A little help with understanding this C code
I am in the process of trying to convert some code from C to Spin2 and am getting a little hung up on what is happening here. It appears that the following occurs:
- A structure is instantiated that is modeled on the BitBucket struct and is named codewords.
- Possibly a byte array is created that is the size of bb_getBufferSizeBytes(moduleCount)? I don't know. I don't really understand what is happening at this step.
- The address of the codewords structure, address of codewordBytes array?, and size of the codewordBytes array is passed to bb_initBuffer.
struct BitBucket codewords;
uint8_t codewordBytes[bb_getBufferSizeBytes(moduleCount)];
bb_initBuffer(&codewords, codewordBytes, (int32_t)sizeof(codewordBytes));
Am I correct in those assumptions?
Also, these dynamic allocations of memory and variables are really cooking my noodle. I suppose there is no good strategy to deal with this in spin. It's a whole different way of doing things.
Any help would be appreciated. I haven't programmed any C or C++ in 20+ years. C# is just easier.
Yep, that's exactly what it does. No, this isn't what good C code looks like. The variable-sized array is considered a dubious feature (only added in C99, later made optional). Unless
is a macro of course, in which case they should make it uppercase or something.bb_getBufferSizeBytes returns a uint16_t so to cover all use cases, I need to allocate 64Kbytes. Ug. This is annoying. Maybe I can test edge cases and see what the actual limit should be.
Follow-up question:
Is this struct really just a LONG, WORD, and BYTE that is really a pointer?
typedef struct BitBucket { uint32_t bitOffsetOrWidth; uint16_t capacityBytes; uint8_t *data; } BitBucket;
Seems really odd that a pointer would be of type BYTE.
It's a pointer to a byte (in this case multiple bytes, as it were). All pointers are 32 bit on a 32 bit machine.
Got it. That really helps Ada! Thank you!
OK, I want to make sure I understand this correctly.
BitBucket *bitGrid is just a pointer to the actual struct that gets passed? The real structs have the ampersand. &modulesGrid and &isFunctionGrid
Is my understanding correct?
static void bb_initGrid(BitBucket *bitGrid, uint8_t *data, uint8_t size) { bitGrid->bitOffsetOrWidth = size; bitGrid->capacityBytes = bb_getGridSizeBytes(size); bitGrid->data = data; memset(data, 0, bitGrid->capacityBytes); } // A little further down the code....... BitBucket modulesGrid; bb_initGrid(&modulesGrid, modules, size); BitBucket isFunctionGrid; uint8_t isFunctionGridBytes[bb_getGridSizeBytes(size)]; bb_initGrid(&isFunctionGrid, isFunctionGridBytes, size);
Roughly, yes. But ampersand just means "address of", for assigning to a pointer. It can be applied to even a pointer, to make a pointer to a pointer.
And when passing a pointer, it's only the pointer being passed. The structure stays put.
So, in the code above, a pointer to isFunctionGrid, which is a struct of type BitBucket, is passed into bb_initGrid as bitGrid. Where inside bb_initGrid assignments for bitGrid properties are done, they are really making assignments to isFunctionGrid properties. Is that Correct?
Yes. The pointer provides access to the original definition (instance).
Actually, that example has a quirk of C in it.
The passing of byte array
isFunctionGridBytes
to functionbb_initGrid()
is missing its address-of ampersand. This is okay syntactically, if a little ambiguous. C has no direct passing of arrays/structures, therefore the compiler assumes address-of.Err, looks like I am a little wrong there. Just placing an ampersand in front of an array's symbol will produce a type mismatch warning. The verbose version of that example would be
bb_initGrid(&isFunctionGrid, &isFunctionGridBytes[0], size);
. So structs and arrays differ in that respect.Thanks @evanh ! This helps.
I have taken 5 pages of handwritten notes about how the structure of this C program works. Hopefully over the next few days I can get it converted to Spin. I am sure this would be an easy task for most. I have started and stopped half a dozen times on this project. I have a feeling it will work out this time. I now have actual hardware the C code was written for and finally figured out how to have debug info output to the serial connection. Arduinos are weird.
--Terry
And more dumb questions.....
In the code I have identified 3 structs that are instantiated of type BitBucket, however it appears they use two separate syntaxes.
When I hover over BitBucket for codewords, it says "struct BitBucket"
When I hover over BitBucket for modulesGrid or isFunctionGrid, I get "Type-Alias Bitbucket"
Is this just a style difference in syntax, or is does the use of "struct" before the datatype make a difference?
Short answer: There will be a
typedef BitBucket BitBucket
somewhere I suspect. I've never tried using identical spelling like that but I presume it's legal.I'll let someone else better versed in the formal C descriptions fill you in more.
