P2 vs Airgun — Parallax Forums
P2 vs Airgun
RaymanRayman Posts: 16,154
edited 2023-10-09 20:05 in Propeller 2
Had a couple boards that needed P2 rework.
One came out of the oven a bit twisted so pins didn't line up right and wouldn't have worked.
Other one had a bad pin group that I needed. Not sure how I killed that pin group...
Anyway broke out the airgun and seem to have fixed both boards.
First one, with misaligned P2, I tried at 380C for several minutes with no luck, so increased to 400C and got it to move enough, although still pretty sticky.
Second board I cranked up to 450 to remove the bad P2. Then hit the pins with soldering iron to give them a coating of solder. Then added a lot of no clean flux to the pin pads and the central pad.
Applied 400C for about a minute and it dropped in place. Actually twisted a bit and had to push into position.
So, seems like I fixed the two boards. Note this is with leaded solder. Probably a lot harder with the unleaded solder...
  • The way I do it is tack solder one corner pin, then check alignment, tack opposite corner pin. After that I solder the whole row of pins together in one continuous solder blob, after that suck out the excess with the de-solder tool. Hakko FM-204
  • RaymanRayman Posts: 16,154
    edited 2023-10-09 21:10
    @DigitalBob That's sorta my usual thing too, but use braid instead of de-solder tool. Have to get one of those!
    The thing with P2 though, is that want to solder ground pad underneath. That kind of needs the air gun approach...
  • roglohrogloh Posts: 6,287
    edited 2023-10-10 02:13
    Good outcome. Great that you could save these boards from the bone pile. :smile:
  • I forgot to mention that I use a liberal amount of solder paste on the heat sink pad, then hot air it from the back.
    I can imagine hot air from back being better. Seems hard to do though…
