAM on the P2-EC32MB, but this is not necessary
since this is the default if HYPER is not specified. If specified, HYPER
or PSRAM should be the second parameter. For example:
cd demos\catalyst
build_all P2_EDGE SIMPLE VT100 OPTIMIZE MHZ_200
cd demos\catalyst
build_all P2_EDGE PSRAM SIMPLE VT100 OPTIMIZE MHZ_200
cd demos\catalyst
build_all P2_EDGE HYPER SIMPLE VT100 OPTIMIZE MHZ_200
The catalyst build scripts have been amended to facilitate building for
the P2 Edge demos using either HYPER or PSRAM by adding a new script
called 'build_p2' which accepts one or two parameters - the platform and
(optionally) the type of XMM RAM to use. Do not specify any other options.
For example:
build_p2 P2_EDGE <-- for P2_EDGE using on-board PSRAM
build_p2 P2_EDGE PSRAM <-- ditto
build_p2 P2_EDGE HYPER <-- for P2_EDGE using HYPER RAM add-on board
build_p2 P2_EVAL <-- for P2_EVAL using HYPER RAM add-on board
build_p2 P2_EVAL HYPER <-- for P2_EVAL using HYPER RAM add-on board
build_p2 P2_EVAL PSRAM <-- will generate an error (not supported)
This script will build two ZIP files - one that uses the SIMPLE serial
HMI option named for the platform (e.g. P2_EDGE.ZIP) and one that uses
the VGA HMI option (e.g. P2_EDGE_VGA.ZIP). Note that the 'p2_edge' and
'p2_eval' scripts have now been removed, but the same function can be
achieved using the new 'build_p2' script. Also note that the 'build_demos'
script still only builds demos for the P2_EDGE using PSRAM and for the
P2_EVAL using HYPER RAM - but building for the P2_EDGE using HYPER RAM
instead can be done with the following command:
5. Added a new demo (in the folder demos/sd_cache) to provide an example of
how to build a local custom version of the Catalina C library to implement
some platform-specific functionality, such as (in this case) enabling the
PSRAM-based SD card cache. This folder also contains a test program that
can be used to demonstrate the SD cache. See the README.TXT file in that
6. Removed the file demos/catalyst/README.SMM_Loader. The information it
contained has been added to the Catalyst Reference Manual.
Other Changes
1. Fixed an issue with Catalina only supporting 200Mhz when the HyperRAM
add-on board is used on the P2 Evaluation board. The platform configuration
files (target/p2/P2EVAL.inc and also target/p2/P2EDGE.inc) have been
updated to disable the use of Fast Reads (HYPER_FASTREAD) and also modify
the RAM read delay (HYPER_DELAY_RAM). Note that the default delay (10)
works from 150 to 260Mhz, but outside that range it may need to be adjusted.
The new utility (demos/p2_ram/delay.c) included in this release can be used
to verify the specified delay works across a range of clock frequencies.
See also the platform configuration file (e.g. P2EVAL.inc) for more details.
Affected the Propeller 2 Evaluation board only.
2. Fix some non 8.3 filenames in library files:
getrealrand.c -> getrrand.c
hub_malloc.c -> hmalloc.c
registerx.e -> register.e
Affected the Propeller 2 under Catalyst only.
3. Fix the C include file stdint.h to specifically identify Catalina as one
of the platforms with 32 bit pointers.
Affected The Propeller 2 under Catalyst only.
4. Fix LCC bug in pointer comparisons which led to the compiler emitting
erroneous warning messages such as "overflow in converting constant
expression from `pointer to char' to `pointer to void".
5. Fixed an issue with the COMPACT version of the getcnt() function on the
Propeller 2. Affected COMPACT mode programs on the Propeller 2 only.
6. The pre-built Catalyst demo (P2_DEMO.ZIP) was incorrectly claiming it was
built for a P2_EVAL board (in the CATALYST.ENV file, as displayed by the
'set' command). It now says it was built for the P2_CUSTOM platform.
Affected the Propeller 2 only.
The number 8 is lucky in Chinese, so release 8.8. must be double lucky! I really hope it is, because I will be putting Catalina into "maintenance" mode for the next few months while I attend to some mundane personal stuff. But I will still do bug fixes if anyone finds an issue that really needs it.
