New PNut-TS compiler for P2 development on Windows, Mac, Linux (yes, RPi) - Page 2 — Parallax Forums
2
  • NEWS
    We've just released v1.51.0, bringing PNut_TS up to par with PNut v51a
    Here's what's new/fixed:
    v1.51.0
    Updated Language Support
    • Add language version support through {Spin2_v51}.
    • Add command-line -F option which, when specified, causes the .flash file to be written (PNut -ci equiv.)
    • Preprocessor intermediate files now end with __pre.spin2 (vs. '-pre.spin2')
    • Preprocessor: #define is no longer affected by command-line -U options
    • Added #pragma exportdef SYMBOL which makes SYMBOL present as if added with -DSYMBOL on the command line but affects all files compiled after the file containing the #pragma (place in top-most file for best results)
    • {Spin2_v44} is no longer supported due to changes in data structures beginning in v45
    • Compatible with PNut versions through PNut_v51a.exe (except for PNut_v44.exe, which is no longer supported)
    • Performance fix: Issue #2 Compiling FILEs in DAT section needs attention - is slow
    PNut-TS is found at its new Public Repository, while the latest Releases are also found there at the Releases Page
    We do comprehensive regression testing in preparation for each release. We also add to our regression suite so all new capabilities are tested as well. You can review our coverage testing via regress at PNut-TS Coverage Testing
    If you spot any issues with code generation or compilation, you can review the testing process. This should help you identify differences between PNut v51a and PNut_TS v1.51.0.
    We look forward to hearing what you find.
    As always, you can report issues here, or better yet, if fixes are needed, then report problems at the repository issues page. (You can also see the current list of what's been reported at this page.)
    Stephen & Chip
  • maccamacca Posts: 1,010
    edited 2025-05-02 08:36
    Seems that the Linux x64 package contains the ARM executable (same as the Linux arm64 package).
    $ unzip pnut-ts-linux-x64-015100.zip
    Archive:  pnut-ts-linux-x64-015100.zip
       creating: pnut_ts/
      inflating: pnut_ts/LICENSE
      inflating: pnut_ts/CHANGELOG.md
      inflating: pnut_ts/AUTHORS
      inflating: pnut_ts/pnut_ts
      inflating: pnut_ts/README.md
      inflating: pnut_ts/Preprocessor.md
      inflating: pnut_ts/copyright
      inflating: pnut_ts/CommandLine.md
      inflating: pnut_ts/Goals.md
    $ file pnut_ts/pnut_ts
    pnut_ts/pnut_ts: ELF 64-bit LSB executable, ARM aarch64, version 1 (GNU/Linux), dynamically linked, interpreter /lib/ld-linux-aarch64.so.1, BuildID[sha1]=4786c866c75e9a87a389393cd98b619259af30dd, for GNU/Linux 3.7.0, stripped
  • again?
  • @macca i’ve uploaded one with correct content please let me know if fixed.
    @Wuerfel_21 yep, i’m a creature of scripts. Guess I better fix one of them! 😋
    Aside from the MacOS garbage :smile:, yes, it works.
    I think there are some missing things, the following sample source is what I used recently to fix most of my issues with pointers, it works with PNut v51a but not with pnut_ts:
    {Spin2_v51}
    CON
        STRUCT sPoint(word x, word y, byte c)
    PUB main() | a, b, ^sPoint ptr
        a := ptr.x++
        a := ++ptr.x
        a := [ptr]
        a := [ptr]++
        a := ++[ptr]
        a := ptr[++].x
        a := ptr[++].x--
        a := --ptr[++].x
        a := [++]ptr.x
        a := [++]ptr.x--
        a := --[++]ptr.x
        ptr.x := a
        [ptr] := a
        ptr[++].x := a
        [++]ptr.x := a
        a := ptr.x := b
        a := ptr[++].x := b
        a := [++]ptr.x := b
    /home/marco/pnut_ts/pnut_ts -I /home/marco/workspace/spin-tools-ide/library/spin2 StructTest.spin2
    pnut-ts: * Propeller Spin2/PASM2 Compiler 'pnut_ts' (c) 2024 Iron Sheep Productions, LLC., Parallax Inc.
    pnut-ts: * Version 1.51.0, Build date: 5/1/2025
    pnut-ts: * pnut_ts -I /home/marco/workspace/spin-tools-ide/library/spin2 StructTest.spin2
    pnut-ts: Wrote StructTest.obj (53 bytes)
    StructTest.spin2:7:error:Expected end of line (m281)
    pnut-ts: Done
    Commenting line 7, show same error on line 15.
