Where is I2C documents for this new LCD? — Parallax Forums
T ChapT Chap Posts: 4,254
edited 2024-03-09 14:38 in General Discussion
https://www.parallax.com/product/16x2-i2c-lcd-display-module-with-yellow-backlight/
The older serial LCD 2x16 is not available and I need to change to this newer version. The website does not show any I2C documents. Does anyone know where the commands are posted?
Edit I see some notes about this LCD being used on the "I2C Device Bus Scanner Utility" Maybe some code examples are in that code I'll check it out.
