Flash resets itself.
In one of the prototypes that I am working on, I have been writing certain values to Winbond-W25Q128JV. The prototype works fine for a couple of hours then the flash resets on its own. Also, I am unable to re-upload the program unless I wait for at least half an hour. After P2 is reprogrammed it works for a while again then the flash is reset. And so goes on the cycle. Any suggestions in this regard? Thank you in advance.
Are there possiblity you are operating P2 faster then flash memories limit?
Sounds like there is pull-up missing.
