4.3" and 5.0" IPS TFT 16bpp adapters for Platform/Eval/Edge — Parallax Forums
RaymanRayman Posts: 15,854
edited 2024-12-19 22:31 in Propeller 2
Just got to work testing some prototype TFT LCD adapters for two header Platform/Eval/Edge type setups.
A very long time ago did something like this in 24 bpp with 480x272 resolution, using two octal buffer to help hold the data from 8-bit bus.
That was fine, but now there are 800x480 resolutions version of the 4.3" and 5.0" IPS TFT displays.
P2 isn't fast enough to do 24 bpp on these.
So, new version is 16bpp with just one octal buffer chip. This should let us do 800x480, if math was done right...
Thinking this will work great with the 16bpp PSRAM GUI also being worked on...
Idea was for this to work on the new Platform board, but also the Eval and Edge.
Now that have it though, it's pretty clear that the header side interferes with stuff on Eval and Edge.
Have to remember to fix that in next version...
  • RaymanRayman Posts: 15,854
    edited 2024-12-19 22:44
    Some perhaps questionable additions to the design are Nunchuck and QWIIC connectors on the outside edge.
    Thinking about dropping that... But, might keep as Nunchuck is basically free and QWIIC is fun and cheap to add...
    These give additional purpose to the I2C bus...
  • Is there a way to layout the QWIIC and Nunchuck connectors such that you can't plug into the QWIIC when the Nunchuck is plugged in?
    Guess could add a solder bridge for power…
    Is there a problem with both connected?
    Bus speed limit maybe?
    Need to get one of those new round displays too…
    Maybe can adapt this to work with that…
    Just found a "feature" in the 800x480 resolution screens that didn't expect...
    Was thinking the pinout was the same, except for Pin#35 that was Analog Vdd for a resistive screen now being N/C because there is no resistive version.
    First page of datasheet looks like this.
    But, second page of datasheet says the Pin#35 is Built In Self Test, that is activated when high.
    Was wondering at first why the screen was showing some test patterns that wasn't programmed...
    So now have a bit of a quandary... If want to support the resistive touch version of 480x272 screens, will need a different version of the board or a solder switch...
    816 x 913 - 98K
    Hmm... Also just realized that 800x480 resolution without PSRAM might not be possible.
    At least, not without major modifications.
    Would need to be 8bpp with LUT for sure. And, that is slow without streamer...
    Depending on the resistance it expects and current requirement, perhaps the P2 IO pin can source the Vdd for the resistive touch and behave as an input when first powered to somehow auto detect the type of screen, or manually drive it from settings for the type of LCD fitted. You can just add a pull down low resistance to this pin via IO port settings, to keep BIST low.
    Typically the resistive touch panels just have X+/X- and Y+/Y- pins you can control directly with P2 IO and read back with ADC's, so not sure what this Vdd is unless it powered an on board touch controller reporting via I2C perhaps?
    @rogloh These are good ideas, but there are no free pins here.
    Well, actually in DE mode, vsync and hsync may not actually be needed.
    So, if gave up I2C also, would have 4 free pins. But, still not enough to both power resistive touch and make measurements on it....
    Actually suppose 4 free pins might be enough…. Might have to try that one day…
    In a desperate attempt to avoid using the streamer here, appear to have found a way to use the smartpins to pulse the pixel clock and upper data latch pins:
      'Setup smart pins for LCD data control
      pinstart(LatchPin, P_Pulse | P_OE , 2<<16+4, %01)
      pinstart(PClkPin, P_Pulse | P_OE , 2<<16+4, %01)
    So now, only need one instruction to toggle the LatchPin and PClkPin instead of two inside the main visible data output loop:
    DAT 'HVisible - Visible data output
    HVisible
                drvh    #DePin
     'can have 9 instructions besides the drvh/l and have ~10 MHz dotclock with 250 MHz clock
     'RJA 21Dec24:  Attempting to use smartpins to speed loop
                rep     @.end,#xpixels
                rfbyte  clr2
                rfbyte  clr1
                setbyte baseport,clr1,#basebyte
                wypin   #1, #LatchPin
                waitx  #0
                setbyte baseport,clr2,#basebyte
                wypin   #1, #PClkPin
                waitx  #0
    .end
                drvl    #DePin
    This is letting us get 62 Hz refresh @180 MHz P2 clock.
