@wummi said:
Hi Chip,
I found a strange behavior with REPEAT <count> WITH <variable> when count is zero.
PUB go () | i
repeat 0 with i
debug(sdec(i))
{ debug output
Cog0 i = 0
Cog0 i = -1
I expected debug(sdec(i)) is never executed, but it executes twice.
I believe this behavior is expected. The Spin document indicates that the count value is normally expected to be a number greater than 0.
The WITH form of the REPEAT statement is a smaller/faster version than the REPEAT FROM statement.
v40 2023-09-21 ● New smaller/faster REPEAT form added for iterating a variable from 0 to n-1, where n > 0.
REPEAT n WITH i 'best way to iterate a variable from 0 to n - 1
REPEAT i from 0 to n - 1 'general equivalent, though WITH needs n > 0
Example:
_clkfreq = 200_000_000
PUB go () | i,n
repeat 0 with i
debug("with loop: ",sdec(i))
n := 0
repeat i from 0 to n-1
debug("from loop: ",sdec(i))
Output:
Cog0 with loop: i = 0
Cog0 with loop: i = -1
Cog0 from loop: i = 0
Cog0 from loop: i = -1
A new PNut_v51 has been posted at the top of this thread.
v51 - 2025.04.02 - New POW, LOG2, EXP2, LOG10, EXP10, LOG, and EXP floating-point operators. SIZEOF() can now be used by PASM code to get sizes of structures. Long variables within structures can now be used as method pointers. Ignore-multiple-return-values '_ (number_of_longs)' had a stack bug rendering it useless, so it has been fixed and the syntax has been changed to use brackets, instead: '_ [number_of_longs]'.
Thanks. I'd like to suggest this be made more prominent in the manual than just in a changelog note 10 versions back from current. This is extremely easy to miss if you don't know what you're looking for.
Also you are correct, you cannot have constant structure members or defaults in Spin2. Nice to have but really not required.
Matteo's been hoping for a Propeller Tool that supports v51 or a more portable solution, so that IDEs can be pointed to compiler executables and you can decouple IDE development from compiler development. Any possibility of these in the near future?
Have you looked at Spin Tools IDE? It has an internal compiler (which Marco keeps up to date with PNut) and facilities to use external compilers. There are features I still like about Propeller Tool (bookmarks and code folding in the main window), so I start there, then move to Spin Tools where I can call the latest version of PNut to do the compilation if desired.
I've found an issue with structs in DAT blocks in the current pnut v51a
CON
STRUCT foo (bar, baz)
DAT
stuff foo[64]
Does not compile. You cannot initialize a block of structs in a DAT block, which kinda defeats the purpose of packed DAT blocks to begin with. Is this something that may change in the future?
Yeah, as long as you fill it with 0s, you can define a block of, for example, 64*2 longs.
So you do that with structs by doing the same thing, but just putting a single struct pointer at the start, and then just moving a struct pointer around. Or just use an offset table like we did on the P1. Got it.
It's definitely a slightly different approach, as at least as far as I remember from the P1 if I define 100 longs starting from pointer foo, I can go foo[32] and just have an offset, but if foo is a struct pointer I can't? Or can I?
Sounds like the functionality works and the manual could stand to be clearer.
PNut is failing to load and compile this object in Obex. It's giving me "invalid character" errors and if I save from pNut it corrupts the file. Anybody know what's going on?
OK, i do not now that n must be greater than 0
Undefined is not the same as expected.
Posted this to the github but I'm not sure if it goes there or here, having some syntax issues with structs vs the example.
https://github.com/parallaxinc/P2_PNut_Public/issues/6
Hope I didn't miss a post about it or something. lil help?
Make sure your code has a
{Spin2_v51}
comment at the very start to declare the Spin2 version number.In your posted example you've got syntax like:
I don't think initializing the structure members (
mark = xxx
) is legal in PNut; it certainly isn't in FlexSpin.Thanks. I'd like to suggest this be made more prominent in the manual than just in a changelog note 10 versions back from current. This is extremely easy to miss if you don't know what you're looking for.
Think that is the idea behind PNut_TS ...
Spin Tools thread
-- https://forums.parallax.com/discussion/174436/spin-tools-ide#latest
Thanks, I'm gonna put some brain cycles into looking at that shortly!
But
<typename>[<expression>]
has never been valid syntax for anything in a DAT block. There's no initializer syntax for structs, but you canor maybe
https://obex.parallax.com/obex/fat32-sd-card-driver/
Edit: the encoding of the spin2 file is UCS-2. That's probably it.
Ya, first thing I always do is convert the source files to UTF-8. Or even strip it down to ASCII and ignore/delete the damaged comments sections.
