P2 running the Parallax "96 x 64 Color OLED Display Module" Product ID: 28087 - SSD1331 - Page 2 — Parallax Forums
2»
  • evanhevanh Posts: 17,214
    Okay.
    And it looks like the PropTool compile report may have always had borked frequency report. Just tested it with another program and it's the same. I'd never really looked before. I barely touch it because it can't see my comports. Yet PNut has no issue finding the Prop2.
  • ke4pjwke4pjw Posts: 1,321
    edited 2022-06-21 22:57
    I found the bug in this code. Was referencing legacy code and was not releasing the RST line.
    It now works with the Parallax Propeller Tool.
    I updated the "To Do" and will spend some time this week trying to get those items completed.
    Code is attached on the first post.
  • Another quick update. Moved the 5x7 font into a file and out of code.
    Version 0.9.2 Released at top of thread.
    edited 2022-06-22 05:58
    As you borrowed and modified one of my objects, I'm doing the same with yours. I'm very stingy with cogs, so I wanted to have change that part. I started with an inline PASM method. Once that worked (verified using LA), I moved the code to be loaded into the upper user RAM of the interpreter cog to be called. Here's the first part of the start() method that captures the IO pins used for the display, sets them up, then loads the SPI driver.
    pub startx(cspin, dcpin, dopin, clkpin, rstpin) | m, x
    '' Start oled driver
    '' -- pins may be non-contiguous, but DO and CLK should be neighbors
      longmove(@cs, @cspin, 5)                                      ' copy pins
      pinh(cs)                                                      ' configure pins
      pinl(dc)
      pinh(rst)
      m := P_SYNC_TX | P_OE                                         ' spi tx mode
      m |= ((clk-dout) & %111) << 24                                ' add clk offset (B pin)
      x := %1_00111                                                 ' start/stop mode, 8 bits
      pinstart(dout, m, x, 0)                                       ' activate smart pin
      pinf(dout)                                                    ' reset/disable until used
      m := P_PULSE | P_OE | P_INVERT_OUTPUT                         ' spi clock mode
      x.word[0] := 2 #> (clkfreq / SPI_HZ) <# $FFFF                 ' ticks in period
      x.word[1] := x.word[0] >> 1                                   ' ticks in low cycle (50%)
      pinstart(clk, m, x, 0)
      longmove(@_cs, @cs, 4)                                        ' move pins to driver code
      regload(@chunk)                                               ' load driver into cog
    ' hard reset
    ' initialization
    This is the shell method and PASM code that uses the configured SPI pins.
    pub write(value, dcbit)
      pr0 := value
      pr1 := dcbit
      call(#spi_write)
    dat
    chunk                   word      spi_write, spi_finish-spi_write-1
                            org       $110
    ' write pr1.[0] to dc pin, write low 8 bits of pr0 MSBFIRST to dout pin
    spi_write               drvl      _cs
                            testb     pr1, #0               wc
                            drvc      _dc
                            ror       pr0, #8
                            rev       pr0
                            wypin     pr0, _dout
                            drvl      _dout
                            wypin     #8, _clk
                            nop
                            testp     _clk                  wc
            if_nc           jmp       #$-1
                            fltl      _dout
            _ret_           drvh      _cs
    _cs                     long      0
    _dc                     long      0
    _dout                   long      0
    _clk                    long      0
    spi_finish
    This, of course, is a WIP and I've only checked the SPI output with a logic analyzer. Once I get the display code ported and working I'll share.
  • Thanks @JonnyMac ! Much appreciated! Today's goal for me is to get the project into the DevOps repository. DM me your email if you would like R/W access.
  • That SPI code in the interpreter cog works with the display. I have the basics running: clear(), line(), and rectangle() are working as expected.
  • Found a new bug. P1 font no longer works with FlexProp. Appears to have broken after FastSpin 4.1.3, back in the FlexGUI days. Works correctly with Proptool.
  • Found the issue. Not sure if this is something you want to look at @ersmith
        ''Write a 16x32 character to the screen at position 0-7 (left to right)
        cbase:=@P1Font+((ch & $FE) << 6)  ' Compute the base of the interleaved character
    Works but....
        cbase:=@P1Font+((ch&$FE) << 6)  ' Compute the base of the interleaved character
    Does NOT work in FlexProp 5.9.12.
    It does work with Propeller Tool 2.6.2.