  • Stephen MoracoStephen Moraco Posts: 445
    edited 2025-05-02 17:34
    We will add that to our regression test next week.
    Thank you for reporting this.
    And yeah, packaged that pretty quickly for you as I was heading to the airport 😊
    edited 2025-05-05 23:59
    NEWS
    We've just released v1.51.1, bringing PNut_TS up to par with PNut v51a
    v1.51.1
    Bugfix Release
    • BUGFIX: Issue (#7): Compile failure for post increment/decrement (Thank you, Macca, for reporting this!).
    PNut-TS is found at its Public Repository, while the latest Releases are also found there at the Releases Page
    If you spot any issues with code generation or compilation, you can review the testing process. This should help you identify differences between PNut v51a and PNut_TS v1.51.1.
    Stephen & Chip
  • @macca your fixes are in. Thank you for reporting this.
  • Hi Stephen,
    I download the new pnut_ts for Mac.
    There is something wrong with pnut-ts-macos-arm64-015102.zip 30.4 KB
    It is only 30kB long!
    edited 2025-05-20 21:16
    @wummi said:
    Hi Stephen,
    Hi, there's nothing wrong. It's just that including the node runtime on the Mac is not working.
    So I ask you to install the Node runtime separately.
    Once you install the Node.js runtime, the pnut_ts file you downloaded will run just fine. See Instructions
    I also try to remind us of this in the release notes.
  • Good morning Stephen,
    /Applications/pnut_ts/pnut_ts v1.51.1 is 991 kByte long.
    /Applications/pnut_ts/pnut_ts v1.51.2 is 28 kByte long, this must be wrong!
    And I get this when I run pnut_ts:
    /Applications/pnut_ts/pnut_ts "-d" VSC.spin2
    node:internal/modules/cjs/loader:1408
      throw err;
    Error: Cannot find module 'commander'
    Require stack:
    - /Applications/pnut_ts/pnut_ts
        at Function._resolveFilename (node:internal/modules/cjs/loader:1405:15)
        at defaultResolveImpl (node:internal/modules/cjs/loader:1061:19)
        at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1066:22)
        at Function._load (node:internal/modules/cjs/loader:1215:37)
        at TracingChannel.traceSync (node:diagnostics_channel:322:14)
        at wrapModuleLoad (node:internal/modules/cjs/loader:235:24)
        at Module.require (node:internal/modules/cjs/loader:1491:12)
        at require (node:internal/modules/helpers:135:16)
        at Object.<anonymous> (/Applications/pnut_ts/pnut_ts:11:21)
        at Module._compile (node:internal/modules/cjs/loader:1734:14) {
      code: 'MODULE_NOT_FOUND',
      requireStack: [ '/Applications/pnut_ts/pnut_ts' ]
    Node.js v23.9.0
    Node.js v23.9.0
    Ok, I'm on this. will investigate and post updated version shortly. Thank you for being persistent in letting me know!
  • @wummi, The macOS assets for release v1.51.2 have been replaced with the correctly built .zip files.
    I've updated my packaging script to (hopefully) prevent this in the future.
    Thanks again for pointing this out.
  • @Stephen, I try to compile my big P2-Project and get: error:OBJ data exceeds 1024k limit
    5 month ago PNUT v48 shows the same Error.
    Chip has found the problem and fix it in SPIN v49.
    He expand the space to 4MB and he found that an internal stack overflow was occurring during compilation when it got six levels deep in objects. Now, it will do all 16 levels
    We did this translation by studying Chip's code and making our typescript version the same or better, so we must have missed something. I'll check with Chip, and then we'll get this fixed.
  • @Stephen, there is the same problem with VSC Spin2 extension.
    When I try to edit my big project i get: [Error - 18:27:05] The Spin2 Language Server server crashed 5 times in the last 3 minutes. The server will not be restarted.
    This is new, 3 weeks ago i edit the project with VSC and there are no problems.