    Will have to tweak the waitx values for higher P2 clocks...
    This is for the 480x272 resolution IPS display.
    This should let me do the 800x480 version at a reasonable P2 clock and refresh (hopefully).
    edited 2024-12-21 19:37
    Got 800x480 working with 54 Hz refresh at 320 MHz P2 clock.
    It looks good and really don't see any flicker with much lower clock rates.
    Had a bit of trouble making it work, but inverting pulse polarity and triggering before setting the data seems to be working:
      pinstart(LatchPin, P_Pulse | P_OE |P_INVERT_OUTPUT , 2<<16+4, %01)     '
      pinstart(PClkPin, P_Pulse | P_OE |P_INVERT_OUTPUT , 2<<16+4, %01)
    HVisible
                drvh    #DePin
                rep     @.end,##xpixels
                rfbyte  clr2         'Note:  24 bit bitmap is stored in order:  blue, green, red (but we need to reverse that)
                rfbyte  clr1
                wypin   #1, #LatchPin
                wypin   #1, #PClkPin
    .end
                drvl    #DePin
    edited 2024-12-21 20:35
    Practicality of the 800x480 driver/display is questionable without PSRAM.
    This test image takes up most of hub ram and only covers half the screen.
    Could working in 8bpp and have another cog convert from 8bpp to 16bpp by scanline though.
    https://en.wikipedia.org/wiki/Blue_jay#/media/File:Cyanocitta_cristata_cyanotephra,_Lubbock,_Texas_2.jpg
    Hard to get a good photo of screen with iPhone... Screenshot below shows some hashing that isn't really there...
    2016 x 1512 - 536K
  • Yeah half size on screen is not ideal. Might be better to line double in that case - though that gives non square pixels of course. PSRAM is the way to go for higher resolutions & depths. A single 4 bit PSRAM is probably good enough too. In my prior P2 LCD "tablet" project, I designed in a single 4 bit PSRAM with that use in mind in order to avoid excessive hub RAM use. Have to get back to that at some point once I release my video driver with parallel LCD RGB mode and can test it out again.
    https://forums.parallax.com/discussion/comment/1532340/#Comment_1532340
    That is another way to go... Using just one PSRAM chip would free up plenty of pins for direct 16-bit interface, instead of this multiplexed 8-bit bus... That would make 70 fps easy... (Think this display does 70 Hz, but maybe not, have to check...)
    Just remembered that perhaps a better option for all of this is just to use the HDMI version...
    But, that is $112 vs $72. Guess that's the major reason not to...
    Working on an 8bpp version for the 800x480 displays.
    Having to create a 16-bpp line buffer for this and will use another cog to translate from 8bpp to 16bpp on the fly.
    Don't want to have to require PSRAM to be able to use the display...
    Think have 8bpp version working, but had to add a delay to the pixel output, reducing FPS to 34 fps with 320MHz P2 clock.
    Appears could fix this by using two cogs to do the conversion.
    Conversion assembly could probably be sped, but thinking not enough to catch up to pixel output...
    Maybe though... If used rfbyte to read in the whole line and store in cog ram and then do wfword loop to send it all out...
