Pitfalls and crawling out... GetSec() behaves not as I expected, to slow and counting down — Parallax Forums
ErNaErNa Posts: 1,859
edited 2025-03-11 11:32 in PASM2/Spin2 (P2)
I use this setting for timing:
con { timing }
  CLK_FREQ = 200_000_000                                        ' system freq as a constant
  MS_001   = CLK_FREQ / 1_000                                   ' ticks in 1ms
  US_001   = CLK_FREQ / 1_000_000                               ' ticks in 1us
  _xtlfreq = 20_000_000 '25_000_000
  _clkfreq = CLK_FREQ                                           ' set system clock
repeat
    term.PutValhex ( 5, 15, "i", ":", GetCt() )
    term.PutValhex ( 5, 16, "T", ":", Getsec() )
    term.PutValhex ( 5, 17, "S", ":", GetmS() )
But GetSec() needs about 10 seconds to count. Do I have to configure something else?
The baud rate works perfect with the setting, I'm using a P2 Eval board
p.s. GetSec counts backward
Some more analysis: GetCt() works as expected, Getsec() counts when GetCt() wraps round. Getms() counts fast, but not milliseconds and GetSec and Getms start at $FFFF_FFFF and count down
Strange things happen: If I use Getsec() is a demo program, it works fine. But no longer in the application., running in a different COG. GetSec() actually counts backward at the overflow of GetCt().
I'll run more tests when time comes..
«13
  • JonnyMacJonnyMac Posts: 9,826
    edited 2025-03-02 21:30
    It's very possible that you're creating a buffer overrun in the terminal you're using. There is no breathing room between loops in your code to let the terminal clear its buffer. If it takes more time to process/display your input than it does for the terminal to receive it, you'll eventually step on yourself.
    I ran a simple test and getsec() works as expected (incrementing count). I used PST (which has that overrun problem if you don't give it breathing room).
  • This seems to work, too:
  • ErNaErNa Posts: 1,859
    Thanks for help, it was just to take advantage of this new feature. The application is quite complex and doesn't work completely, I finally did it the old-fashioned way and now the display show the right ticks of seconds. The moment the screen updates all the variables (just now, it is reluctant), I'll give GetSec() another try.
    edited 2025-03-02 22:33
    Where to find the subtle difference between
    _clkfreq, clkfreq and clkfreq_?
  • evanhevanh Posts: 17,245
    edited 2025-03-02 23:09
    Last section, called Clock Setup, of Spin 2 Language Documentation - https://docs.google.com/document/d/16qVkmA6Co5fUNKJHF6pBfGfDupuRwDtf-wyieh_fbqw
    • _clkfreq and _clkmode are the user constants of desired startup sysclock frequency/mode to be compiled. Should never be used in methods. Only define in the CON section.
    • clkfreq_ and clkmode_ are the compiled constants of startup sysclock frequency/mode. Use these in your methods.
    • clkfreq and clkmode are system variables that contain dynamic runtime settings. These are adjusted by clkset(). If such is used then all timing methods should also use these variables in place of the above compiled constants.
    I used both in pllset() method. It adjusts the runtime variables as well as extracting board specific compile-time parameters from the constants - https://obex.parallax.com/obex/pllset/
    OK. I now have a first statement in the Main: clkset (clkmode_, clkfreq_) and the program show sound behavior, no symptoms of overrun. Another step. Thanks.
    I'm falling into another pit: as mentioned, I initated clkfreq : clkset (clkmode_, clkfreq_) A timer is running on a cog started. This timer created problems before, because I migrated software from the P1, that used clkfreq, the compiler was fine with that.
    Now I'm working to implement Cluso's LCD driver, overcome some hurdles, but so far, it's ok. What happens: In the main I create a tick reading clkfreq
    if (tick - GetCt()) < 0 Lcd_.HandsRoundclock() tick += clkfreq ' +1S
    This works as long as I do not activate the other cog creating a tick. I checked, I never write to clkfreq and I only once use clkset.
    If I change clkfreq to clkfreq_, it works fine.
    The behavior is, that clkfreq looks to be a constant, because ticks run for about the same time as they stall. I'll try to find the reason, but any idea is welcome.
  • If you only want to set speed once, do not use CLKSET, just set
    CON
    _CLKFREQ = 300_000_000 ' Or whatever you need it to be
    Computing the right clkmode value at runtime is tricky
    If I understood correctly, clkfreq and clkfreq are constants. clkfreq is a register. From Spin-documentation:
    CLKSET(NewCLKMODE, NewCLKFREQ) Safely establish new clock settings and update CLKMODE and CLKFREQ.