    Not the same problem. The latest highlighter is dying on something in your code. Can you share a portion of your crashing code? I'll fix it and release a new version for you.
  • @Stephen, I found the object which crash the Spin2 Language Server.
    It is the biggest object in the project.
    When you give me your email, I send you the file.
    edited 2025-05-27 18:40
    NEWS
    We've just released v1.51.3.
    v1.51.3
    New include behavior and BUGFIX
    • New Feature: Allow OBJ and DAT files to be found via -I {include} directories (#9) Requested by github user @AustinMathuw
    • BUGFIX: Issue (#10) Old OBJ limit still in place
    If you encounter any issues with code generation or compilation, you can review the testing process outlined in this document. This should help you identify differences between PNut v51a and PNut_TS v1.51.3.
    Stephen & Chip
    I left a message for you...
  • Hi @"Stephen Moraco",
    I just tried the latest version of PNut-TS with a PASM2 code and run into an error using $. It looks like that the compiler does it only accept with a PASM2 instruction. With PNut it is working anywhere in the DAT section.
    CON
    _CLKFREQ        = 4_000_000
    DAT
                    org     0
    start
                    jmp    #$
    .end_of_code
                    long    $AA55_BB44[$1F0 - $]
                    fit     $1F0
    /Applications/pnut_ts/pnut_ts Test.spin2
    pnut-ts: * Propeller Spin2/PASM2 Compiler 'pnut_ts' (c) 2025 Iron Sheep Productions, LLC., Parallax Inc.
    pnut-ts: * Version 1.51.5, Build date: 9/30/2025
    pnut-ts: * pnut_ts Test.spin2
    pnut-ts: Wrote Test.obj (53 bytes)
    Test.spin2:12:error:"$" (DAT origin) is only allowed in DAT blocks
    pnut-ts: Done
    Thanks for the heads up and the code example. I'll get this fixed and a new release posted soon.
    edited 2025-12-26 22:43
    NEWS
    We've just released v1.51.7. With all my work with building and testing projects lately, I found myself needing to know where objects in my code landed in the image. So I decided to add a .map feature to tell me this! (Necessity is... ;-)) Oh, and I fixed some bugs too!
    v1.51.7
    • New Feature: Added -m / --map command-line option to generate memory map files (.map). The map file provides a detailed narrative of the compiled object structure, memory allocation, and multi-object relationships.
    Fixed
    • Error Codes: All duplicate compiler error messages now have unique error codes for easier troubleshooting and support
    • Compatibility: Symbol names exceeding 30 characters now generate an error, matching the original PNut compiler behavior
    • BUGFIX: Fixed -I include path handling - paths relative to the current working directory now work correctly (previously only paths relative to the source file worked)
    • BUGFIX: Missing #include files now properly stop compilation with a standard-format error message instead of silently continuing
    • BUGFIX: Fixed $ (DAT origin) operator not working in DAT data declarations like long value[$1F0 - $]. The operator now works anywhere in DAT blocks, not just in PASM instruction operands. (Thank you @kaio for reporting this!)
    @Kaio, this work resulted in my adding another regression test with the code you provided, so we don't miss this in the future.
    Actually, in this release cycle, we added a large number of regression tests. For the latest test coverage (not code coverage), see: PNut-TS Regression Test Coverage Report. My goal is to continue increasing this test coverage with every release so we stay fully compatible with PNut for Windows.
    As always, you can report issues here, or better yet, if fixes are needed, then report problems at the repository issues page. (You can also see the current list of what's been reported on this page.)
    Stephen & Chip
    I have just started to work with pnut_ts and I see the following issue:
    ❯ pnut_ts -v -d -l struct_test.spin2
    pnut-ts: Verbose output is enabled
    pnut-ts: * Version 1.51.7, Build date: 12/26/2025
    pnut-ts: * pnut_ts -v -d -l struct_test.spin2
    pnut-ts: Compiling with DEBUG
    pnut-ts: Verbose- Working with file [struct_test.spin2]
    pnut-ts: Verbose- * Write listing file: struct_test.lst
    pnut-ts: Verbose- ext dir [/snapshot/PNut-TS/out/ext]
    pnut-ts: Verbose- lib dir [/snapshot/PNut-TS/out/lib]
    pnut-ts: Verbose- wkg dir [.]
    pnut-ts: Verbose- Node version: v18.5.0 (built-in)
    pnut-ts: Verbose- Compiling file [struct_test.spin2]
    struct_test.spin2:6:error:Expected "=" "[" "," or end of line
    I have attached the Spin2 source.
