Process serial string input? — Parallax Forums
Just checking before reinventing some wheels...
Getting data input on a P2 pin as TTL serial text.
The data string looks like this:
VAC1=3.99e+01 VAC2=2.17e-01 VAC3=9.04e+02
Is there something already that can turn a string into a float?
Would also be convenient if something could parse this input, but guessing not...
  • This probably won't help -- but maybe it will inspire something. Last year I helped a friend who wanted to send floats through serial commands. I used my standard parser to get the chunks out of the string, and then this simple code to convert values from string to float. It doesn't support scientific notation though.
  • RaymanRayman Posts: 16,025
    Thanks @JonnyMac, this does look like will help.
    tokenizer seems to work.
    Zero based token index.
    Seems rigged to tokenize on white space.
    got the input parsed into three strings now.
    Close to having it done...
    Actually want to process input from two serial ports. Don't want to waste cogs though.
    Fortunately, found the @"Stephen Moraco" 8x serial input code in OBEX:
    https://obex.parallax.com/obex/p2-high-speed-8-port-serial-subsystem/
  • JonnyMacJonnyMac Posts: 9,637
    edited 2025-04-09 20:50
    You probably have this sorted, but I knocked this together while having lunch and waiting on the Zoom call. It will take a "parameter=value" string and breaks up the parts, filling strings you specify.
    pub parse_cmd_value(p_str, p_cmd, p_val) | i
      i := find_chr("=", p_str)                                     ' look for separator
      if (i < 0)                                                    ' abort if not found
        return
      bytemove(p_cmd, p_str, i)                                     ' copy command to own string
      byte[p_cmd][i] := 0
      i++                                                           ' skip separator
      bytemove(p_val, p_str+i, strsize(p_str)-i)                    ' copy value to own string
      byte[p_val][strsize(p_str)-i] := 0
    pub find_chr(c, p_str) : pos
    '' Return index of first occurance of c in p_str
    '' -- returns -1 if not found
      repeat pos from 0 to strsize(p_str)-1
        if byte[p_str][pos] == c
          return
      return -1
    I almost have parsing an FP string in Scientific notation working.
    edited 2025-04-10 16:28
    This gets a little long, but -- so far -- seems to work. I added the ability to detect sci-notation and deal with the exponent. I checked the return values using this page:
    -- https://www.h-schmidt.net/FloatConverter/IEEE754.html
    pub str2fp(p_str) : result | sign, dpflag, d, e, b
    '' Convert string to floating point
    '' -- legal characters: "-", "+", "0".."9", ".", "E", "e"
      repeat                                                        ' strip leading spaces
        if (byte[p_str] == " ")
          p_str++
        else
          quit
      sign, dpflag, d := 1.0, false, 1                              ' preset locals
      if (byte[p_str] == "-")                                       ' check for sign
        sign := -1.0                                                '  set
        p_str++                                                     '  skip
      elseif (byte[p_str] == "+")
        p_str++
      repeat                                                        ' get significand
        b := byte[p_str++]                                          ' get byte from string
        case b
          "e", "E", " ", 0 :                                        ' done?
            quit
          "0".."9" :
            result := (result * 10) + (b - "0")                     ' add new digit
            if (dpflag)                                             ' past dpoint
              d *= 10                                               '  yes, bump divisor
            if (dpflag == false)                                    ' new decimal point?
              dpflag := true                                        ' set flag
            else
              return 0.0                                            ' invalid 2nd decimal point
          other :
            return 0.0                                              ' illegal character
      result := sign *. float(result) /. float(d)
      if (b <> "e") && (b <> "E")                                   ' done if no exponent
        return
      sign, e := 1.0, 0                                             ' reset for exponent
      if (byte[p_str] == "-")                                       ' check for exponent sign
        sign := -1.0
        p_str++
        p_str++
      repeat                                                        ' get exponent
        b := byte[p_str++]
        case b
          0, " " :
            quit
          "0".."9" :
            e := (e * 10) + (b - "0")
          other :
            return
      if (e == 0)                                                   ' done if exponent == 0
        return
      ' adjust significand with exponent
      if (sign == 1.0)
        result := result *. float(XPower[e])
      else
        result := result /. float(XPower[e])
    dat
      XPower        long    1                                       ' 10 ^ 0
                    long    10
                    long    100
                    long    1_000
                    long    10_000
                    long    100_000
                    long    1_000_000
                    long    10_000_000
                    long    100_000_000
                    long    1_000_000_000                           ' 10 ^ 9
    For this app, there's a very limited range of exponents possible.
    So, just did significand and exponent separately.
    Also, turning this Torr floating point value into integer number of milliTorr....
    Processed exponent like this:
    pub sExponent_To_Factor(p):fac  'Turn exponent into a factor to multiply significand by
    'Neet to turn "-03" into 1 and "+03" into 1_000_000
      if strcomp(p,string("-03"))==-1
        return 1
      if strcomp(p,string("-02"))==-1
        return 10
      if strcomp(p,string("-01"))==-1
        return 100
      if strcomp(p,string("-00"))==-1
        return 1_000
      if strcomp(p,string("+00"))==-1
        return 1_000
      if strcomp(p,string("+01"))==-1
        return 10_000
      if strcomp(p,string("+02"))==-1
        return 100_000
      if strcomp(p,string("+03"))==-1
        return 1_000_000
  • Cool.
