Breadboard overlay for P2eval
Tubular
in Propeller 2
This overlay board for P2eval is modelled on your classic 300-tie breadboard, ie 30 pins wide.
I've extended the middle so there are actually 360 pins here
Nice. I tend to use the Eval more than any other board (so much so that I made a P1 version for myself).
I made this add-on for the Eval and other boards with the 2x6 header pins. To be fair, it's based on something I saw someone else do. This uses the breadboard from the PAB which is small, but I find big enough for test circuits (like the 1W part in the picture).
I also made the XBee adapter that has TX and RX LEDs on it so I can see activity.
I really like what you did too, Jon.
Boards arrived today. Here’s one loaded with almost all the headers. Need to buy some more as this board really eats them
