We've just released v1.51.0, bringing PNut_TS up to par with PNut v51a
Here's what's new/fixed:
v1.51.0
Updated Language Support
Add language version support through {Spin2_v51}.
Add command-line -F option which, when specified, causes the .flash file to be written (PNut -ci equiv.)
Preprocessor intermediate files now end with __pre.spin2 (vs. '-pre.spin2')
Preprocessor: #define is no longer affected by command-line -U options
Added #pragma exportdef SYMBOL which makes SYMBOL present as if added with -DSYMBOL on the command line but affects all files compiled after the file containing the #pragma (place in top-most file for best results)
{Spin2_v44} is no longer supported due to changes in data structures beginning in v45
Compatible with PNut versions through PNut_v51a.exe (except for PNut_v44.exe, which is no longer supported)
Performance fix: Issue #2 Compiling FILEs in DAT section needs attention - is slow
We do comprehensive regression testing in preparation for each release. We also add to our regression suite so all new capabilities are tested as well. You can review our coverage testing via regress at PNut-TS Coverage Testing
If you spot any issues with code generation or compilation, you can review the testing process. This should help you identify differences between PNut v51a and PNut_TS v1.51.0.
We look forward to hearing what you find.
As always, you can report issues here, or better yet, if fixes are needed, then report problems at the repository issues page. (You can also see the current list of what's been reported at this page.)
@"Stephen Moraco" said:
@macca i’ve uploaded one with correct content please let me know if fixed.
Aside from the MacOS garbage , yes, it works.
I think there are some missing things, the following sample source is what I used recently to fix most of my issues with pointers, it works with PNut v51a but not with pnut_ts:
{Spin2_v51}
CON
STRUCT sPoint(word x, word y, byte c)
PUB main() | a, b, ^sPoint ptr
a := ptr.x++
a := ++ptr.x
a := [ptr]
a := [ptr]++
a := ++[ptr]
a := ptr[++].x
a := ptr[++].x--
a := --ptr[++].x
a := [++]ptr.x
a := [++]ptr.x--
a := --[++]ptr.x
ptr.x := a
[ptr] := a
ptr[++].x := a
[++]ptr.x := a
a := ptr.x := b
a := ptr[++].x := b
a := [++]ptr.x := b
/home/marco/pnut_ts/pnut_ts -I /home/marco/workspace/spin-tools-ide/library/spin2 StructTest.spin2
pnut-ts: * Propeller Spin2/PASM2 Compiler 'pnut_ts' (c) 2024 Iron Sheep Productions, LLC., Parallax Inc.
pnut-ts: * Version 1.51.0, Build date: 5/1/2025
pnut-ts: * pnut_ts -I /home/marco/workspace/spin-tools-ide/library/spin2 StructTest.spin2
pnut-ts: Wrote StructTest.obj (53 bytes)
StructTest.spin2:7:error:Expected end of line (m281)
pnut-ts: Done
If you spot any issues with code generation or compilation, you can review the testing process. This should help you identify differences between PNut v51a and PNut_TS v1.51.1.
@wummi said:
Hi Stephen,
I download the new pnut_ts for Mac.
There is something wrong with pnut-ts-macos-arm64-015102.zip 30.4 KB
It is only 30kB long!
Hi, there's nothing wrong. It's just that including the node runtime on the Mac is not working.
So I ask you to install the Node runtime separately.
Once you install the Node.js runtime, the pnut_ts file you downloaded will run just fine. See Instructions
I also try to remind us of this in the release notes.
Good morning Stephen,
/Applications/pnut_ts/pnut_ts v1.51.1 is 991 kByte long.
/Applications/pnut_ts/pnut_ts v1.51.2 is 28 kByte long, this must be wrong!