    This works in flexspin and Spintools.
    I am seeing the same in other files when defining structs even from the examples in the Spin2 docs.
    Also same in pnut-term-ts which I assume uses the same core.
    Thanks in advance
    I forgot to mention I am running on Debian Linux machine.
    Bob
    Please disregard the last line comment about pnut-term-ts. With correctly compiled files pnut_term-ts is working fine so far.
    Thanks! Looking into this. More soon!
    edited 2026-02-14 06:58
    @TrapperBob, well, that was a fun search!
    your line BYTE test is causing the problem for both PNut and PNut-TS.
    Both PNut v52a AND PNut-TS v52a reject this code at line 10 - this is consistent behavior.
    • PNut v52a error: Expected a unique variable name
    • PNut-TS v1.52.1 error: Expected a unique variable name, STRUCT name, BYTE, WORD, LONG, "^", ALIGNW, or ALIGNL
    The issue is that PNut and PNut-TS currently treat pasm instruction names as reserved words. TEST is a pasm2 instruction.
    (Interesting that this works in FlexSpin and Spintools. I'll discuss this further with Chip)
    edited 2026-02-14 08:04
    NEWS
    We've just released v1.52.1, bringing PNut_TS up to par with PNut v52a
    v1.52.1
    • Add language version support through {Spin2_v52}.
    • Compatible with PNut versions through PNut_v52a.exe (except for PNut_v44.exe, which is no longer supported)
    We do comprehensive regression testing in preparation for each release. We also add to our regression suite, so all new capabilities are tested. You can review our coverage testing via regress at PNut-TS Coverage Testing
    If you spot any issues with code generation or compilation, you can review the testing process. This should help you identify differences between PNut v52a and PNut_TS v1.52.1.
    As always, you can report issues here, or, better yet, if fixes are needed, report problems on the repository issues page. (You can also see the current list of what's been reported at this page.)
    Stephen & Chip
    Thank you for pointing out the reserved words issue. I have changed that and now am seeing the next layer of the onion so to speak when trtying to use the Spin2 Extension integration of VSCode.
    Using VSCODE and running:
    Tasks: Run Build Task and selecting "compileTopP2" from popup
    I get the following:
    • Executing task: /home/bob/.local/bin/pnut_ts "-d -l"
    PNut-TS: error: unknown option '- -l'
    pnut-ts: * Version 1.52.1, Build date: 2/14/2026
    pnut-ts: * pnut_ts -d -l
    arguments: [ '- -l', length: 1 ]
    combArguments: [
    '/home/bob/.local/bin/pnut_ts',
    '/snapshot/PNut-TS/out/pnut-ts.js',
    '-d -l',
    options: { debug: true }
    pnut-ts: ERROR- Missing filename argument
    pnut-ts: Aborted!
    It is obvious from the Executing task line that it is missing to filename to compile.
    Tasks: Run Build Task and selecting "compileP2" from popup
    * Executing task: /home/bob/.local/bin/pnut_ts "-d -l" struct_test.spin2
    pnut-ts: * pnut_ts -d -l struct_test.spin2
    pnut-ts: Wrote struct_test.bin (9778 bytes)
    pnut-ts: Done
    Also I see the following:
    If I run the pnut_ts command in the vscode terminal window manually
    The compile runs correctly with both a listing file and a .bin file
    ❯ pnut_ts "-l" "-d" struct_test.spin2
    pnut-ts: * pnut_ts -l -d struct_test.spin2
    pnut-ts: Wrote struct_test.lst
    pnut-ts: Done
    VSCode Version: January 2026 (version 1.109)
    The latest Spin2 Extension is installed: 2.5.0
    The subject Spin2 file is the same as in post #55 above with the name of the byte struct renamed as you pointed out.
    This is happening on all my files Spin2 in separate directories
    Please help me to understand what I have possibly mis-configured to cause this.
    Bob