  • ersmithersmith Posts: 6,283
    edited 2022-06-23 17:26
    @ke4pjw : When you say "Does NOT work" what do you mean by that? Does it give a syntax error, or does it compile incorrect code? Is this Spin1 or Spin2 code? I need some more context to figure this out, because for me the following two functions generate identical assembly code:
    DAT
    P1Font long 0
    PUB get1(ch) : cbase
      cbase := @P1Font+((ch & $FE) << 6)
    PUB get2(ch) : cbase
      cbase := @P1Font+((ch&$FE) << 6)
    EDIT: I downloaded your repo and tried both variations in oled_AsmDrv.spin2, and again, the generated assembly was the same in both cases.
    edited 2022-06-23 20:20
    @ersmith The P1 font was being mangled. I cannot reproduce the problem, now. Sigh. I apologize. I tested before and after and it was reproducible, more than once. It only worked correctly in an old version of flexGUI. It may be where I have some of the libraries pointed to in FlexProp that caused the issue. I can't make it do it now. Again I apologize.
    --Terry
    edited 2022-06-23 21:02
    There was different editions of the font. I made a point of eliminating all copies of one edition I had a couple of years back because it caused me grief. Err, I've found both again! I probably couldn't remember which one to delete, same as now.
    No worries, Terry. If you do find out what was going on please let me know and I'll look into it!
  • Version 0.9.4 released.
    Updated to run in a single cog.
    Updated write1x6String() and write1x16String() to process string length automatically.
    This version does not work in FlexProp 5.9.12. This is most likely related to the quick hack of moving the SPI code to inline PASM.
    Many, MANY things need to be cleaned up.
    For a nice clean implementation for the SSD1331, please see Jon's code at https://forums.parallax.com/discussion/174665/spin2-interpreter-tricks-for-cogless-96x64-oled-driver-now-works-w-flexprop
    edited 2022-07-01 05:53
    Version 0.9.5 released.
    A terminal string interface added. Includes scrolling and wraparound.
    CON
      _xtlfreq = 20_000_000
      _clkfreq = 160_000_000
      CS    = 10
      RST   = 12
      DC    = 11
      CLK   = 9
      DATA  = 8
    VAR
      byte i[4]
    OBJ
      OLED    :     "oled_AsmDrv"       ''OLED dedicated SPI engine in Assembly
    PUB  main()
      OLED.Init(CS,DC,DATA,CLK,RST)
      OLED.AutoUpdateOff()
      OLED.clearDisplay()
      i[1] := $30
      i[2] := $00
      repeat 9
         OLED.TERMSTRING(String("Test really really really really long line.", OLED.CR, OLED.LF),OLED.White,OLED.Black)
         waitms(500)
         OLED.TERMSTRING(String("Line 2", OLED.CR, OLED.LF),OLED.White,OLED.Black)
         waitms(500)
         OLED.TERMSTRING(String("Line 3", OLED.CR, OLED.LF),OLED.White,OLED.Black)
         waitms(500)
      OLED.TERMSTRING(String("Last line.  No CRLF"),OLED.White,OLED.Black)
      repeat
        waitms(9000)
  • Nice!
  • Version 0.9.6 released.
    SEND() method has been implemented.
    I want to add ANSI escape sequences to manipulate colors and cursor position. Maybe later this weekend.
    I want to thank @cgracey for implementing the SEND() method. The utility of that is incredible!
  • RaymanRayman Posts: 16,367
    @ke4pjw
    Fired up this code again for another project.
    One thing that think seeing is that in addition to setting I/O pins in the top file, one also has to set these pins in the assembly driver:
    lchipselect = 33'10
    clkout = 32'9
    txout = 31'8
  • @Rayman I thought that I had solved that. I filed a bug and will clean it up.
    Think you can override subobject constant values from the top object in the OBJ section...
    Maybe that's the easy way to fix it?
    Thought this OLED was basically the same as the one sold by Newhaven Display.
    But, seems was mistaken...
    Had to email Newhaven for help. They pointed me to some Arduino code.
    Ported that to FlexC and it works.
    Now, need to figure out why the code here doesn't work with it.
    Kind of a mystery...
    c
  • @Rayman Probably because I wrote it, lol!
    @ke4pjw your code works great on my parallax oled module. There must be some difference even though both have same ssd controller chip…