    As ClkFreq is located in Hub-Ram, I suspect, I accidently overwrite this location, have to investigate...
    HubRAM variable only.
    That would be bad,
    edited 2025-03-10 17:18
    I'm really simple. I set the program running speed from the constants section in my topmost cog.
    con { timing }
    Since child objects don't have access to my CLK_FREQ constant, they use the system variable clkfreq to determine running speed when needed.
    Wise move for library type code. It can then handle the user program making runtime frequency changes too.
    OK, it looks as if the hub ram is corrupted. I output the value, correct 200.000.000, the moment, the other program starts, it nullified. So there is a bug in another place and I have to find it. So using this register is a bug-indicator ;-)
    clkfreq is located $44 in hub memory. So it is unlikely I overwrite this location and the SPIN-interpreter is not corrupted? I tested $40 and $48, they are unchanged ;-(
    I'm coming close:
                 long[LONG[@Val011[MirrOffs]]] := ((long[LONG[@Val014[MirrOffs]]]*AnzaPoPa)<<12 / WklMeDiv)//3600
                 long[LONG[@Val009[MirrOffs]]] :=   long[LONG[@Val014[MirrOffs]]]          <<12 / WklMeDiv
                 long[LONG[@Val007[MirrOffs]]] := (((long[LONG[@Val079[MirrOffs]]]*((ClkFreq~>8))) / long[LONG[@Val080[MirrOffs]]]~>8)*60) / IncrRevo
    I can see, that clkfreq ($44) is set to zero, if and only if, the last of the lines above is executed. If the line is commented out, the timer runs correctly! Maybe there is a bug only when this program is running on a P2. We'll see.
    edited 2025-03-10 23:14
    Yep, the ~ operator changed from Spin1 to Spin2. It now erases the variable!
    From docs:
    var~ Return var, post-clear all bits in var
    EDIT: Oh, err, wow, never even knew about ~> operator. The equivalent Spin2 is: (ClkFreq SAR 8)
    PS: I wouldn't used that operator though. The frequency variable is unsigned in nature. Just use >> right-shift operator instead.
    edited 2025-03-11 07:55
    That's unexpected:
    Separation of ClkFreq fixes the problem!
                 fxck := ClkFreq
                 long[LONG[@Val007[MirrOffs]]] := (((long[LONG[@Val079[MirrOffs]]] * (( fxck~>8))) / long[LONG[@Val080[MirrOffs]]]~>8)*60) / IncrRevo
    Even if I shift ClkFreq~>2, the variable is set to $0
    From docs:
    Thanks, luckily you didn't know about this operator.
    I had changed ~> to SAR in other source files, but it slipped through here. You see other places, and I wouldn't have the starting point if not clkFreq was nulled. ;-) Lucky me.
    A next problem:
              x := byte[@SH00][sprev*2+1]   << 24
              x := x SAR 24
              drawLine(CX, CY, CX + byte[@SH00][sprev*2], CY + x, fgm)'bgd)   ' remove prev second hand
    '          drawLine(CX, CY, CX + byte[@SH00][s_cur*2], CY + byte[@SH00][s_cur*2+1], fgs)   ' show second hand
    I'm modifying Clusos LCD-demo to have a clock, I can move around. Adding byte valued hands coordinates to a long results in an error if the byte value is negative.
    Had to find SIGNX.
    I just run into a problem when migrating from DIRA[7..0] in P1 to the P2. I have to use Port B. For single pins it is working, but no range does what expected. Is there a simple replacement or do I really have to study the smart pins just now?
    PINLOW [39..32] works, but that is not a simple replacement. Is there a "PINTOGGLE" function?
  • Is there a "PINTOGGLE" function?
    Yes. Spin2 is documented here:
    -- https://docs.google.com/document/d/16qVkmA6Co5fUNKJHF6pBfGfDupuRwDtf-wyieh_fbqw/edit?tab=t.0#heading=h.1h0sz9w9bl25
    You'll find
    • pinhigh()
    • pinlow()
    • pintoggle()
    • pinwrite()
    • pinfloat()
    • pinread()
    To deal with multiple pins you need to create a pin group with addpins.
      pinlow(32 addpins 7)
    If you're writing to an 8-pin bus, you can do this
      pinwrite(32 addpins 7, value)
    To keep you code cleaner and easier to edit, you can define the bus pins group as a constant
    CON
      LCD_BUS = 32 addpins 7
    edited 2025-03-28 16:46
    OK, thanks for helping with the pins. And now the counters (ASM):
    I was used to wait for a counter to reach a value: waitcnt TimTrig, #0
    WaitCnt doesn't exist any longer, I have to loop for just now, but there are three counters to wait for. Just have to make the choice. If I know how.