And I get this when I run pnut_ts:
/Applications/pnut_ts/pnut_ts "-d" VSC.spin2
node:internal/modules/cjs/loader:1408
throw err;
Error: Cannot find module 'commander'
Require stack:
- /Applications/pnut_ts/pnut_ts
at Function._resolveFilename (node:internal/modules/cjs/loader:1405:15)
at defaultResolveImpl (node:internal/modules/cjs/loader:1061:19)
at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1066:22)
at Function._load (node:internal/modules/cjs/loader:1215:37)
at TracingChannel.traceSync (node:diagnostics_channel:322:14)
at wrapModuleLoad (node:internal/modules/cjs/loader:235:24)
at Module.require (node:internal/modules/cjs/loader:1491:12)
at require (node:internal/modules/helpers:135:16)
at Object.<anonymous> (/Applications/pnut_ts/pnut_ts:11:21)
at Module._compile (node:internal/modules/cjs/loader:1734:14) {
code: 'MODULE_NOT_FOUND',
requireStack: [ '/Applications/pnut_ts/pnut_ts' ]
Node.js v23.9.0
Node.js v23.9.0
Ok, I'm on this. will investigate and post updated version shortly. Thank you for being persistent in letting me know!
@wummi, The macOS assets for release v1.51.2 have been replaced with the correctly built .zip files.
I've updated my packaging script to (hopefully) prevent this in the future.
Thanks again for pointing this out.
@Stephen, I try to compile my big P2-Project and get: error:OBJ data exceeds 1024k limit
5 month ago PNUT v48 shows the same Error.
Chip has found the problem and fix it in SPIN v49.
He expand the space to 4MB and he found that an internal stack overflow was occurring during compilation when it got six levels deep in objects. Now, it will do all 16 levels
We did this translation by studying Chip's code and making our typescript version the same or better, so we must have missed something. I'll check with Chip, and then we'll get this fixed.
@Stephen, there is the same problem with VSC Spin2 extension.
When I try to edit my big project i get: [Error - 18:27:05] The Spin2 Language Server server crashed 5 times in the last 3 minutes. The server will not be restarted.
This is new, 3 weeks ago i edit the project with VSC and there are no problems.
Not the same problem. The latest highlighter is dying on something in your code. Can you share a portion of your crashing code? I'll fix it and release a new version for you.
@Stephen, I found the object which crash the Spin2 Language Server.
It is the biggest object in the project.
When you give me your email, I send you the file.
If you encounter any issues with code generation or compilation, you can review the testing process outlined in this document. This should help you identify differences between PNut v51a and PNut_TS v1.51.3.
I just tried the latest version of PNut-TS with a PASM2 code and run into an error using $. It looks like that the compiler does it only accept with a PASM2 instruction. With PNut it is working anywhere in the DAT section.
CON
_CLKFREQ = 4_000_000
DAT
org 0
start
jmp #$
.end_of_code
long $AA55_BB44[$1F0 - $]
fit $1F0
/Applications/pnut_ts/pnut_ts Test.spin2
pnut-ts: * Propeller Spin2/PASM2 Compiler 'pnut_ts' (c) 2025 Iron Sheep Productions, LLC., Parallax Inc.
pnut-ts: * Version 1.51.5, Build date: 9/30/2025
pnut-ts: * pnut_ts Test.spin2
pnut-ts: Wrote Test.obj (53 bytes)
Test.spin2:12:error:"$" (DAT origin) is only allowed in DAT blocks Test.spin2:12:error:"$" (DAT origin) is only allowed in DAT blocks
pnut-ts: Done
@Kaio said:
Hi @"Stephen Moraco",
Thanks for the heads up and the code example. I'll get this fixed and a new release posted soon.
We've just released v1.51.7. With all my work with building and testing projects lately, I found myself needing to know where objects in my code landed in the image. So I decided to add a .map feature to tell me this! (Necessity is... ;-)) Oh, and I fixed some bugs too!
v1.51.7
New Feature: Added -m / --map command-line option to generate memory map files (.map). The map file provides a detailed narrative of the compiled object structure, memory allocation, and multi-object relationships.
