USB Host controller code ported to C++
in Propeller 1
Hi,
I have finally managed to successfully porting the USB Host controller code by M. Elizabeth Scott from Spin to C++.
Took me a while to make it working due to a very nasty issue with the received bytes count calculation that was very hard to debug.
The attached zip file contains the USBHost class and two demo applications: enumerate.elf shows the informations about the attached device, and hid.elf that polls a keyboard or mouse and shows the data from it.
Can be compiled with propeller-gcc using the included Makefile and uploaded and run on the Propeller with propeller-load:
propeller-load -p /dev/ttyUSB0 -t -r enumerate.elf
propeller-load -p /dev/ttyUSB0 -t -r hid.elf
The code is not fully tested and I'm sure it needs some more revisions so use with cautions.
Hope you enjoy!
Best regards,
Marco
Hope you enjoy!
Best regards,
Marco
Thanks for sharing it. I am interested in C/C++ and will look at it.
