Where is I2C documents for this new LCD?
https://www.parallax.com/product/16x2-i2c-lcd-display-module-with-yellow-backlight/
The older serial LCD 2x16 is not available and I need to change to this newer version. The website does not show any I2C documents. Does anyone know where the commands are posted?
Edit I see some notes about this LCD being used on the "I2C Device Bus Scanner Utility" Maybe some code examples are in that code I'll check it out.
Courtesy of JonnyMac, does this object help ?
https://obex.parallax.com/obex/lcd-i2c-pcf8574-driver/
I'm assuming you're after P1 code... not sure why I did that
Search for "PCF8574" here : https://obex.parallax.com/obex/
P1, P2 and C drivers come up.
Thanks! I use a PCF8474 on my board, interesting it is used for the LCD also.
Thanks Jon for making this object and demo. Works great!