Yes, I see the type definition. I just don't understand the difference between the two syntaxes above.
Structure namespace is separate from the typedef namespace, so they can use identical names.
For those simple uses in your example they are the same. You can define a structure with either
struct BitBucket <symbol name>
or, because of the typedef,BitBucket <symbol name>
defines the same.Structure namespace has an important use case when declaring self-referencing structure types. Structure declarations for linked lists being the poster child of this.
It was my understanding that the typedef defines the structure and names it.
And that the following creates an instance of the structure and names that instance.
And the following also creates an instance of the structure and names that instance.
I am just trying to understand the difference between the last two, or if this was just inconsistent coding style.
I appreciate your patience. Trying to understand code when you don't know the little caveats of the language can be difficult.
"Defining" is the C term for creating an instance. "Declaring" is constructing the object type so to speak.
Typedef'ing is an optional alternative path, and entirely unneeded. I think it's solely available as a tidiness option.
The structure type can be declared as so:
struct BitBucket { uint32_t bitOffsetOrWidth; uint16_t capacityBytes; uint8_t *data; };
And then an instance defined with
struct BitBucket <symbol_name>;
. Which is one of the solutions employed in your example.BitBucket isFunctionGrid;
can just as easily be defined this way:struct BitBucket isFunctionGrid;
And while the typedef exists then
can be defined this way:BitBucket codewords;
Hope I've covered the bases this time.
Huh, I only just paid attention to what Ada was talking about. That variable sized array is totally new to me. I've only ever known ANSI C, aka C89. So I can't see how that works since there is no such thing as memory management in C natively. That's not how C was meant to be.
Thanks @evanh ! For the life of me I couldn't understand why it was written two different ways to define it. I didn't know if it could have been a difference in scoping, or something else. I really appreciate your help and showing me the correct verbiage.
Cool.
Speaking of C ways of doing things. The ternary operator in C,
a ? b : c
, it always felt an odd fit to me. As if it had been grafted from an older language. I've just looked it up on Wikipedia and sure enough it is almost verbatim from the 1963 CPL language, then BCPL, then C. https://en.wikipedia.org/wiki/Ternary_conditional_operatorIndeed. VLAs were added in C99 and subsequently removed as a requirement again in C11. Which just goes to show that everyone makes mistakes. Since C compilers are no longer required to support VLAs they should never be used if you want portable C. Use malloc instead.
Ross.
I have a new one. Why would flexprop throw this error?
status = fwrite(buffer, sizeof(ihdr) + 4, 1, pngfile);
The error is
error: Unknown type for sizeof
Removing the addition of 4 does not result in an error.
I've not tried doing that with sizeof() myself, but that error I have struck before. It was when I was attempting to add an offset to a compiler generated constant reference in Pasm source code. I ended up asking Eric for a feature improvement to allow the offset - which eliminated the error message.
It sounds like flexspin is having trouble figuring out the size of whatever
ihdr
is. How is that defined?@ersmith it is a structure.
typedef struct { uint32_t width; uint32_t height; uint8_t bit_depth; uint8_t color_type; uint8_t comp_method; uint8_t filter_method; uint8_t interlace_method; } ihdr_t ;
ihdr_t &ihdr; uint32_t chunk_length = swap_uint32(sizeof(ihdr)); status = fwrite(&chunk_length, sizeof(uint32_t), 1, pngfile); ihdr.width = swap_uint32(width + border*2); ihdr.height = swap_uint32(height + border*2); ihdr.bit_depth = 8; // 8-bit image ihdr.color_type = 0; // grayscale samples ihdr.comp_method = 0; // deflate/inflate ihdr.filter_method = 0; // adaptive filtering ihdr.interlace_method = 0; // no interlacing
@ke4pjw : Something seems a little off with that code;
ihdr
is declared asihdr_t &ihdr
(which means it's a reference to anihdr_t
, but nowhere is that reference assigned. Instead it just starts assigning to values of ihdr. Did you really mean to include the&
?@ersmith if I remove it, I get this error:
error: syntax error, unexpected identifier `ihdr', expecting ',' or ';'
I am just too ignorant of all the C "isms" to get why the "&" would be needed in the first place. This is probably just bad code.
OK, I think I figured it out. Somehow the typedef is not making its way from the header file. Ug.
Dumb question. when an assignment is done such as this
dir = -1;
And dir is 16bit signed, it litterally just assigns it the value of -1, correct? I ask because the code I am looking at does both
dir = -1;
anddir = +1;
and the style just seems different than other code. ie everything else isdir = 1;
