P1 In The Movies (Again) — Parallax Forums
JonnyMacJonnyMac Posts: 9,574
edited 2025-07-22 19:58 in PASM/Spin (P1)
For those who have seen -- or are about to see -- the latest Superman movie, you'll be happy to know that the robot called 4 (voiced by Alan Tudyk) has a P1 that allows it to come to life. The head and hand mechanics and lighting were designed by my friend, Rick Galinson. All of the head motion is controlled through an RC transmitter. The S.BUS output from the receiver feeds a P1 that was programmed by Rick to create the motion and lighting needed for the character to come to life.
I remember nearly two years ago when Rick and I met for dinner where he pulled out his PC and showed me a circuit board design for the central eye of this robot. It has two concentric rings of 2mm WS2812 pixels. The boards were made in a toaster oven.
Rick is an amazing engineer and a great friend, and I'm always happy to assist him when he calls for a driver that will make his programming life easier. In this project he's using an S.BUS receiver, a Dyanamixel driver, and a pixel driver. Maybe even a standard servo driver. I'll have to ask.
https://www.youtube.com/shorts/hrvhLleaNZ0?feature=share
  • RossHRossH Posts: 5,694
    Good stuff. I hope they intend to use a P2 in Superman 2! :)
  • Very cool, Jon!
  • RaymanRayman Posts: 15,943
    That must be a lot of fun to work on.
    Or maybe just lots of pressure?
    Going to see this soon, will keep in mind, thanks.
    Space is always at a premium in Rick's projects; that's why he goes with the P1 Mini (he bought a bunch when Ken announced its retirement). With the P2i, there is a chance that the P2 could find its way into one of Rick's prop projects.
  • JonnyMacJonnyMac Posts: 9,574
    edited 2025-07-22 01:01
    @ersmith said:
    Very cool, Jon!
    It's all Rick. I just help out if he needs an assist with one of my drivers -- or needs a driver that I don't have. For example, he built the small robot called Dewey in "Finch," and end-of-the-world movie with Tom Hanks.
    Rick needed a Dynamixel driver that worked with RS-485. Luckily, I had build a little RS-485 board in the size/shape of an XBee that could be plugged into the PAB. We spent a day in his shop writing code and drinking beers -- and we got it all to work! This allowed Rick to create animation sequences that were duplicated (on another platform) by the electronics guy on that job. Still, using the P1 was critical to getting things developed for the film.
    edited 2025-09-03 17:40
    Can be both, but mostly the former. For example, the day before Rick was to be on set for Superman he called me wanting me to remind him how to save variable values in the EEPROM so they'd auto boot. He's been in the business since before Jurassic Park 1 and knows that directors always ask for adjustments. In this case Rick used pots on the RC transmitter to tune the LED colors on 4's face. With a button press he was able to save those to EE so that they'd boot up the same the next day. Anticipating what could happen helps reduce the pressure a bit.
  • Yeah, what the heck is it?
    @JonnyMac man, this needs an article published. The fact that it's movie related will get attention.
  • I replaced the IG link with one to YouTube. It's the robot called "4" in the new Superman -- head and hands built by my friend Rick, and the head puppeteered by Rick on set during shooting.
    Rick gave a presentation an the Propeller Day event in May:
