Okay. Looking around I've found cluster size in struct FATFS. Which _vfs_open_fat_handle() creates and passes to f_mount(). The user program calls _vfs_open_fat_handle() during mounting, so access to cluster size is only just below. I'm not sure of C foo to reach it though.
There's a way to grab the internal FATFS struct from the VFS. I think I used it once to proof-of-concept converting paths between long and short names - you'd need that if you had some kind of file explorer application with LFN support and want to launch e.g. MegaYume (no LFN support) with a given file through FC000 ARGv).
@ersmith said:
Worst case I suppose you could always read sector 0 (the BPB) and get it from there. Out of curiosity, why do you want the cluster size?
From observation, I'm of the opinion that the file speed testing performs highest when the read/write chunk size (The tester's buffer size) matches the cluster size. Above that level seems to be slightly reduced speed even.
And how does a program read partition blocks?
something like fopen("/sd/.","rb"); ??
EDIT: Nope, errno = 4: No such file or directory
The handle you pass to _vfs_open_fat_handle(h) (e.g. the result of _sdmm_open is a FILE *, so you can use fread or fwrite on it. This may not be obvious in the headers, which tend to use the name struct vfs_file_t * for this pointer, but FILE is an alias for struct vfs_file_t.
@evanh said:
Uh-oh, can't fseek(). It just doesn't do anything. I have to read every block sequentially to reach start of partition to then fetch the cluster size.
I forgot to warn you, fseek() on the SDMM device only works to seek to sector boundaries; it's also possible (probable) that fread() and fwrite() will only work on sector sized chunks.
PS: If it were to function, it'd make sense to use LBA block numbering rather than bytes.
You can actually open a FAT file image that's contained on another device (e.g. a FAT file on the host PC using the 9P file system). So not all underlying devices only work on block boundaries, just the kind of hacky SDMM one. Someday it would be nice to remove the SDMM restrictions, but that's a pretty niche case.
Actually I see the stat() function has an st_blksize field, which we can fill in with the cluster size (at least for regular files). I've just pushed a change to do that. The patch looks like:
Ah, stat() needs a path specified, would that be "/sd" this time?
fstat() can presumably use the same file handle I already have. However fstat() is not implemented? It has a header entry declared but no source definition that I can see.
No, it would be the name of the file you plan to read from. The code I posted won't work on the root directory (e.g. "/sd", if that's where you mounted the fatfs) . However, I've pushed an update that will work, so that's always an option.
Yes, fstat() never got implemented, because not all file systems can do it easily (FATFS being one of them).
Updated to the latest include/filesys/fatfs/ files.
Okay, making progress. I correctly get buff->st_blksize == 32768 when I stat() one of the written files. But not the case for stat("/sd", buff);. It's just a zero value for all attempts at stat()ing the mounted volume directly.
I am just blindly examining st_blksize without knowing anything else about what stat() has filled out. Don't know how it's normally used.
EDIT: Turning on -D_DEBUG_FATFS and using a file gives me:
A debug() issue. The below code works properly with Pnut v46. But in Flexspin it fails to adjust the baud for the changing sysclock frequency. I presume Flexspin's -gbrk blob is out of date.
@evanh Actually the problem was that _clkset wasn't writing the frequency into the smart pin repository, it was only setting the value in memory (why doesn't the gbrk debugger use that? Oh well, another mystery). I've updated _clkset to do that now.
Eric,
Recently, and I can't say if and when it might have changed, I've noticed when I majorly restructure a program, that also uses my SD card driver, and leave a dangling reference in the source I'll get a compile error message of "Unknown symbol", which is expected, but gets the wrong source file. eg: I know perfectly well the errors are on lines 137 and 229 of source file sdfat_accesstest.c. Both after a struct __using("blkdrvr/sdsd.cc") drv_t;
/home/evanh/hoard/coding/prop2/testing/files/blkdrvr/sdsd.cc:1385: error: Unknown symbol 'DRV2'
/home/evanh/hoard/coding/prop2/testing/files/blkdrvr/sdsd.cc:1385: error: Unknown symbol 'filename'
Looking at sdsd.cc, Line 1385 is the extended line with __builtin_bswap32()
When I remove -DSD_DEBUG from the compile command, the compile error messages identify the locations correctly:
/home/evanh/hoard/coding/prop2/testing/files/sdfat-accesstest.c:137: error: Unknown symbol 'DRV2'
/home/evanh/hoard/coding/prop2/testing/files/sdfat-accesstest.c:229: error: Unknown symbol 'filename'
It compiles fine either way once the dangling references are fixed up.
@evanh : thanks for the bug report. The key was that the bug stopped showing up when "%X" was replaced with "%x"; the former isn't one of the formats directly handled by __builtin_printf (probably it should be,, but that's another matter). The code for falling back to the library printf wasn't properly restoring the error handling state. That should be fixed in github now.
I think it'd be better if a lacking support situation generated an error instead of silently switching to printf(). That way I'd know when bloat is being generated. EDIT: Not that it actually matters for the SD driver. Those are present only with debug compiles.
Well, stdio.h actually has #define printf __builtin_printf, so for now it has to fall back. I could add an optional warning about falling back though.
Making an observation about Flexspin's use ptra vs objptr, they seem inverted in effective use ... reading through some of the generated pasm2 code, PTRA is hardly touched. Meanwhile OBJPTR gets hammered with ADDs and SUBs for accessing hubRAM data.
It seems that quite a lot of bloat could be trimmed by making PTRA the object pointer. Load PTRA from OBJPTR at head of routine then for uneven single byte accesses could use a rdbyte local1, ptra[5] while mostly moving around with something like rdlong local1, ++ptra[3].
EDIT: Actually, even just using lots of AUGSs for free ranging offset indexing would be better than all those ADDs and SUBs. No need to keep reloading PTRA then either.
Yeah, using PTRB for objptr would probably be a good optimization. I worry that it'll break existing code though, since we've always documented that ptrb is free for user code to use. Similarly, changing the purpose of PTRA might also break things, since it's always been the stack pointer.
Hmm, I did use PTRB as a private simplistic debug stack in the early SD mode testing code. But my debug code was buggy itself, I ditched the mechanism when building the subsequent complete driver. I wouldn't care about that testing code dying now. It's long been superseded.
I've used PTRB occasionally locally within inlined Pasm2 code otherwise. I think retaining this ability would be enough. Same as PA is now.
I haven't seen anyone else using PTRB within inline Pasm2. Actually, I don't think I've seen anyone else using inline assembly for anything. It's all COGINIT'd stuff.
I think this is still an option too. Anyone messing with potential compiler internals should be expecting it to break with newer releases of the compiler.
something like
??EDIT: Nope,
(e.g. the result of_sdmm_open
is aFILE *
, so you can usefread
orfwrite
on it. This may not be obvious in the headers, which tend to use the namestruct vfs_file_t *
for this pointer, butFILE
is an alias forstruct vfs_file_t
.huh, cool. Too easy.
Actually I see the
stat()
function has anst_blksize
field, which we can fill in with the cluster size (at least for regular files). I've just pushed a change to do that. The patch looks like:Sounds good.
stat("/sd", buff);
. It's just a zero value for all attempts at stat()ing the mounted volume directly.I am just blindly examining st_blksize without knowing anything else about what stat() has filled out. Don't know how it's normally used.
And "/sd" gives me:
Looks like it ignores and returns without error.
Here's the relevant source code:
@evanh Aargh, there was another problem where stat() itself was just ignoring the root directory. That should be fixed now.
All good!
Thanks.
PS: pllset is from https://obex.parallax.com/obex/pllset/
_clkset
wasn't writing the frequency into the smart pin repository, it was only setting the value in memory (why doesn't the gbrk debugger use that? Oh well, another mystery). I've updated_clkset
to do that now.Works nice thanks.
Good question. I don't remember a specific reason even though the dynamic handling was done on my request.
The debugger is generally supposed to survive hub memory corruption.
Eric,
A little bit of experimenting I find the compile error is correct when I comment out the first and third printf()s.
Ah, and when replacing the two %X with %x that fixes the error too.
Hope that's narrowed it down enough for you.
Cool.
, so for now it has to fall back. I could add an optional warning about falling back though.Yes please, that'd be great.
ptra
vsobjptr
, they seem inverted in effective use ... reading through some of the generated pasm2 code, PTRA is hardly touched. Meanwhile OBJPTR gets hammered with ADDs and SUBs for accessing hubRAM data.It seems that quite a lot of bloat could be trimmed by making PTRA the object pointer. Load PTRA from OBJPTR at head of routine then for uneven single byte accesses could use a
while mostly moving around with something likerdlong local1, ++ptra[3]
.EDIT: Actually, even just using lots of AUGSs for free ranging offset indexing would be better than all those ADDs and SUBs. No need to keep reloading PTRA then either.
PTRA is used quite directly in the function call prologie/epilogue to save/restore registers.
Mind there's an entire PTRB the compiler codegen never touches.
I have a lot of inline ASM that does this
In your emulators? I'm seeing both local uses and COGINIT'd uses, but nothing that seems to be global uses of PTRB within inlined assembly.