Fixed
Error Codes: All duplicate compiler error messages now have unique error codes for easier troubleshooting and support
Compatibility: Symbol names exceeding 30 characters now generate an error, matching the original PNut compiler behavior
BUGFIX: Fixed -I include path handling - paths relative to the current working directory now work correctly (previously only paths relative to the source file worked)
BUGFIX: Missing #include files now properly stop compilation with a standard-format error message instead of silently continuing
BUGFIX: Fixed $ (DAT origin) operator not working in DAT data declarations like long value[$1F0 - $]. The operator now works anywhere in DAT blocks, not just in PASM instruction operands. (Thank you @kaio for reporting this!)
@Kaio, this work resulted in my adding another regression test with the code you provided, so we don't miss this in the future.
Actually, in this release cycle, we added a large number of regression tests. For the latest test coverage (not code coverage), see: PNut-TS Regression Test Coverage Report. My goal is to continue increasing this test coverage with every release so we stay fully compatible with PNut for Windows.
As always, you can report issues here, or better yet, if fixes are needed, then report problems at the repository issues page. (You can also see the current list of what's been reported on this page.)
I have just started to work with pnut_ts and I see the following issue:
❯ pnut_ts -v -d -l struct_test.spin2
pnut-ts: Verbose output is enabled
pnut-ts: * Version 1.51.7, Build date: 12/26/2025
pnut-ts: * pnut_ts -v -d -l struct_test.spin2
pnut-ts: Compiling with DEBUG
pnut-ts: Verbose- Working with file [struct_test.spin2]
pnut-ts: Verbose- * Write listing file: struct_test.lst
pnut-ts: Verbose- ext dir [/snapshot/PNut-TS/out/ext]
pnut-ts: Verbose- lib dir [/snapshot/PNut-TS/out/lib]
pnut-ts: Verbose- wkg dir [.]
pnut-ts: Verbose- Node version: v18.5.0 (built-in)
pnut-ts: Verbose- Compiling file [struct_test.spin2]
struct_test.spin2:6:error:Expected "=" "[" "," or end of line
I have attached the Spin2 source.
This works in flexspin and Spintools.
I am seeing the same in other files when defining structs even from the examples in the Spin2 docs.
Also same in pnut-term-ts which I assume uses the same core.
We do comprehensive regression testing in preparation for each release. We also add to our regression suite, so all new capabilities are tested. You can review our coverage testing via regress at PNut-TS Coverage Testing
If you spot any issues with code generation or compilation, you can review the testing process. This should help you identify differences between PNut v52a and PNut_TS v1.52.1.
As always, you can report issues here, or, better yet, if fixes are needed, report problems on the repository issues page. (You can also see the current list of what's been reported at this page.)
Thank you for pointing out the reserved words issue. I have changed that and now am seeing the next layer of the onion so to speak when trtying to use the Spin2 Extension integration of VSCode.
Using VSCODE and running:
Tasks: Run Build Task and selecting "compileTopP2" from popup
Tasks: Run Build Task and selecting "compileP2" from popup
I get the following:
* Executing task: /home/bob/.local/bin/pnut_ts "-d -l" struct_test.spin2
PNut-TS: error: unknown option '- -l'
pnut-ts: * Version 1.52.1, Build date: 2/14/2026
pnut-ts: * pnut_ts -d -l struct_test.spin2
pnut-ts: Wrote struct_test.bin (9778 bytes)
pnut-ts: Done
Also I see the following:
If I run the pnut_ts command in the vscode terminal window manually
The compile runs correctly with both a listing file and a .bin file
❯ pnut_ts "-l" "-d" struct_test.spin2
pnut-ts: * pnut_ts -l -d struct_test.spin2
pnut-ts: Wrote struct_test.lst
pnut-ts: Done
VSCode Version: January 2026 (version 1.109)
The latest Spin2 Extension is installed: 2.5.0
The subject Spin2 file is the same as in post #55 above with the name of the byte struct renamed as you pointed out.
This is happening on all my files Spin2 in separate directories
Please help me to understand what I have possibly mis-configured to cause this.
NEWS
PNut-TS is found at its new Public Repository, while the latest Releases are also found there at the Releases Page
Stephen & Chip
Seems that the Linux x64 package contains the ARM executable (same as the Linux arm64 package).
again?