Hmmm. Something seems to have changed recently on Windows 10. Catalina's version of telnet no longer works - but everything else seems to be fine. It is most likely due to a recent Windows update, but it may take me a while to pin it down and (if necessary) fix it.
However, everything (including telnet) works fine under Windows 11. Since Windows 10 is due to have support pulled later this year, it may not be worth fixing.
Found the problem. It was not Windows 10, it was Oracle VirtualBox. For reasons unknown it had created and enabled another virtual Ethernet adapter, which interferes with local Windows network connections even if they use WiFi and not Ethernet, and even if VirtualBox is not running. Windows 11 worked because that machine did not have VirtualBox installed. I seem to recall discovering this particular issue once before
Disabling this virtual network adapter using Windows Device Manager fixes the problem (note - you must disable it, not uninstall it - otherwise VirualBox just creates another one).
I don't much like Windows 11, and I use it as little as possible - but while messing about with it today (to try and find the problem with telnet (which turned out to be a VirtualBox problem anyway, not a Windows problem) I noticed that in Windows 11, the default application to use when executing batch files etc is the Terminal app, not the standard Windows command processor (i.e. cmd.exe).
This is generally ok, but there are a few things (such as the payloadi batch script) that won't work correctly under the Terminal app. To make them work correctly, you can go to "Settings" in the Terminal app, and set the "Default Terminal Application" to Windows Console Host instead of Windows Terminal or Let Windows Decide (but see EDIT1 and EDIT2, below!).
Ross.
EDIT 1: I have found a way to do this that does not require modifying the Windows Terminal app. Instead, open the properties of the "Catalina Command Line" desktop shortcut (and/or the Start menu entry) and change the Target from: "C:\Program Files (x86)\Catalina_8.8\bin\catalina_cmd.bat"
to conhost.exe "C:\Program Files (x86)\Catalina_8.8\bin\catalina_cmd.bat"
Works a treat!
EDIT 2: Also, at least one of the Catalina Geany Build commands need updating. Change the Download and Interact command to:
conhost payloadi.bat %x "%p\%e" -b%b
Note the inclusion of the ".bat" suffix - this is required.
@evanh
No cache:
Using a write-back SD sector cache:
Ross.
Excellent results for sure. How much RAM is used by the cache?
For details on why the format program matters, see https://www.sdcard.org/press/thoughtleadership/the-sd-memory-card-formatterhow-this-handy-tool-solves-your-memory-card-formatting-needs/).
Nice! Which also explains why you don't have it always compiled in.
Huh, there is a Linux edition, and it looks to be quite new - https://www.sdcard.org/downloads/sd-memory-card-formatter-for-linux/
I note it has a
--discard
option. I coded a full card discard for some of my cards not long ago - to see if that made any difference to testing speed but it didn't. Probably because it only matters after the card has been written 100%.Not FAT32-on-SDXC option though, lame.
SDA formatted:
GParted formatted:
Oh, yeah, from 64 GB upwards it shoves you with exFAT. That's a fail.
Reformatted to FAT32 with GParted: LBA flag set, no alignment, 16 MB unused at beginning:
Same behaviour with the Samsung 128 GB. SDA formatted:
And redone to FAT32:
Ross.
I love making progress like that.
Ross.
About 200.
Sounds like it.
Fair enough.
Catalina 8.8 has been released on GitHub and SourceForge.
Ross.
Ross.
Release 8.8 is all good.
Ross.
Ross.
to
Works a treat!
Just found an obscure bug with Catalina 8.8 ...
When compiling a program for a Propeller 2 to use XMM LARGE mode and a 1K cache in the LUT you get an error message. For example:
catalina -p2 hello_world.c -lc -C P2_EDGE -C LARGE -C CACHED_1K -C LUT_CACHE
Gives:
3309: ERROR: Cog address exceeds FIT limit. fit $1ea
There is an easy workaround. Just also define the Catalina symbol EXTERNAL_FLT_CMP - for example:
catalina -p2 hello_world.c -lc -C P2_EDGE -C LARGE -C CACHED_1K -C LUT_CACHE -C EXTERNAL_FLT_CMP
Having a 1K cache in the LUT is probably not a combination of options used by anyone except me, but I will fix this properly in the next release.
Ross.
