NTSC VIdeo Question — Parallax Forums
NTSC VIdeo Question
So I am trying to upscale the video for my Color Computer 3 so it can be displayed on a VGA monitor. I have a GBS-8200 that I thought should work, however it will not properly sync. I am wondering if the HSYNC is inverted and the upscaler can't deal with that. Here is an image of the hsync line with the red line as a reference.
Any video gurus out there that might know what it should look like?
  • OK, I think I figured it out. The RGB is composite levels and the HSYNC and VSYNC are at TTL levels. The BGS-8200 needs csync (composite sync). I think that is the issue.
  • Try mix them together with resistors as hv sync
  • composite sync just means combined H/V sync. That's a separate issue from whether the sync is at video level or TTL level.
    The GBS board should accept TTL-level H/V sync just fine. (obviously not through the 5-pin connector though).
  • @Wuerfel_21 so I saw where it works best with composite sync, but yes, it is supposed to do RGBHV. It will not sync to the CoCo 3. Looking at the signal above, the pulse goes high between frames. Looking at VGA, the signal goes low between frames.
    Also the CoCo appears to do inverted V-Sync as well.
    Is that what I am seeing in the documentation? If you think so, I am going to build a circuit to invert them and see if that works.
    Tried that. No joy.
    Luckily I have a multisync NEC LCD Monitor that the CoCo 3 works fine on. Only a handful of VGA monitors can produce an image from the signaling. (15KHz) I think it is something really silly that prevents it from working with the BGS-8200. I haven't found anyone that has been able to get it to work.
  • Sync polarity shouldn't really matter on anything even slightly digital. Though idk, these GBS boards have a reputation for being bit a bit shoddy (though people do mod them for improved quality etc)
  • I remember some RGB signals have the sync in the Green signal ?
    My previous guess is confirmed by: but inverted
    https://www.retrorgb.com/building-a-passive-sync-combiner.html
  • Those RGB/CGA/EGA to VGA converter boards work well from Amazon, about $20
  • Just a quick update on this. Unfortunately doing an ORed H+V for csync did not produce the a good image when feeding the BGS-8200. I built an XNORed H+V csync from a CD4077 chip. It worked out great. Video looks crystal clear.
