Streamer/Lut Can I change which byte is used on the fly? — Parallax Forums
If I set up the streamer to output to a pin as DDS, is it possible to switch which byte in the streamer's longs is used by the pin on the fly? I don't see how, but I also can't see why not..
    With each streamer command, you select which pins are the outputs or inputs. So, you can only change them at the command boundary, in time.
