Pitfalls and crawling out... GetSec() behaves not as I expected, to slow and counting down - Page 2 — Parallax Forums
2»
  • evanhevanh Posts: 16,508
    edited 2025-04-01 11:11
    Forget the first MOV, and ALTS's D operand is meant to be the index.
           'Update pattern here
            alts     PatIdx_, #PWMPatt00   ' PatternIdx added
            mov      PattCurr,  0-0
  • AribaAriba Posts: 2,693
    As long as the pattern table is in the cogram (of the same cog that executes the code), the ALTS approach should work. I would write it like that:
            alts     PatIdx_, #PWMPatt0   ' PatternIdx added to pattern table addr
            mov      PattCurr,  0-0
    Andy
  • ErNaErNa Posts: 1,828
    OK, I was close, just not close enough! Now it works as expected. Nothing like the Prop around !
  • JonnyMacJonnyMac Posts: 9,307
    edited 2025-04-01 15:59
    Just a reminder that CANONICAL Spin2 (that is, compiled by PNut/Propeller Tool/Spin Tools) can do assembly testing without invoking a separate cog. I've never used ALTS but think it will be useful in an upcoming project so I took Andy's suggestion and wrapped it into an inline test. It works as intended. Thanks, Andy!
    pub demo_alts()
      org
                            mov       pr0, #0
    .loop                   alts      pr0, #Fib0
                            mov       pr1, 0-0
                            debug("Index: ", udec_(pr0), "  Fibo:", udec_(pr1))
                            waitx     ##(CLK_FREQ >> 2)
                            incmod    pr0, #9               wc
            if_nc           jmp       #.loop
                            ret
    Fib0                    long      0
    Fib1                    long      1
    Fib2                    long      1
    Fib3                    long      2
    Fib4                    long      3
    Fib5                    long      5
    Fib6                    long      8
    Fib7                    long      13
    Fib8                    long      21
    Fib9                    long      34
      end
    Inline ASM works in flexspin, too, no need to stress out. Recently a new mode has been added that's even more compatible with PNut (Put {++opt(!fast-inline-asm)} between PUB/PRI and the method name to enable - other compilers treat this as a regular comment)
    Lol, that might be a little overkill. Jon was just saying he hasn't tested using Flexspin so can't speak for it. His example assembly will compile in just fine without special controls.
    The main reason Eric added that full assembler compatibility switch was to provide compile-time cogRAM allocation warnings for two of my chunky Pasm2 Fcache'd routines that use big RES directives. The default assembler can't do the calculation to give a warning.
    edited 2025-04-09 16:53
    Coming out with the next question: the smartpin modes are very nice, as I suppose ;-) and now I have to use the ADC the way I'm used the P1: read the ADC counter at any time and determine the number of counts form successive reads at certain times by subtraction. If for example I read the counter 3 times 100 µs apart, the wait for 1 ms to read another three values, I can see, if the signal changes a little.
    I have to figure out, if this is possible...
    Is it as simple as using "RQPin" ?
  • I think there is no "free running" mode that behaves exactly like the P1 did. But there are a lot of possible tricks. If you need to sync the ADC sampling window to a PWM you could probably use the Goertzel mode and "abuse" the weighting table to generate seperate sampling windows for the high and low phases.
    Or you can use one of the SINC filtering modes with a low sampling period and add a number of samples together.
    Mind that the ADC low-level pin mode and the ADC smart mode are independent of each other. The former generates a bitstream that's integrated and sampled by the latter. You could select the ADC pin mode with one of the counting smart modes to get a P1-style thing. I think, anyways, haven't tried it to see if there's a gotcha.
    edited 2025-04-10 00:50
    Certainly can, Sinc1 filtering is the Count-Highs mode: pinstart(<pin number>, P_ADC_1X | P_COUNT_HIGHS, <sample period>, 0)
    For totalising counter mode just set the sample period = 0, so then it's up to the software to diff.
    PS: Silicon Manual has it named as %01111 AND !Y[0] = Count A-input highs
    edited 2025-04-10 20:54
    @evanh, that shows good results when I run a first test. Now I have to do is in ASM and it looks, the smart pins are smarter than me ;-)
    OK, I have the first conversion running! The signal is way better, than what I'm used to know from the P1! Thanks to all that took part in the development of this great chip!
    All to do: set up the ADC and later read and calculate the difference!
