jm_ht16k33_4x14segs
in Propeller 1
Hello there
Are there something to setup in the hardware for the refered object work?
In another objet it has this line of code: htAdd = $70 ' Address of HT16K33 (Adafruit defult address module) and it worked very well.
I would like know what I am making wrong to it don´t work.
Thank you in advence.
I would LOVE for you to post the code you're having problems with -- especially when you call out one of my objects or projects. Archive your top-level project and attach it so I can see what you're seeing.
The file jm_ht16k33_4x14segs.spin is a layer on top of my jm_ht16k33.spin object which is a layer on top of my jm_i2c.spin object. I've zipped those files and attached them. Unzip them and put all in your Library folder. You will refer to jm_ht16k33_4x14segs.spin in your project/application.
