Breadboard overlay for P2eval — Parallax Forums
This overlay board for P2eval is modelled on your classic 300-tie breadboard, ie 30 pins wide.
I've extended the middle so there are actually 360 pins here
  • JonnyMacJonnyMac Posts: 9,642
    edited 2024-11-04 22:40
    Nice. I tend to use the Eval more than any other board (so much so that I made a P1 version for myself).
    I made this add-on for the Eval and other boards with the 2x6 header pins. To be fair, it's based on something I saw someone else do. This uses the breadboard from the PAB which is small, but I find big enough for test circuits (like the 1W part in the picture).
    I also made the XBee adapter that has TX and RX LEDs on it so I can see activity.
    1512 x 2016 - 716K
  • :smile: Always good to have gear like this handy for some quick experiments. I do like both of these board options, though Jon's is easier to use while retaining other IO, unless you also bring up some long pins through this overlay board (making it a porcupine).
  • I really like what you did too, Jon.
    Boards arrived today. Here’s one loaded with almost all the headers. Need to buy some more as this board really eats them