    ' setup ADC Pin 43 Shun
                    fltl    pinAdcSh                      'set pin to ADC mode
                    wrpin   adc_modes,   pinAdcSh
                    wxpin   #0,          pinAdcSh         '#0 is 1-clock
                    drvl    pinAdcSh                      'start pin
                    rdpin   Sh_Val0, pinAdcSh      ' Read ADC
                    sub     Sh_Val0, oldValu       ' determine increase of counter
                    add     oldvalu, Sh_Val0       ' update to current counter value
    That's it.
    And you will have very nice signals from a 50 kHz source!
    I'm working with a data buffer:
    CON
    RingBufSiz  = 4096  '32_768   '  8192'
    RingBufSize = 1024
    DAT
    RiBufSz   long 0
    RingBuf   long 0 [RingBufSiz]
    RingBuf1  long 0 [RingBufSize]
    The app works as expected with a buffer size of 4096, but no longer with 8196. While I'm looking deeper into this issue: Is there any limitation of the Array size (I can not imagine this to be the case)
    Why why don’t you show the code that deals with head and tail pointers?
    This is a very primitive version. One COG reads the ADC at 50 kHz and writes data to the hub until the buffer is filled. A flag is set. A plot routine plots the buffer and resets the flag after completion. I just want to be sure, that larger arrays up to the memory limits are possible. Ringbuf1 is defined just to protect the memory if there is any leak, but this buffer is OK, as far as I have tested. Will be out of office tomorrow and dig into it on Wednesday.
    edited 2025-05-06 02:18
    If you're doing any left-shifts or multiplies, those can easily lose the most significant bit as the initial value is increased. MULDIV64() is available for re-scaling without chopping the tops off.
    edited 2025-05-08 17:49
    One bug found: a missing character when two variables share the "same" name. So the answer is "Yes, your arrays can use all the memory available". The bug again was sitting in front of the screen ;-)
    Next: I used a terminal to start the program, which was boring and so I did an auto-start. Accidentally I realized, larger array worked, it was the terminal program that stalled for unknown reason....
    edited 2025-05-21 15:18
    Debugging the issue with Array size:
    I have a rather complex program using 7 COGs, the original P1 version worked for more than a decade, limited by space and speed. This program is moved to the P2, needed only little modification, some systematically, others more difficult to find. Now I face this situation:
    There is a set of buffers, normally 1k of LONGs. Now, that the functions mostly work, I tried to extend the buffer and it came to a stall of the display process. Carefully adjusting the buffer size I could find the limit. Adding another line of code stalled the program again, reducing buffer size brought the program to life again.
    Setting breakpoints I realized, that the screen-routine stalls indeed and finally I realized, the DAT section of the screen process is corrupted.
    This is data dumped when OK:
    and this is when something goes wrong:
    I use Propeller Tool 2.9.3, but had the same result using the current pnut
    edited 2025-05-21 16:16
    OK: could be, I use word pointers, and that is just not enough using more than 64K! And the problem arises obviously the moment, the local data is stored at higher memory addresses
    YES, that did the job!
    This is strange:
      clkset (clkmode_, clkfreq_)
      dirb[7] := 1
      repeat
        outb[7] := 1
        outb[7]:= 0
    I expect Pin 39 to toggle: but he is reluctant!
    edited 2025-05-28 14:59
    If you're going to do it in Spin2, why not be obvious about it?
      repeat
        pintoggle(39)
    dirb and outb are registers in the interpreter.
    This is what I get when running the P2 at 200MHz.
    OK, this was the minimal program, that didn't work. "dirb and outb are registers in the interpreter" Does this mean, they can no longer be used for I/O? I used "mov outb" in assembler, what works like I'm used from the P1.
    Pintoggle did what it should, my original task is to set a trigger and reset it, so I tried "pinhigh() and pinlow()", what also toggles the pin, so I can move it to the right places. Thanks for helping out.
  • I think the meaning of something like outa[N] changed from "Nth bit of OUTA" to "register[OUTA + N]" in Spin2, because there is a proper bit access operator (that would be OUTA.[N]).
    Jon is 100% correct in that there is almost never a reason to directly touch the OUT/DIR/IN registers, especially not from Spin2.
    (The "almost never" case being where you want to write multiple bits to pins at once and using the streamer to do it isn't possible/appropriate, so you'd do SETBYTE/MUXQ/etc on OUTA/OUTB)
    Spin2 has better direct pin control than Spin1 so some mechanisms used in the P1 no longer apply to the P2; this instance being an example. It's important to remember that dira[] and outa[] as used in the P1 looked like direct register manipulation, but under-the-hood required a bit of work creating the mask(s) required by the PASM1 code and applying them appropriately. Spin2 and PASM2 are much friendlier for IO control.