@Wuerfel_21 yep, i’m a creature of scripts. Guess I better fix one of them! 😋
, yes, it works.
{Spin2_v51} CON STRUCT sPoint(word x, word y, byte c) PUB main() | a, b, ^sPoint ptr a := ptr.x++ a := ++ptr.x a := [ptr] a := [ptr]++ a := ++[ptr] a := ptr[++].x a := ptr[++].x-- a := --ptr[++].x a := [++]ptr.x a := [++]ptr.x-- a := --[++]ptr.x ptr.x := a [ptr] := a ptr[++].x := a [++]ptr.x := a a := ptr.x := b a := ptr[++].x := b a := [++]ptr.x := bCommenting line 7, show same error on line 15.
We will add that to our regression test next week.
Thank you for reporting this.
And yeah, packaged that pretty quickly for you as I was heading to the airport 😊
NEWS
We've just released v1.51.1, bringing PNut_TS up to par with PNut v51a
PNut-TS is found at its Public Repository, while the latest Releases are also found there at the Releases Page
Stephen & Chip
@macca your fixes are in. Thank you for reporting this.
Hi Stephen,
/Applications/pnut_ts/pnut_ts "-d" VSC.spin2 node:internal/modules/cjs/loader:1408 throw err; ^ Error: Cannot find module 'commander' Require stack: - /Applications/pnut_ts/pnut_ts at Function._resolveFilename (node:internal/modules/cjs/loader:1405:15) at defaultResolveImpl (node:internal/modules/cjs/loader:1061:19) at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1066:22) at Function._load (node:internal/modules/cjs/loader:1215:37) at TracingChannel.traceSync (node:diagnostics_channel:322:14) at wrapModuleLoad (node:internal/modules/cjs/loader:235:24) at Module.require (node:internal/modules/cjs/loader:1491:12) at require (node:internal/modules/helpers:135:16) at Object.<anonymous> (/Applications/pnut_ts/pnut_ts:11:21) at Module._compile (node:internal/modules/cjs/loader:1734:14) { code: 'MODULE_NOT_FOUND', requireStack: [ '/Applications/pnut_ts/pnut_ts' ] } Node.js v23.9.0Ok, I'm on this. will investigate and post updated version shortly. Thank you for being persistent in letting me know!
NEWS
We've just released v1.51.3.
Stephen & Chip
I left a message for you...
CON _CLKFREQ = 4_000_000 DAT org 0 start jmp #$ .end_of_code long $AA55_BB44[$1F0 - $] fit $1F0Thanks for the heads up and the code example. I'll get this fixed and a new release posted soon.
NEWS
Stephen & Chip
Thanks in advance
I forgot to mention I am running on Debian Linux machine.
Bob
Please disregard the last line comment about pnut-term-ts. With correctly compiled files pnut_term-ts is working fine so far.
Thanks! Looking into this. More soon!
@TrapperBob, well, that was a fun search!
your line
BYTE testis causing the problem for both PNut and PNut-TS.Both PNut v52a AND PNut-TS v52a reject this code at line 10 - this is consistent behavior.
Expected a unique variable nameExpected a unique variable name, STRUCT name, BYTE, WORD, LONG, "^", ALIGNW, or ALIGNLThe issue is that PNut and PNut-TS currently treat pasm instruction names as reserved words. TEST is a pasm2 instruction.
(Interesting that this works in FlexSpin and Spintools. I'll discuss this further with Chip)
NEWS
We've just released v1.52.1, bringing PNut_TS up to par with PNut v52a
Stephen & Chip
arguments: [ '- -l', length: 1 ]
combArguments: [
'/home/bob/.local/bin/pnut_ts',
'/snapshot/PNut-TS/out/pnut-ts.js',
'-d -l',
options: { debug: true }
pnut-ts: ERROR- Missing filename argument
pnut-ts: Aborted!
It is obvious from the Executing task line that it is missing to filename to compile.
pnut-ts: Done
pnut-ts: Done
Bob