    OK, I made a hit in the hardware manual Page 22, System counter...
    edited 2025-03-28 17:53
    I'm working on a new product that needs to update pixels at a very specific rate while also checking on inputs from buttons, IR (laser-tag guns), and RF (XBee coms from control system). I came across the pollct() Spin2 instruction which returns true or false instead of blocking like waitct() does. If you don't have Chip's PNut compiler archive you might consider downloading it. Chip always includes his PASM2 code for the interpreter in that archive. From that I found that the cmpm instruction is a the heart of pollct() and I've been using it in a lot of code. Here's a simple example.
    dat
                            getct     pr0                           ' start of period
    .loop                   ' do something
                            getct     pr1                           ' get now
                            cmpm      pr1, pr0              wc      ' period done?
            if_c            jmp       #.loop
    In this case if the C flag is set the period has not expired.
    That's not the case. In Spin2:
      t := getct()
      repeat
        ' do something
        waitct(t += LOOP_TIX)
    In PASM2:
    dat
                            getct     timer                         ' get now
                            ' do something
                            addct1    timer, #TRGT_TIX              ' set target
                            waitct1                                 ' wait to reach target
    Of course, for simple delays (with no work being done while holding) you have the waitx instruction.
    It will take a lot of time 'till you can just play the Propeller. Always surprising news around the corner! I have to expand an existing P1 software, have to do housekeeping, removing all the garbage, which sometimes turns out be of hidden importance, ... This is fun to do, but takes time and time, so searching for a function can take hours, you urgently need in another place. The counter-stuff also is tricky and I can make good use of this later...
    Thanks for pointing me to to sources..
    If you're simply pausing the program for a short time then use WAITX instruction. It's simpler than the old WAITCNT. Spin2 also has the waitms() and waitus() functions.
    I need waitct, but it is great to have three counters, so I can have them interleaved. Have to have variable times to measure a signal, but I'm making progress.. Only sometimes I waste some hours watching a few lines of code ;-)
  • Have to have variable times to measure a signal,
    Smart pins can help. Have a look at this thread:
    -- https://forums.parallax.com/discussion/176164/using-a-smart-pin-to-get-frequency-of-a-pin
    Yes, various smartpin modes have their own timers.
    Before I waste time:
    There is a list of patterns and I have to load a distinct pattern using an index.
    My first attempt was to use ALTS, but something went wrong:
           'Update pattern here
            mov      scratch,    #PWMPatt00      ' register address of first pattern
            alts     scratch, PatIdx_   ' PatternIdx added
            mov      PattCurr,  0-0
    DAT
    scratch     long  0
    PWMPatt00     long  %00__10_10_10___00__10_10_01___00__10_01_01___00__01_01_01  ' 0 5
    PWMPatt01     long  %00__10_10_10___00__10_01_10___00__10_01_01___00__01_01_01  ' 1 4
    PWMPatt02     long  %00__10_10_10___00__10_01_10___00__01_01_10___00__01_01_01  ' 2 3
    PWMPatt03     long  %00__10_10_10___00__01_10_10___00__01_01_10___00__01_01_01  ' 3 2
    PWMPatt04     long  %00__10_10_10___00__01_10_10___00__01_10_01___00__01_01_01  ' 4 1
    PWMPatt05     long  %00__10_10_10___00__10_10_01___00__01_10_01___00__01_01_01  ' 5 0
    So I decided to do it the old fashioned way:
            cmp       PatIdx_,  #0  wz
    if_z        mov      PattCurr,  PWMPatt00
            cmp       PatIdx_,  #1  wz
    if_z        mov      PattCurr,  PWMPatt05
            cmp       PatIdx_,  #2  wz
    if_z        mov      PattCurr,  PWMPatt04
            cmp       PatIdx_,  #3  wz
    if_z        mov      PattCurr,  PWMPatt03
            cmp       PatIdx_,  #4  wz
    if_z        mov      PattCurr,  PWMPatt02
            cmp       PatIdx_,  #5  wz
    if_z        mov      PattCurr,  PWMPatt01
    But this is by no way appropriate! Not even for a president!