    Here's the present code for conversion:
    DAT 'ConverterEntry  'Convert 8bpp bitmap into 16 bpp buffer, one line at a time
    orgh
    org
    ConverterEntry
    GetPointers   'First get pointers to 8bpp bitmap and 16 bpp buffer
                  rdlong    ptrb,ptra++ 'ptrb is now pointer to bitmap
                  rdlong    ptra,ptra   'ptra is now pointer to 16 bpp line buffer
    GetLUT  'Then, read palette into LUT
                  add       ptrb,#$36 'offset to palette
                  mov       cxx,#0
                  rdfast    #0,ptrb         'load .bmp palette into lut
                  rep       @.end,#$100
                  rflong    cyy
                  shl       cyy,#8
                  rgbsqz    cyy
                  wrlut     cyy,cxx
                  add       cxx,#1
    .end
                  add       ptrb,##$400 'offset to 8bpp bitmap data
                  mov       pl,ptrb 'save ptrb
                  mov       pm,ptra 'save pa
    FrameStart
                  mov       cyy,#ypixels
                  'rdfast    #0,ptrb
                  mov       ptrb,pl
    FrameLoop 'Begin conversion
                  mov       cxx,##xpixels
                  mov       ptra,pm
    LineLoop
                  'rfbyte    cp
                  rep     @.end,cxx
                  rdbyte    cp,ptrb++
                  rdlut     cp,cp
                  wrword    cp,ptra++
    .end
                  'djnz      cxx,#LineLoop
    NextLine
                  waitatn
                  djnz      cyy,#FrameLoop
                  jmp       #FrameStart
    pm long 0
    pl long 0
    cp long 0
    cxx long 0
    cyy long 0
    2016 x 1512 - 511K
    edited 2024-12-26 22:56
    Switched Converter code to use rdfast and wrfast with cog buffer and self-modifying code.
    FPS now back up to 51 fps with 320 MHz P2 clock.
    The additional delay that was "waitx #8" is now down to a single "nop".
    Don't think there's any improvement to be made, but who knows...
    Pretty sure 51 fps is just fine, except maybe for gaming or something.
    FPS will be better when using PSRAM instead of hub ram though...
    orgh
    org
    ConverterEntry
                  jmp       #GetPointers
    buff long 0[200]
                  mov       cxx,#0
                  rep       @.end,#$100
                  rflong    cyy
                  shl       cyy,#8
                  rgbsqz    cyy
                  wrlut     cyy,cxx
                  add       cxx,#1
    .end
                  mov       pm,ptra 'save pa   (line buffer)
    FrameStart
                  mov       cyy,#ypixels
                  mov       ptrb,pl
                  mov       ptra,pm
                  mov       blocks,#4
    BlockLoop
                  mov       cxx,#200'##xpixels
                  setd      CogMov,#0
                  sets      HubMov,#0
    LineLoop
                  rdfast    #0,ptrb
                  rep       #4,cxx
                  rfbyte    cp
                  rdlut     cp,cp
    CogMov
                  mov       0-0,cp
                  add       CogMov,incd
    .end
                  wrfast    #0,ptra
                  rep       #3,cxx
    HubMov
                  mov       cp,0-0
                  wfword    cp
                  add       HubMov,#1
    .end2
                  add       ptra,#200*2
                  add       ptrb,#200
                  djnz      Blocks,#BlockLoop
    NextLine
                  waitatn
                  djnz      cyy,#FrameLoop
                  jmp       #FrameStart
    blocks long 0
    incd long 1<<9
    pm long 0
    pl long 0
    cp long 0
    cxx long 0
    cyy long 0
    czz long 0
    edited 2024-12-27 17:28
    With tip from @evanh sped up 8-bit to 16-bit conversion enough to remove that NOP and get full frame rate back.
    Was doing rep to write words from cog to hub.
    Now, packing the words into longs in cog and then using SETQ to fast write cog longs to hub.
    orgh
    org
    ConverterEntry
                  jmp       #GetPointers
    buff long 0[200]
                  mov       cxx,#0
                  rep       @.end,#$100
                  rflong    cyy
                  shl       cyy,#8
                  rgbsqz    cyy
                  wrlut     cyy,cxx
                  add       cxx,#1
    .end
    FrameStart
                  mov       cyy,#ypixels
                  mov       ptrb,pl
                  mov       ptra,pm
                  mov       blocks,#2 'two blocks of 400 pixels each
    BlockLoop
                  mov       cxx,#200
                  setd      CogMov,#0
    LineLoop
                  rdfast    #0,ptrb
                  rep       #4+3,cxx
                  rfbyte    cp
                  rdlut     cl,cp
                  rfbyte    cp
                  rdlut     cp,cp
                  setword   cl,cp,#1
    CogMov
                  mov       0-0,cl
                  add       CogMov,incd
    .end
                  'Tip from @EvanH to move longs fast
                  setq #200 - 1
                  wrlong 0, ptra
                  add       ptra,##200*4
                  add       ptrb,#200*2
    NextLine
                  waitatn
                  djnz      cyy,#FrameLoop
                  jmp       #FrameStart
    cl      long 0
    blocks long 0
    incd long 1<<9
    pm long 0
    pl long 0
    cp long 0
    cxx long 0
    cyy long 0
    czz long 0
    edited 2024-12-27 19:17
    Added XTerm palette (by replacing the included bitmap with one with xterm palette, attached here).
