Use @ operator to reserve space for new cog? — Parallax Forums
RaymanRayman Posts: 16,371
edited 2025-07-06 16:06 in PASM2/Spin2 (P2)
Seems can also use @ operator to reserve stack space for new cog:
cogspin(newcog,IMU(56),@" ")
Note: There are actually many spaces after the @" that are somehow hidden here...
It'd be easier if could do:
cogspin(newcog,IMU(56),@byte[1000])
This compiles but goes horribly wrong...
  • Re-using constant data space as variables is kindof nasty. It's better to just use regular VAR arrays.
    @byte[1000] already means something (the same as the plain integer 1000... syntax symmetry with other more useful things)