    This bitmap both shows the palette and contains the palette :)
    Modified the demo from 2.4" touchscreens and seems to be working:
    https://www.youtube.com/shorts/0vvW_fbBTis
    Fonts that were giant on 2.4" are regular size here...
    Think can declare victory with 8bpp mode and move on to 16bpp PSRAM mode.
    (Although perhaps should also get this driver also working with regular resolution, 480x272, displays)
  • evanhevanh Posts: 16,945
    Since you're using the special PTRx registers you can make a small optimisation on auto increment.
                  setq #200 - 1
                  wrlong 0, ptra
                  add       ptra,##200*4
    can become
                  setq #200 - 1
                  wrlong 0, ptra++
    @evanh Thanks! Seems to work...
    Nice 👍
  • Created a streamer based driver for the 480x272 version.
    Though found some pretty bad hardware flaws, so it seems like Ray will make a new version:
    • Bad expansion of 5/6 bit channels to 8 bit that leads to missing steps
    • The latch system essentially has the wrong endianess (high byte is latched, low byte connected directly), so can't use DMA with native 16bpp buffers
  • Note that the driver seems to work fine all the way down to
    _CLKFREQ = 57_000_000
    CLOCK_DIV = 3 ' For half-pixels
    even with software endian swap. So down to 6 P2 cycles per pixel.
    This would certainly also work with 640x480/800x480 screens even without crazy sysclocks.
    Maybe the double latch 24 bit idea should be revisited with driver code this clean.
    edited 2025-09-29 19:44
    Picking this project back up. New board is working with 800x480 IPS LCD (WVGA).
    This one only has one buffer chip, so is rigged for 16bpp.
    Think going to focus on 16bpp mode and working with the PSRAM drivers...
    Could also do 8bpp with LUT, but skipping that for now.
    There's not enough hub ram for a full 800x480 16bpp image, so just doing half the screen here.
    edited 2025-11-25 11:14
    Got the new boards in. Looks exactly like the above, but blue instead of green...
    This example is a slideshow from images that are loaded into PSRAM from uSD.
    Did I2C scanner on it and looks right.
    Only sorta issue is the frame rate. Removed all the delays and it is now at 44 Hz (with 300 Mhz P2 clock).
    This is enough to be flicker free, but would ideally be closer to 60 Hz, also want to allow slower P2 clock...
    Actually, there's another issue... The first column of pixels looks wrong. Might be supposed to be the last column, not sure yet.
    I've tried all the simple things and haven't fixed it yet...
    Here's the main visible pixel loop:
    HVisible
                drvh    #DePin
                rep     @.end,##xpixels'800'xpixels
                drvl    #PClkPin
                drvl    #LatchPin
                rfbyte  clr1
                drvh    #LatchPin
                drvh    #PClkPin
    .end
                drvl    #DePin
    Think could move some pin toggling to a smartpin and gain enough to get to 60 Hz.
    But, this is a tricky thing...
    Guess need to ask @Wuerfel_21 for help :)
  • roglohrogloh Posts: 6,185
    You had earlier code here that used smartpins...does that still apply with this HW?
    https://forums.parallax.com/discussion/comment/1564322/#Comment_1564322
    Also in rep loops with critical timing setups, you sometimes need to unroll either the first or last pixel to be treated differently while still meeting the required instruction spacing. That might explain your first column of pixels issue perhaps.
    Thanks @rogloh, totally forgotten about that.
    That might shave off two instructions from the loop, might be enough...
    Was thinking about a different way, where the pin toggling was free running.
    But, this is a lot easier...
